Question about Philips FW-R7 CD Shelf System
How do i record cd's using the aux output on the phillips fw-r7?
    Brigadier General:
  • 8,546 Answers
You mean Aux INPUT, don't you?
Try this manual:
http://www.p4c.philips.com/files/f/fw-r7_22/fw-r7_22_dfu_eng.pdf
page 20
Posted on Apr 29, 2010
How do i record a cd using aux on phillips fw r7/37?
connect your aux device into the aux sockets on the back then proceed as recording from aux
Apr 28, 2010 | Philips Audio Players & Recorders
I have not been able to record LP's. The instructions mention hooking up the cables to the receiver outputs down to the TDK deck. Which outputs? Tape, Aux,? I tried splitting off of my phono outputs with...
your phono outputs are a whole diff ball of wax than aux or tape etc, whole diff signal, all that they should run to is phono in on the receiver. You are using the cd recorder as a tape deck more or less, so use tape out to line in on the tdk, and tape in from tdk output. so..when spinning record, you have receiver set on phono, and the tdk should also be receiving that signal, to playback you would hit tape monitor button on the receiver and hear what the tdk has done, or is doing.
Feb 01, 2010 | TDK DA-5900 2-Disc CD Recorder
My recently made music CD will NOT play in our Philips FW-R7. It will play on all our computers and DVD players. The message is "Wrong Disc." Other music CD we've made do play fine in the FW-R7.
This is common with burned cd's they have trouble playing in different sets. Do prerecorder cd's play fine in your philips? If those are having trouble also you could improve it's playability possibly with a cleaning of the opu. Optical pick up.
Jul 17, 2009 | Philips FW-R7 CD Shelf System
CANCELLING the demo mode
Once the demo has started, press the STOP button on the front panel for 3 seconds. Demo will stop and the unit will enter standby.
You can download the user manual here:
https://www.p4c.philips.com/files/f/fw-r7_22/fw-r7_22_dfu_eng.pdf
May 07, 2009 | Philips FW-R7 CD Shelf System
Recording trouble
Hi again,
I understand. Must be a glitch somewhere. Anyways, I already posted possible solutions here your original posting/problem. They were:
1. Power on the Philips FW-R7, leave the left tray empty and closed. Open the tray and put in a recorded CD (not a CDR but a regular CD from your music collection), close the right tray. Wait a couple of seconds as the FW-R7 reads the CD. Now open the tray, remove the music CD and insert your CDR. The FW-R7 should read the CDR without the error message and record to the CDR from any source. Let me know if this works for you;
2. laser cleaning or realignment (would need a service center);
3. try using lower then 40X blank CDs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 18, 2008 | Philips FW-R7 CD Shelf System
Recording trouble
Hi again,
Lost you twice on the Live Session, must be a glitch somewhere.
Recording
Unit may have defective disk motor or optical pick-up. Take in for service
May 04, 2008 | Philips FW-R7 CD Shelf System
Insert disk indicator problem
Unit may have defective disk motor or optical pick-up. There is a chance the lens on pick-up may need cleanning. If you can reach it, try gently useing a q-tip in a circular motion on lens
Jan 06, 2008 | Philips FW-R7 CD Shelf System
Shelf system shuts after a few minutes philips FW-R7
In power supply check capacitors ,one of them is leake or dry.Best way of detecting this cap is to have freez it (coolant) to sprey on the sections in power supply and thanindividual capacitors this will definately solve your problem.
Dec 16, 2007 | Philips FW-R7 CD Shelf System
Philips FW-R7 CD Shelf System Logo
164 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
