Question about Garmin Rino 130 (14 Channels) 2-Way Radio
Computer is Windows Vista...data transfer cable for map transfer is not compatable with VISTA.any solutions for newer computer operating versions?
  • 52 Answers
You might just have to down grade the os (operrating system) or just get diferent software.
Posted on Apr 28, 2010
I had to install on a newer computer Deluxe 99 and it says not compatible. What is the best solution since I have years of accounting to transfer?
If you have your Quicken data file you should be able to convert and open it with a newer version of Quicken (Quick Books). What is the type and version of the new computer (i.e. Mac OSX, Windows 7, etc)?
Mar 02, 2011 | Intuit Quicken Deluxe 99 for Windows...
My computer says that the print shop deluxe version 20 is not compatable with vista.
Print shop deluxe version 20 is not designed to work on windows vista. it was designed to work on windows 98 up to windows xp only. Try using a version that is compatible with vista like version 23.
Sep 08, 2010 | Computers & Internet
I have picture package 1.5 but when i want to convert the tape to cd, i can not select the source and target is there a patch for this ? This for DCR-HC32 E Also i have now bought a new laptop which has...
The supplied Picture Package software is not compatible with the Vista Operating System.
Option 1:
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Option 2:
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Good Luck!!!!!!!!!!!!!!!
Sep 18, 2009 | Sony DCR-HC32E DV Digital Camcorder
Diffrence
The terms 32-bit and 64-bit refer to the way a computer's processor (also called a CPU), handles information. The 64-bit version of Windows handles large amounts of random access memory (RAM) more effectively than a 32-bit system. For more details, go to A description of the differences between 32-bit versions of Windows Vista and 64-bit versions of Windows Vista online.
Jul 24, 2009 | Computers & Internet
Need software for Zire M150 that runs on Windows Vista?
Older palm products and vista aren't compatible. You either needs to transfer info via bluetooth or upgrade your palm if you wish to continue using vista. As far as transferring, possibly a memory card.
May 28, 2009 | Palm Zire Mono M150 Handheld
Won't work with Vista 64 bit
Hello
I am running Windows Vista 64 bit also and finding out that there are a lot of programs that won't run on a 64 bit machine due to the fact they are not supported for 64 bit, listed below is info to your problem,
Photoshop Elements compatibility with Windows Vista This TechNote lists which versions of Adobe Photoshop Elements are compatible with Microsoft Windows Vista.
Photoshop Elements Version Compatible with Windows Vista (32-bit)? 6.0 Yes 5.0 Yes
Note: You must download the Photoshop Elements 5.0.2 update to ensure compatibility with Windows Vista.
4.0 No 3.0 No 2.0 No 1.0 No
Note: For the versions of Photoshop Elements that are compatible with Windows Vista, the 64-bit editions of Vista are not supported. Adobe Technical Support can assist you with the features of Photoshop Elements and with issues that also occur in supported operating systems. Technical Support cannot, however, assist you with issues that occur only on the 64-bit editions of Windows Vista. Instead, you can use the following support options on the Adobe website:
  • The User to User Forums, on which you can enter your problem or concern to see if another Adobe user can offer advice. Access this resource at www.adobeforums.com.
  • The Support Knowledgebase, which contains solutions for issues that occur on supported operating systems. Access this resource at www.adobe.com/support/photoshopelements.
dmg49
Apr 15, 2009 | Adobe Premiere® Elements 3.0 Full Version...
I am trying to move my Bookkeeper program to a new Vista Computer. I am getting a message that I am trying to run an older version of Bookkeeper with newer pogram. My old computer is XP and the new one...
Most programs written for Windows XP also work in this version of Windows, but some older programs might run poorly or not at all. If an older program doesn't run correctly, use the Program Compatibility Wizard to simulate the behavior of earlier versions of Windows.
• Open the Program Compatibility Wizard by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
NoteTo find out if your programs (or programs you plan to buy) are compatible with Windows Vista, go online to the Windows Vista Compatibility Center. This website contains a comprehensive list of programs, computers, and devices that have been tested to work with Windows Vista.
Oct 24, 2008 | Computers & Internet
Sony handycam DCR-TRV330 Software
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRTRV330&region_id=1
Driver information for Microsoft® Windows Vista® and Windows® XP
  • The drivers needed to connect most Sony® cameras and camcorders to a computer are already included in the Windows Vista and Windows XP operating systems. With these drivers, you should be able to connect and transfer files to a computer.
    Note: If the your camera or camcorder is not recognized by the computer when connected, you may need an updated driver. Check the Updates tab below to see if any updated driver is available.
  • Detailed Windows Vista compatibility information is available for Sony Cameras and Camcorders.
  • Starter and 64-bit versions of the Windows Vista and Windows XP operating systems are not supported.
Apr 20, 2008 | Sony Handycam DCR-TRV330 Digital Camcorder
Garmin Rino 130 (14 Channels) 2-Way Radio Logo
61 people viewed this question
Top Garmin Radio Communications Experts
TO Lady
eradiostore
eradiostore
Steve
Are you a Garmin Radio Communication Expert? Answer questions, earn points and help others
