Question about Gateway 550GR PC Desktop
Serious problem My gateway has been having problems for a very long time. At first the opening sign with the Gateway would just run and never actually turn on. Now the tower turns on and is clearly running; however, the monitor is black and when you turn it on it says "Power Save Mode."
    Genius:
  • Gateway Master
  • 1,479 Answers
Just because it turns on and you see lights on the tower and hear fans running doesn't mean to say it's turned on, it just means the power supply is doing something.
It could be something as simple as just remove and replace the ram. If not then it may be the graphics (either on-board or seperate card).
If you're not familiar with the insides of your pc then take it to your local friendly pc repair man.
Posted on Apr 28, 2010
    Sergeant:
    Novelist:
  • 172 Answers
Hi bigciss22. That means that your computer is turning on but NO booting up. Do you hear any beeps? Because depending on the number of beeps can mean either memory or video card. Open the machine and verify that the memory is tightly inserted. If you use the video card on the motherboard (most likely) I suggest you buy a new video card (you have to make sure the interface is either AGP or PCI (i dont think it's PCIe - PCI express). If you dont want to start swaping components, you will have to take it to a repair shop. I hope this helps and please dont forget to rate my answer. Thank you! :D
Why cant i sign into my Gateway computer
You need to contact Gateway Customer Service for the solution to this problem. It is likely they may have a FAQ on their website for this problem. You would be amazed how many people often encounter the same problem.
Apr 28, 2014 | Gateway Computers & Internet
Keyboard
please be patient and answer the questions.
Is the keyboard typing all by itself or not?
thanks so much
Sep 15, 2012 | Gateway Id47h02u Notebook I5-2410m {intel...
I have a Gateway model M-6881 with a Sony AD-7563A optical drive. When a dvd or any disc is inserted it does not auto play and when I open up my computer and double click on D: drive I get an error message...
Follow these steps
  1. Click on Start
  2. Click on Run
  3. Type in REGEDIT
  4. Click on OK
  5. Click on the plus sign (+) next to HKEY_LOCAL_MACHINE
  6. Click on the plus sign (+) next to SYSTEM
  7. Click on the plus sign (+) next to CurrentControlSet
  8. Click on the plus sign (+) next to Control
  9. Click on the plus sign (+) next to Class
  10. Click on the plus sign (+) next to {4D36E965-E325-11CE-BFG1-08002BE10318}
  11. On the right pane, click to highlight Upperfilters
  12. Right click on Upperfilters
  13. Click on Delete
  14. Click on OK
  15. On the right pane, click to highlight Lowerfilters
  16. Right click on Lowerfilters
  17. Click on Delete
  18. Click on OK
  19. Close the Registry Editor
  20. Reboot the computer
May 21, 2010 | Gateway (5500652) (  5500652)...
My Gateway GM5972 computer shut down and will not start up again, There is no video or audio. The fan still runs, and the DVD drive come on, but computer will not start up
Despite the fans running and the dvd powering up it could still be a power supply problem BUT it really sounds like the motherboard died.
I have built and repaired thousands of computers and your description fits the majority of the dead ones. Replacing the motherboard with a like board is the easiest solution. You can replace with a different motherboard but be prepared for problems. I wouldnt suggest it unless you are a experianced tech.
Apr 09, 2010 | Gateway GM5072 Desktop PC
Do you have internet explore ip address. it starts 192"?
what do you mean by internet explore ip?? just your computers IP?? or your routers IP??
normally the IP would be 192.168.0.XX submask is 255.255.2550
but if you just need to know your ip for now just go to START>RUN and type CMD that will open command prompt ( quick way is windows sign on keyboard + R ) to open RUN
once in CMD you type ipconfig then you'll see your IP adress, subnet mask and default gateway. hope this helps
Mar 05, 2010 | 2wire Wireless-G 802.11g ADSL Gateway
My compaq prasario is telling me I have no ip address how can i solve this problem i cannot connect to the internet
How are you connecting to the Internet now¿ That is a serious question since I will assume that this is a second computer hooked up to the same connection you want with the Presario. I also will assume that you don't have a Gateway / Router between the modem and the actual computer. I will assume that you want both of these computers on the Internet at the same time so you will want to hook up the Gateway. To reset the modem so that it will accept a different MAC Address (It's a computer thing) you will need to remove all the connections to the modem and pull out the battery that is behind a hidden door. The modem will need to be in this condition for 1 minute and then it can be hooked up to the new Gateway or Computer however you want it to be hooked up now that the modem has been reset. Good luck.
Sep 18, 2009 | Compaq Presario 5000 PC Desktop
Gateway computer does not turn on
Without seeing the machine, I'm thinking you have a motherboard problem. But try these troubleshooting steps before throwing in the towell:
Open the case and disconnect the CD cable. Now try it. If it still doesn't work, disconnect the hard drive and try it.
Let me know what happens. I've seen CDs mess up a system like this. I many times will swap out the power supply, but I'm thinking with the lights flashing, its a more serious problem.
Jun 23, 2009 | Gateway 500GR PC Desktop
Dont have recovery disks and have virus...actually just missing disk 2
If the popup you're getting is from something like "MS Antispyware 2009" or similar, that's the same trouble I've seen on several other computers. Download a removal tool called ComboFix. You can find information on how to use it and links to download it here. This is a handy tool even if the virus you have is different as it will fix a number of virus and trojan problems. ComboFix can be run in safe mode if your computer can't start all the way into Windows. Turn your computer on, and when you see the Gateway logo screen press the F8 key. This will give you a startup menu screen from which you can pick starting in safe mode. This prevents Windows from loading everything except the minimum stuff it needs to start. Run ComboFix and let it repair the troubles it finds.
May 25, 2009 | Gateway 835GM (835GH) PC Desktop
DSL (2wire modem) and LAN conflict
You can actually try accessing the interface of your gateway and put it on DMZ mode. That way it will open the ports on your gateway to ensure passage of all data from your gateway to all your computers even when the dsl is on. But make sure tat you have security software installed on all your computer workstations bec. putting your 2WIRE gateway on DMZ mode will expose your connection.
Aug 15, 2008 | 2wire 2700HG-B Router (2700HGB)
Gateway 550GR PC Desktop Logo
89 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
