Question about Haier Dryers
We purchased the haier encore super capacity washer and dryer 5 months ago! the dryer broke 3 days ago sounds like a jack hammer.it's under warranty.Haier sent a repair guy out he said he dont no whats the matter with it..and it could take up to a month to fix!! the washer is not working correctly the water flow has decreased trmendously. and is getting louder.has anyone else had problems with these products?
dididsaythat
  • 291 Answers
SOURCE: Haier beer dispenser model HBF05E
Either its not getting cold enough to shut off or your thermostate isnt working.. thats the only thing that cycles it.
Posted on Aug 29, 2007
SOURCE: My Maytag dryer makes an aweful noise.
Typical parts that wear out and get noisy on that model are the two drum rollers (part # 12001541), the front drum glides #306508, the idler pulley Y303705 and the blower wheel 303836. None of these parts are very expensive, but to do all of them would definitely add up to the point that you might want to think about whether or not you want to keep the machine in operation especially after 10 years of good service.
Posted on Jan 04, 2008
AlmostBob
  • 550 Answers
SOURCE: GE dryer is getting louder when running
most common cause is the failure, or wear of the rollers at the rear,
the drive belt places a lot of torque on the drum, and it has rollers to support this force, in addition to nylon guides as the front has
good roller
worn roller
most dryers access from the front, the front panel and door come off,
here are generic removal instructions
with dryer unplugged examine lower front panel.
If there are two screws at lower corners
  • remove screws
  • swing front panel up from bottom
  • unhook top clips
  • undo door switch wires
  • set panel and door aside
If there are no screws
  • remove llint screeen from top
  • remove 2 screws from under lint screen
  • with putty knife or other blunt blade
    push spring clips at front top corners
  • tilt top up
  • remove 1 screw each side 1/3 way from top of dryer
  • tilt front panel down
  • undoor door switch wires
  • set front panel aside
Common to both
  • reach under drum to belt tensioner, pull tensioner to end of spring travel
  • unhook belt from motor and tensioner
  • withdraw drum forward
  • examine rollers felts nylon guides
replace rollers in pairs if worn
replace nylon glides if worn
replace felts if worn, the back one may wear before the front one, if the dryer is the open drum type,
Posted on Oct 17, 2008
aborcass
  • 2651 Answers
SOURCE: Haier HWD1000 washer/drye
please repost for i have no knowledge of the haier productline
Posted on Jan 31, 2009
TheMobilian
  • 8220 Answers
SOURCE: Wire Scraping sound and sparks inside rear dryer drum area.
Probably the rear bearing has failed and caused the drum to rub against the heating element. Hey, is this the guy that said he heard a noise last month? LOL
Posted on Feb 04, 2009
A manual for a Haier Encore Super Capacity washing machine
Check your model # on Haier website for a manual download
Nov 11, 2017 | Haier Washing Machines
Dryer tub replacement...i need to replace the dryer tub. when dryer is on it makes a scrubbing noise
there may be something stuck in between the tub and the outer wall, have you tried to make sure this area is clear first. Make sure you unplug the dryer first before removing the back panel, then use a flashlight to check the tub and surrounding area. id do this first before i go to the expense of replace the tub section
Jul 20, 2014 | Haier / EncoreR Super Capacity Gas Dryer
Dryer super loud
This may be a structural defect and not repairable.
Sep 20, 2017 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer keeps tripping the circuit breaker no problem with previous dryer dryer is only 2 months old
call the store that you bought the machine from the dryer is still under warranty. it sound like you either have a short or a bad breaker
Jul 15, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
Kenmore 80 series only 3 yrs old, won't, spin and the agitator appears to be stripped
your agitator dogs are stripped there about $10.00,remove cap to replace. easy,need 1/2 to 3/8 adapter or 7/16 socket depending on model. and your coupler is broken about $20.00 its what runs yous washer its like your belt under neath between motor and transmission , less cloths max water will stop it from happening again
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
May 10, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Dryers Logo
146 people viewed this question
Top Haier Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Bill Long
Are you a Haier Dryer Expert? Answer questions, earn points and help others
