Question about Konica Minolta PagePro 1350W Laser Printer
I have a problem with the message "Output File name" what should i put?
I have Konika minolta 1350w Printer, my Pc (win Vista) when I need to print I get a message saying "Output File Name: " and when i put the file name it says " access is denied" need help pls.
  • 3 more comments
  • joenice Mar 27, 2008
    same prob
  • Anonymous Apr 22, 2008
    same problem
  • Laylabug May 05, 2008
    I am having the same problem
  • Student18 Sep 12, 2008
    Yeah I've been having the same problem. I had this problem when the PagePro was hooked up to a machine with XP. But on there I was able to uncheck the 'print to file' box and it started working fine. On the Vista, the box is greyed out and unchecked, so I can't even try that!
  • ewisnie765 Sep 18, 2008
    the same problem
OK, download the new driver from the website and install. Next, go to control panel and go to printer. Right click on printer and select "properties" Click the tab that says "ports".... uncheck where it says "print to file" and then check the box that says "USB"... this is what i did and it worked. Good luck!
Posted on Oct 08, 2009
    New Friend:
Don't need to install new driver.
Just right click on printer and select "properties" Click the tab that says "ports".... uncheck where it says "print to file" and then check the box that says "USB" if you are using USB port.
Posted on Mar 01, 2010
Pagepro 1400W Does not work with Vista...I don't care what they say I have tried everything...Ditch Vista and go to Xp...or better yet...Buy a mac and throw out the printer too!
Posted on Dec 17, 2008
Have the same problem, wanted to use with laptop, worked well on pc, but I get the same message print to file
Posted on Apr 09, 2008
SOURCE:
Konica minolta page pro with windows 7
I looked at the manufacturer's web-site:
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productname=1350W
and you are correct -- there are drivers for 2000/XP, and for 95/98, but nothing for Vista nor Windows 7.
Find an old computer running Windows 2000 or XP, and connect the printer to it, and "share" the printer across your home-network.
Apr 07, 2010 | Konica Minolta PagePro 1350W Laser Printer
I need a driver for a 1350W to run in Windows 7 (64). I'm thinking maybe a Vista 64-bit might work? My brand new 8 Gig Elite is without working printers!
I have this printer in the attic coz of vista. konica minolta did not bother to create a driver for VISTA. I brought out the 1350w not that i got win 7. still no driver.... i have a feeling there wont be a 1350w driver for win 7. however they have 1400w drivers for vista/7.
the only way you can print with the 1350W is as a remote printer in win virtual pc running xp.
Nov 21, 2009 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta 1350 printer won't print with Vista
Also try turning spooler OFF/ON. Also, try turning 1350 OFF/ON. Those sometimes work. But 1350 had same problem with W98SE so must be a problem in 1350 software(?). I got so tired of this that I bought a Canon MFC which works perfectly. Still use 1350 to use up the toner.
Sep 15, 2009 | Konica Minolta PagePro 1350W Laser Printer
Konica minolta 1350w status display comes on at start up
Open c:\windows\system32
find a file called MSTMON_Q.EXE
right click and rename the file to anything with a file extension .exe, I named it MSTMON.EXE
Create a shortcut to this new file in case you need it in the future and put the shortcut on your desktop
also, write the original name of the file down or put it on notepad, in case you want to change it back.
restart windows
Mar 13, 2009 | Konica Minolta PagePro 1350W Laser Printer
Don't have cd
hi i lost my konica minolta page pro 1350w printer software cd. I want free download for above software to make print
Jul 18, 2008 | Konica Minolta PagePro 1350W Laser Printer
Only allows "print to file" will not allow printer to print.
you can go to printers and change the port to the virtual usb printer port....from the file port
Mar 30, 2008 | Konica Minolta PagePro 1350W Laser Printer
Konica Page Pro 1350 - Not printing from DOS
When you install your printer, you may notice an message asking whether you want to print from DOS based programs. If you answer yes You could print from DOS based programes too. To do this you may need to unistall and re-install your printer again ! If it doesn't work you should download any ultility from the internet to get the printer supported on DOS.
Oct 06, 2007 | Konica Minolta PagePro 1350W Laser Printer
PagePro 1350W communication pops in and out
If you are using the USB interface, try switching to Parallel port instead. I had nothing but problem with USB and they all went away when using the Parallel interface.
Sep 28, 2007 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta PagePro 1350W Laser Printer Logo
1,861 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
