Question about Kenmore Oasis HE 27082 Top Load Washer
The machine stops during its cycle and displays an F1.
  • 299 Answers
This is a known issue for this model. There may be nothing wrong except for a false error from the control board. Call Sears at 800-847-9083 and give them the serial number to see if your unit is eligible for a free control board upgrade under their recall program. I just had the same problem a few weeks ago. They sent the part by UPS and then a technician out to install it once it arrived. In the meantime, you can still do the laundry by pressing "pause" twice and restarting the unit. Since the new control board was installed there has been no further problem.
Posted on Apr 28, 2010
I am getting a F1 code in my washer which causes it to stop several times during a wash cycle, what do I need to do?
Hello;
My name is Peter. I am a retired field service appliance technician.
If you own a Whirlpool Cabrio and are experiencing an F1 error, you're unable to finish or start a load of clothes. When the Whirlpool Cabrio displays an F1 error, this means the the control board is having difficulty communicating with the motor.
To fix your F1 error, you can first try to unplug your washing machine for 15 minutes and then plug it back in. If this doesn't work, you will need to replace the control board. The only tools that you need to replace the control board is a Phillips screw driver and a 1/4" hex head driver. Be sure to unplug the machine from the electrical outlet before performing any repairs.
After unplugging your Whirlpool Cabrio washer, carefully pull the washer away from the wall (Watch your drain hose and the two inlet hoses.) Next unscrew the 3 screws located on the back of the Whirlpool Cabrio. Next, take a picture or make note of where each plug connects to the control board. Next, unplug each plug and the pressure tube. Lastly, unscrew the 1/4 screw then remove control board. Replace with new control board and reverse your steps to install. The new board will fix the Whirlpool Cabrio F1 error.
Dec 08, 2014 | Washing Machines
Machine goes through the wash cycle then stops before it rinses and spins . Machine displays F1 OR F5 which indicates an error has occured , have to empty manually but cant get it to spin at all .....
Hello
F1 is usually a low water code.Check your hoses and water supply inlet screen for any bulid up of dirt or sediment.
Also the water inlet valve may need to be replaced.
F5 is a water temp fault.Possible bad heating element or thermostat.
The F1 code could be causing the F5.
Due to low water.
May 04, 2011 | Indesit Washing Machines
F1 code coming up on my Oasis HE washer
YES! Serious problem...more annoying than anything else. Wait until your machine stops at the spin cycle and displays "F1" again. We just had a repair tech out today and received a quote of $384+ to fix/replace the circuit board. Kenmore & Sears are fully aware of this problem and have issued a recall on a model that is one digit off of the model I have yet they will not do anything about this even though it is the same problem. These machines are huge dogs!
Jan 15, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis stops mid-cycle. Get F1 display on panel.
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!!
Dec 11, 2009 | Kenmore 24902 Top Load Washer
Machine stops during spin cycle and reads 'ob' on the display
Read this thread about your error. I am sure it relates to your (drain) problem.
Good luck and if you have any more questions, just come back here and leave a comment - I'm happy to help.
May 21, 2009 | Kenmore Washing Machines
Washing mchine stops during cycle and starts beeping
See if you are overfilling you machine or the load is out of balance. Even try running the machine empty
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Washer stops with an F1 Code during rinse cycles.
Well I have the same problem the only way I have found that my washer works is that on the soiler level make sure you put that on the heavy. And that should work I know its a pain but thats what I do and my washer washs with out stopping
Dec 04, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Elite Oasis HE F1 Error
Im sorry to tell you but you have a bad control board. This was a faulty board from the factory. There is a class action lawsuit agianst whirlpool (whirlpool made the oasis). Try calling to get whirlpool to fix it. Maybe try joining the lawsuit. They have remanufactured the part so the new one wont do that again. Its a great machine when it works right.
Nov 18, 2008 | Kenmore Oasis HE 27087
Washer stops immediately into cycle
f1 is the code for primary control failure cod be a bad connection at the primary control under the control console or a faulty primary control if its still under warranty id have a tech look at it
Jan 12, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Oasis HE 27082 Top Load Washer Logo
193 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
