The washer clicks off about 1 min into the cycle, then clicks back on after a minute or two, then off, then on. Maybe a solenoid?
  • 438 Answers
Might possibly be a thermal protection device in the motor to prevent overheating and subsequent burnout of the motor also some washing machines having a delicate wash feature programs a pause between each agitation, if this is not the case suspect the motor is over heating.
Posted on Apr 28, 2010
Washer gets stuck in agitation cycle and a 45 min load will take about 1 1/2 hours
Have you ever unplugged the unit in its current location? Try unplugging it for 10 minutes and plugging it back in to reboot the computer control. Other than that it's time to call in a pro.
Jul 20, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Washer says fo6 what is the problem
if it will drain and spin o. k. you may have a bad main board.
Mar 15, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Washer goes through 40 min. cycleand stays on 1 min. spinning and rinsing for another 30 min
your using way to much soap
during that whole 1 minute cycle it is detecting suds and trying to rinse the cloths further
cut way down on the soap here
you should be using 1 tablspoon per load
wash one load without anyy soap at all
this should help to reduce your suds lock
Oct 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load washer LHW0050PQ often will not start
Unplug the washer for 10 min. This will reboot the circiut board. Select one cycle. Selecting too many cyles in a short period or pushing too many buttons in a short period can overwelm the little brain in the board.
Apr 30, 2009 | Whirlpool LHW0050PQ Front Load Washer
One minute left
be sure water is draining out before spin starts if necessary remove bottom panel and clean pump out and ck hoses to pump be sure there are no excess suds ..wash only full loads small loads or loads with 1 heavy item will cause washer to sense off balance and try to balance load this will extend cycle time
Nov 09, 2008 | Whirlpool GHW9400 Front Load Washer
Washer won't run through a complete cycle-stops at 29 minutes
There is a service manual behind the control panel it will show you how to test the door locks. If might have a bad lock solenoid.
Aug 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
F1045w spin prob
unfortunately that sounds like your timer is faulty.......in Ireland a timer is now costing approx €100-€150 euro so its not worth replacing outside of warranty
May 20, 2008 | Zanussi F1045W Front Load Washer
Front load washer won't start
Telescope, Im assuming your model starts with 417.44092, Kenmore made by Frigidaire. You have the best model with the digital display. Try unplugging the machine for 5 minutes to see if you can reset the board. If that doesn't work put it into a test mode by doing the following: Turn the dial to drain spin, press cancel to turn off the led's. Within 5 seconds press and hold the options and pause/cancel together for 5 seconds. All the led's should light. Now by turning the dial 1 click at a time clockwise you are going to test the following. 1rst click- hot water solenoid 2. bleach solenoid 3. Bleach and wash water solenoid 4. door lock solenoid activates 5. door lock solenoid de-activates. 6. the washer will fill and tumbe. 7. washer will fill and spin 8. drain pump and door lock will activate and washer will go in high spin. 9 clicks from the start, the last error code will be displayed. To clear the error, press and hold the options and cancel buttons for 3 seconds. To exit the test, just unplug the washer for 5 seconds. Sometimes these electronic boards just get a glitch and have to be reset. Make sure that the dispensor door is shut all the way. Try these things first...Catriver..post back.
Nov 04, 2006 | Kenmore Energy Star 44092 Front Load...
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
