Question about Brother HL 1240 Printer
Light streak down 1 side - Brother HL 1240 Printer
    Scholar:
  • 118 Answers
turn printer on/off, unplug, plug in, should reset configs.
take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are stuck.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Posted on Apr 29, 2010
2 Suggested Answers
wheatlandsvc
  • 1110 Answers
SOURCE: my copies have a thin
Remove the toner cartridge and look at the toner "roller" on the front. Make sure you do not see the same 1/4" band on the roller where there is no toner. If you do then you have a defective toner cartridge. Do you have the machine hooked up to your PC? If so do the computer prints have the same blank line? If so then it could be something blocking the laser. This would require removing the drum/toner units and wiping the laser glass that is just above where the drum/toner cartridges sit in the machine. If the PC prints are fine then the blank line is coming from your document scanner so you would need to clean the strip glass in the document feed area.
Good Luck and Thank You for using Fixya.
Posted on May 20, 2011
Prints a light gray streak down the left side of paper
either the drum developer or fuser if you can show me a sample I can tell you which it is
Apr 14, 2014 | Kyocera Office Equipment & Supplies
White streak down center of page
Remove the toner cartridge and while keeping it level, shake from side to side. Re-install and test. If light streak goes away then you are back in business. Keep in mind that this MAY mean your toner cartridge is getting low on toner.
Good Luck and Thnak You for using Fixya.
WheatlandServices
Oct 25, 2010 | HP LaserJet 1100 Printer
Grey streak down the right side of the page 1/4 inch wide
Yip, its fuser film alright. You could pick up a fuser unit / kit from:
http://www.printersupplies.com/c-Laserjet3015Parts.html
and fix it yourself using the manual in this post:
http://www.fixya.com/support/t468332-fuser_removal_instructions_hp_laserjet
Best of luck
BD
Sep 07, 2010 | HP LaserJet 3015 All-In-One Printer
White streaks on photos
Light leak, definately a light leak. You need to change or add foam around the chamber to prevent any light from entering.
Jun 15, 2009 | Canon EOS-AE-1 35mm SLR Camera
I have a Hitachi 50V500A
You need a new light engine.
Apr 23, 2009 | Televison & Video
Magenta leaving a colorless streak
You need to check with Xerox , ther is some toner that was manufactured last year (2008) that was defective
the phone number for xerox support is 503-682-7377
Apr 01, 2009 | Xerox Phaser 7760/GX Laser Printer
The fax streaks
Open the lower part of the number panel by pulling up 1 inch. and clean the small scanner glass.....hard to see.
Mar 02, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
Black streaks down left side of printouts Epson Aculaser C2600
I had exactly the same problem. Luckily we have 3 of these printers. Swapped the photoconductor and it solved the vertical streaking, even though the photoconductor was only half way through its life.
Dec 02, 2008 | Office Equipment & Supplies
Lines down both the left side of the printouts.
good day,
this usually occurs when you print large volume of copies of documents that goes beyond the printable area of the paper, some powders stick in the roller of your printer hence making the gray streak.
you can check if the rollers have accumulated some powder, if so, have the rollers cleaned.
i hope this will help.
Oct 14, 2008 | HP LaserJet 4L Printer
Black streaks on printout
Your fuser is worn out. Needs to be replaced.
Mar 27, 2008 | HP LaserJet 5p Printer
Brother HL 1240 Printer Logo
184 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
