Question about Westinghouse 78092 Verandah Breeze Ceiling Fan
My outdoor ceiling fan doesn't seem to "blow" the air down low enough so that I can feel the coolness?
  • 4 more comments
  • petiepalaza Apr 28, 2010
    Ok, my fan was installed on a slanted ceiling so that one side the "blades" are 4" from ceiling and the other side approximately 14" from ceiling. Do you think it's too high?
    SO WHAT DO YOU SUGGEST - HOW FAR DOWN SHOULD IT BE FROM THE CEILING? ANOTHER FOOT? DOES THE FACT THAT IT'S ON A SLOPING CEILING HAVE ANYTHING TO DO WITH IT NOT BLOWING AIR?
    I'm not sure if this got sent. Should I move the fan down to a foot below the ceiling and then on the top slanted part it will be two feet from ceiling. Does the slanting of the ceiling have anything to do with the way the air is not flowing right?
  • petiepalaza Apr 29, 2010
    Ok, first I live in Belize so weather is hot and humid. Next my porch size is approx 7'x18'. I have a 52" fan (westinghouse Verandah Breeze78092 - pretty much all the island had).
    My blades are on properly, my ceiling is slanted (approx. 10' down to 7.5'), I only have clearance on one side of 4" so I will put a 12" extention to lower fan to get better air circulation - yes? This is my next step OR do you think the fan I purchased is not appropriate for my conditions and if so, what do you recommend. Living in a foreign country the choices are few.
    You're not answering my questions?: What about the fan itself?
    I am going to lower the fan but will not be able to have this done til next week so I will not sign off on this problem.
  • 713 Answers
Hi,i think the problem is from the motor of your ceiling fan,the motor is not producing enough torque(force that drives the blade) of your ceiling fan,the higher the torque,the lower the blown air travels down enough for the coolness to be felt. However the motor needs to be replaced,this is the lasting solution to your problem.
Alternatively,as a temporary solution you might replace the pipe rod that hangs the fan from the ceiling,with a longer pipe rod,which can be purchased from any electrical parts shop in your area.
Thanks and take care
Posted on Apr 30, 2010
  • 5,911 Answers
Most ceiling fans have a direction switch on the motor that enables the consumer to reverse the direction of rotation on the fan. In one direction, the fan will pull air up from the floor. Reversed, it blows air down. You may want to verify the set up on your fan motor to see if the direction switch is in the correct position.
Posted on Apr 29, 2010
    Guru:
  • 415 Answers
Most ceiling fans are equipped with a switch that reverses the direction of the blades. In the winter time, the recommended direction is to have the flow of air go upward where it captures the heat collected at the ceiling and moves it downward along the walls to minimize the breezy cooling affect. In the summertime, the recommended direction is to have the flow of air go downward to create a breezy cooling affect.
Ensure the air is blowing down. If it still does not seem to be blowing hard enough, it could be that you need a larger fan or a longer downrod depending on the size of your room and heighth of your ceiling. Click HERE for a website that has an array of information on ceiling fans to include sizing ceiling fans and downrods for your room.
I hope you find this information to be very helpful to you moving forward. :-)
  • 2 more comments
  • laura Newman Apr 29, 2010
    The size of the rod and the fan will depend on the size of your room and the heighth of your ceiling. The website will help you make that determination; however, if you prefer, I can offer suggestions once I receive your information on the dimensions of your room. :-)
    Yes, lowering the fan will improve the circulation. :-)
    52" fan is appropriate for a room up to 485 sq ft.
    If the porch is open or partially open, you will need to be in close proximity of the fan to feel the breeze. In other words, you may not feel the breeze on the other end of the porch. Most open-type porches in hot/humid climates use multiple fans across the length of the porch.
    I hope this is helpful to you. I look forward to hearing back from you. :-)
    Click http://www.ylighting.com/lib/ylighting/M..." target="_blank" rel="nofollow" >HERE for an alternative ceiling fan that should work well for offering a breezy cooling affect on your porch.
    Also, here are some pictures I collected of ceiling fans installed on Southern Porches where it's hot and humid:
    I hope this is helpful. When choosing ceiling fans there are so many considerations........performance of course, but also cost and style. :-)
  • 4,059 Answers
The amount of air a fan can blow is determined by how much air it has to pull. The closer the fan is to the ceiling the less air is available. You may need to get an extension to put between the ceiling and the fan. It's a hollow rod. You can get them a places like Lowes.
Another possible problem with outdoor fans is that the high humidity can cause the blades to warp and not have the proper shape and angle to move the air. Metal blades would be the best for outdoors.
Make sure the fan is turning the correct direction to blow down.
Posted on Apr 28, 2010
  • Charles T Nevin
    Charles T Nevin Apr 28, 2010
    Yes, four inches is a little too close. Every inch you can get without being in danger of the blade hitting anyone will help. Every little bit will give you more air to pull.
  • Charles T Nevin
    Charles T Nevin Apr 29, 2010
    I think the extension will take care of your problem. Good luck.
Which way does a ceiling fan need to run in winter
Usually most peopledont want drafts on them in winter so making the fan turn with the edge thats turned down then that is the leading edge
IE say you look at the blade from the bottom
next note the blades are tilted you have to determine which way your blades are mounted. The fans may all be the same or some odd ones may be out there.
say looking up at a blade thTAs 12:00 from you
if the edge thats closer to the floor is on the left the fan turns left from 12:00 or Counter-clock wise to make the air blow toward the ceiling away from you. Reverse for cooling so the air blows on you.
This makes the air move upward.
If your ckoser edge is on the opposite side the fan turns opposite..
the edge thats turned down toward you is the direction of travel for winter
In small rooms with larger fan the air may make such a quick change that it feels like it blows on you in either direction.
Jan 15, 2012 | Hunter (25417) Ceiling Fan
Refrigerator portion on top does have cooling but freezer on bottom works fine. I have read that the cooling all happens in the bottom and a fan transfers cool air to the the top.
if the fridge part is cool and freezer is fine what problem are you having?is the fridge not cold enough? a common problem with bottom mount freezers is the freezer door doesn't get closed all the way,warm air enters the freezer mixes with the zero degree air and freezes up the air ducts,when you open the freezer door you should hear the fan blowing,if it is check the ceiling in the freezer to see if ice is on it,check the packages for frozen water droplets and stick your hand in the fridge where the air ducts are to see if you can feel cold air blowing into the fridge,if you can't feel air blowing into the fridge,unplug it,open the freezer door,remove the top basket and remove all the food out of the bottom basket,with a hair dryer blow into the back wall into the vent holes and melt out all the ice in the ducts,you'll see water dripping down through the vent holes,when the water stops dripping plug it back in and see if the fan is blowing the air into the fridge.also you can remove the bottom kickplate and you should see a tech sheet in it,read it and it will tell you how to put the machine into defrost,it will stay in defrost for like 20 minutes,you can do this instead of unplugging it, there's a heater that comes on behind the back panel in the freezer,this can help you melt out the ice but if it seems to hard to do just unplug it.
May 25, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Stops blowing air
remove cover at ceiling so you can see in at fins and see if they are frosting up bad. If they are, I suspect during AC installation, they didn't open up ducts on discharge properly and air flow is restricted, which will cause freeze up, especially if low flow from discharge ducts. I'm assuming it is a ducted system. You may have to remove or drop down entire ceiling assy, to see if the ducts into ceiling have any blockage. Sometimes they don't cut rubber roof material back far enough, or misaligned ducts and cause restricted flow to ceiling vents, which will cause unit to frost up, which kicks out compressor until frost is melted, then compressor kicks back in and cooling happens again.
Apr 06, 2010 | Dometic Rooftop RV Air Conditioner
Ceiling fan does not blow air
I would guess that the blades are on upside down. Ceiling fans are not supposed to work the same as desk fans though. The idea is not to create a strong flow of air but to create a "cooling breeze" by speeding the convection currents. They work better when they are running slowly (like you see in the old movies)
Sep 19, 2009 | Hampton Bay 24002 Ceiling Fan
Wont blow cold air
First check and clean the filters, and the evaporator coil. (thats the "inside" coil that has the indoor air sucked through it, cooling it and then pushing it out the vents.
If the filter is clogged or the coils are dirty, it will not cool properly and potentially freeze up.
Also check the condensor (outdoor) coil, if it is dirty/clogged, it will run hot and not cool properly.
If all coils and filters are clean, and the fan motors are running and in good condition and it is still not cooling then you are likely low on refridgerant. (handling/purchasing refridgerant other than R134A requres a CFC certification by law)
Aug 20, 2009 | Heating & Cooling
PROBLEM WITH MY AIR CONDITIONER
Is the outside unit running? if so can you feel warmer than outside air blowing from outside fan? If not your system may have a leak and pressures low. You can also check the piping to and from the unit larger one should be cold small one should be warm
Jul 03, 2009 | Whirlwind FH-778 Air Conditioner
Home Air Condition cooling problem
Hello. If your outdoor coils are dirty it's a good chance the indoor coils are dirty also. Clean the indoor coils and flush out the condensate line.
I know it's tempting to feel the air and try to decide if the unit is working properly but, you need to use a thermometer and while the unit is running check the temperature at the return air vent and then check the temperature at the supply vent closest to the unit. Remember to let the thermometer set for about 5 minutes before reading.
You should be looking for about 15 degrees F cooling between the return and supply.
If your coils are clean make sure the outdoor fan is operating properly. The air coming out of the outdoor fan should feel warm, almost hot. If not you may need to check your pressures. Good luck and let me know what you find.
Feb 03, 2009 | Ruud Central System Air Conditioner
Fan not blowing air.
theres a small toggle switch on the fan
that switch is to change direction on the way the fan is blowing
one direction for downward blowing
the other direction is for upward blowing
depends on the area you have to determine which is the best, but i doubt area restriction will hamper force air blowing, air will flow regardless, the area might be big so you dont feel it.
as being living in the attic, HOT AIR rises, so you might want to invest in some installation for the ceiling, because whent he sun hit the roof, it will create an oven effect, in your living area. the hot air is always present, you should have a ventilation fan blowing the hot air out, like thru a small window, the more hot air you blow out, the better.
not sure if this make sense. not sure how big the room is, as FANs are NOISY by nature.
Aug 16, 2008 | Hampton Bay 24002 Ceiling Fan
Temp
Before an evaporation cooler will feel "cool" there has to be a greater difference in the outdoor and indoor temps and/or humidity. If the humidity is high and the temp cool < 80'f The "cool" wont feel cool because there is not much evaporation taking place.
Now if the temp goes to 90 or the humidity goes down under say 40% the cooling effect "feeling cool" will change and be more like its cooling. Part because of the difference in the temperature but also because the air can hold more humidity and it is pulling moisture off your skin.
When you talk about "feel" it is rather suggestive and always different for different people.
Aug 04, 2008 | Mastercool 67680 Evaporative Cooler Air...
Hunter ceiling fan remote doesn't work
counterclockwise for cooling. This blows air down. The electronics board maybe burned out. There is a small fuse and capacitor in the fan. You can buy parts for this fan. http://www.eceilingfans.com/
Jun 27, 2007 | Hampton Bay 04314 Ceiling Fan
Westinghouse 78092 Verandah Breeze Ceiling Fan Logo
509 people viewed this question
Top Westinghouse Dryers Experts
Pranavendra Pranav
Pranavendra Pranav
Level 1 Expert
Paul Bade
john h
Are you a Westinghouse Dryer Expert? Answer questions, earn points and help others
