Question about Vector 2M Pwr Rch Spotlight
Can I buy replacement bulb assem??? - Vector 2M Pwr Rch Spotlight
  • 973 Answers
You can purchase on from Black and Decker, they purchased Vector in 2006 and service all their products, here is the link http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Posted on Jun 17, 2010
Replacing headlight bulb on 2003 cavalier.
If you can reach it and remove the bulb, then yes. Otherwise, you will have to remove the assemly to get the bulb out.
Jan 24, 2013 | Cars & Trucks
HI ! I HAVE A 1997 BUICK LA SABRE, WITH A BURNED OUT BRAKE LAMP BULB. AS FAR AS I CAN SEE , YOU HAVE TO REMOVE THE WHOLE ASSEM. ACROSS THE TRUNK TO GET AT IT. I HAVE REMOVED ALL 8 NUTS HOLDING THE ASSEM....
hello! Yes there is...Install a couple nuts onto the mounting bolts...Using a block of wood tap them with a hammer to break the sealant free...There is nothing holding it other than sealant..
Guru...Saailer
Jan 14, 2011 | 1997 Buick LeSabre
How to replace tailights on a 1997 toyota camry
pull carpet back remove 2 nuts holding assem,flat handed smack the assem towards rear of car then just turn bulb housings counter clockwise and remove bulb hope this helps please rate
May 07, 2010 | 1997 Toyota Camry
How to replace rear turn signal light bulb. how do you remove the rear tail light cover so as to remove the bulb on 2006 Ford Explorer XLT
I just changed my rear turn signal. Really easy. There is two 1/4 inch bolts visible when you open the tailgate. Take both of those out and gently lift the light housing out towards the outside of the vehicle. There is two small clamps on the other side of the fixture that just slide right out when you pull on it. There you go
Feb 20, 2010 | 2006 Ford Explorer
How do i install a headlight bulb on a jeep cherokee 2002
open hood two bolts are holding headlight assem in remove bolts then pull straight out on assem there is a ball and socket fitting behind assem that is why you have to pull some
Jan 01, 2010 | 1987 Jeep Cherokee
Replace right front headlamp?
The headlamp assem. or the halogen headlight bulb? If the light is out, jus open the hood, reach down to behind the light assem., and unscrew the plactic ring holding in the bulb. Unplug the bulb from the socket assem. Before you replace the bulb, make sure to not touch the bulb with your fingers(body oil will cause the bulb to pop as soon as it cuts on) Use a thing latex or jersey glove. Plug bulb back in, and Presto! It's fixed.
Aug 29, 2009 | 1998 Ford Taurus
LEFT BRAKE LIGHT DOES WORK ,CHANGED BULB STILL NOT
check for 12v in left brake light circuit......if no power then bad brake light switch...if power then try another bulb
Aug 28, 2009 | 1999 GMC Jimmy
How to remove a 96 Volvo 960 wagon tail light assembly
there are 4 ten millimetr nuts holdin assemly to car remove trim to see them
Jul 21, 2009 | 1996 Volvo 960
I need to see the schematics for a yz 125 clutch plate assem and kick start assem
let me know what you need to do and i can help you i know everything about those bikes
Jul 14, 2009 | Yamaha YZ 125 Motorcycles
My 97 SE has a right hand turn light (not blinker) with a blown bulb. I cannot find a way to get to the globe.
you will have to take the bottom fairing panels off,quite esay to do ,only need a phillips screw driver,once you have those off you can see the whole light assemly,it is only held in by two light spring loaded clips,pop those off and the whole assemly will come out from the rear of the panel,change the globe,and reverse procedure to reassemle(check that it works first )before putting the panels back on
Jul 02, 2009 | 1999 Honda GL 1500 SE Gold Wing
Vector 2M Pwr Rch Spotlight Logo
77 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Barry_IA
Level 1 Expert
Jim London
Jim London
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
