I have an envelope somewhere in my Lexmark 5300 printer. Cant see itbut it will not print, of course. What can be done to makeit serviceable again. PLEASE
    Genius:
  • 3,422 Answers
HI,
Please give more details about your problem.
Waiting for your reply.
Posted on Mar 26, 2008
  • 19,396 Answers
Explain the problem in detail please, why the printer doesn't print?
  • Ginko
    Ginko Mar 26, 2008
    Does the printer print a blank page ? if so you have to change cartridge.
    If it has a red light the printer may be faulty.
    If it does not start at all the printer is faulty.
    Did you put new cartridges? old ones must have dried up.
    Please provide details
SOURCE:
How do I print envelope with address?
This has to be done through an application like Microsoft Word. For instance on Office 2007 you would select the Mailings tab then click on Envelopes to specify the address etc. In previous versions you would have had to click on the Tools menu then Letters and Mailings then Envelopes and Labels. Once you've got all the information you want printed on the envelope Place the envelope in the printer in the exact configuration shown on the printer. Should have a feed on the side, look for the envelope symbol. Print and you'll be good to go. (:
Dec 21, 2009 | Lexmark Optra S 2455 Laser Printer
How do i print envelopes
Hello!
Printing envelopes can depend on your computer and the program you're using as well as the printer.
Go into a program on your computer that let's you write and print documents (for instance Microsoft Word).
Look around for an "Envelopes" option. In MS Word, in the bar at the top, go to "Tools", "Letters and Mailings" then "Envelopes and Labels".
Enter the required addresses and look at the "Feed" window at the bottom right to see which direction to put the envelopes in the printer.
Now look for a slot somewhere on the front of the printer, or maybe a place on the top or back that has a picture of an envelope on it. If you don't see anything, refer to your documentation to see where the envelope slot is.
Once everything is in place, click the "Print" button in your software on your computer.
That's all there is to it! If you don't have MS Word, look around on your computer for another word processing program. Most computers come with a simple word processor at least.
Aug 08, 2009 | Lexmark X2500 All-In-One Printer
LEXMARK X1240 WON'T PRINT ENVELOPES
I was so pissed off that so many on the web had this same problem that I spent many hours trying to get it to work. I am sure that this is not how it is designed to work but my envelopes got printed.First I went under File, Print, Properties to Page Set-up for envelope #10. I also ********** print colour images in black and white which someone else had suggested- although it might not be necessary. I selected quick print but normal should probably work too. I then closed out these two windows. Then under tools, I selected Letters and Mailing, then envelopes and labels, typed in the addresses, went under options and changed the feed from automatic to default tray, which automatically changes the feed method to the 4th one out of 6 which wasn't what I wanted but ignore it. Check off face up. Putting the envelope into the printer was bizarre- it has to be inserted very far into the printer until only 2-3 inches of the envelope stick above the horizontal surface of the printer. It must be inserted into the middle of the paper holder, until it is just 2-3 inches sticking up, and then slide it all the way over to the right where the printer indicates the envelope should be- nice and straight against the right margin. Do not use the movable paper holders that they suggest you swing over to the right to hold your envelope- or printing won't occur for some odd reason. Press O.K. on envelopes and labels and then press print. Good luck- it worked for me.
Jun 01, 2009 | Office Equipment & Supplies
My lexmark will print page, business cards, labels, pics, etc. But it will not print envelopes. Looks, sounds, and acts like its printing. But when it spits out the envelope nothing is printed on it.
There must be an issue with the size of the envelope the printer is expecting. If you're using Microsoft Word, check under "Letters and Mailings" and then "Evevolopes and Labels" to check the size you have set the envelope to. Perhaps its also a setting in File and Page Setup or in the printers own settings under Control Panel and Printers. Sorry for not being of more help but if its not jamming or giving an error then its probably just set to the wrong envelope size.
May 17, 2009 | Lexmark X2600 InkJet Printer
Printing
Check on your color (not mono) ink levels. If they are low, this could cause this.
Technical info: On this printer, envelope text is printed in "composite black" which means we mix the colored inks to make black. This is done for envelopes and not letters because of the ink properties which resist water and smear. If one of the colors is low, you'll get something other than black.
Mar 24, 2009 | Lexmark Z53 Color InkJet Printer
Paper Jam inside the printer Lexmark 5470
Firstable, you need to remove these pieces of paper from your printer. It is possible just removing a part of the printer located in the back or the bottom of it. Then you need to know that if you want to print on an envelop, it's necessary to format the printing settings. Just go to printing format and choose envelop
and also the dimensions of the envelop you want to print, then after this it'll be simple.
Dec 19, 2008 | Lexmark X5470 All-In-One InkJet Printer
Owners manual for kodak 5300 printer
Download and install Adobe Reader, if you do not have it.
Use the Get Adobe Reader button at this link
http://www.adobe.com
I am assuming you made a typo as many of us do and the title is correct and this is a Kodak 5300 All-In-One printer please respond if it is not and I will search for the correct printer.
Your printer's manuals and software can be found here
http://www.kodak.com/global/en/service/products/ekn033540.jhtml?pq-path=9104
As I do not know your operating system or version of MSWord, the following are hints about how this is done and may not be step-by-step accurate for you
http://safari.oreilly.com/0201741474/ch08lev1sec5
http://www2.essex.ac.uk/cs/documentation/use/word6/howto/env-lab.html
Dec 23, 2007 | Office Equipment & Supplies
Open Questions:
how to reset aol password @{18OO~8O31O69} There are two circumstances that can cause someone to want to change his/her AOL password: 1 forgetting the AOL password and needing to recover it and 2 to change the AOL password. The latter can be because the AOL password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's AOL password at least once in a month. Contact Aol Mail Password Reset. For your convenience to contact Aol Mail Password Reset We have provided all possible information of Aol Mail Password Reset. You can contact Aol Mail Password Reset on the given phone number 1-8OO-8O3-IO69. Changing an AOL Password The following steps show in detail how to change an AOL password when the current password is known: Sign into the AOL Mail Account from AOL Do you want to recover/reset your AOL email password? So you'll be do the some steps to recover your AOL password. We'll help you to fix your problem and we'll guiding the some steps to recover your AOL password. Follow and do the below steps to recover your AOL email password- Go to the AOL - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your AOL mail message on your Gmail account. AOL is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While AOL's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, AOL has made it easy to recover or reset your account's password. *Please Read* If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your AOL password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your AOL password.
Oct 21, 2019 | AOL Computers & Internet
Computers & Internet Logo
Ekse
Alun Cox
