Question about Maxtor Hard Drive
Maxtor diamondmax plus 9 6y080l0
Bios does not recognize my hard drive correctly, only recognizes the family (calypso).
it tries to boot but hangs in boot mode then it says slave hdd error,and carries on booting but only using primary, think the firmware is corrupted. can anyone help me found the firmware but not sure how to get it to the hard drive and reprogram please help thanks .
  • GUNITJEAN Apr 07, 2008
    when i turn my computer doen't want to start at all with the Maxtor hard drive , it keep telling me error
  • ineedhelpplz Apr 09, 2008
    thanks for the heads up, but the pc has been running fine for bout 3 years with no probs then 1 morn woke up and it was like this, does any1 no how to reprogramme the firmware.
  • 236 Answers
If you have you primary HDD set on Cable select, and the secondary HDD is set on anything other then Cable select (with the jumper settings on the back of the HDD) then there will be an error.. Also, if you primary is set to master/slave and the same for the secondary, it will cause problems.
Another thought, if one of your drives is SATA and the other IDE, if the IDE is set to master, there may be an issue as SATA HDD's will try to post as the master drive
Posted on Apr 09, 2008
  • 2 more comments
  • Dave MacPhee
    Dave MacPhee Apr 09, 2008
    ** I should expand that second statement.. If the primary drive is set to MASTER, and the secondary is set to MASTER, there will be problems.. Same if they are both set to SLAVE
  • Dave MacPhee
    it is possible that the disk has gone bad..
    I would recommend downloading Seatools iso image and create a boot cd. It will run various diagnostics on your drive. Perhaps it can shed some light into this problem///
  • Dave MacPhee
    If you prefer, here is an EXE File of Seagate diags for floppy disk use
  • Dave MacPhee
    Dave MacPhee Apr 10, 2008
    Well, I have found a like to your firmware.. But in order to repair it, you need to get special hardware/software.. The only other solution is to take it to a recovery place...
Romulus Name for Maxtro D540X
U can do one thing , convert your HDD using ide to usb or sata to usb converter and connect ur HDD via usb and check what happens....
Dec 26, 2013 | Maxtor DiamondMax D540X 40 GB Hard Drive
11S09N0848ZJ1BLDP019YA
what problem, it is not shinny any more? LOL?
do say. please.
I am clueless, so far due to?
what system? PC, MAC,DVR,ext, TV, moon rocket.(LOL)
what OS?
using it as an internal drive, 2nd drive, or external.?
boot drive?
Seagate bought out MAXTOR.
that number must be a bar code, its not the product number
eg:
so tell me what it is.
as time passes, maxtor, fades to dark at SeaGate.
but this deep search nets, this, (hidden well)
http://www.seagate.com/gb/en/search/?keyword=maxtor
ive been using MAXTOR since day 1.
decodes for Maxtor :
Maxtor
xayb0
xa = drive family
- 6Y = DiamondMax(DM) Plus 9
- 6B = DM10
- 6L = DM10 RoHS compliant version
- 6H = DM11
- 7B = MaxLine(ML)III
- 7L = MLIII RoHS compliant
- 7H = ML Pro
- 4R = DM16
- 2F = Fireball 3
- 6E = DM Plus 8
- 5A = ML II
- 7Y = ML Plus II
y = the capacity of the disk, in gigabytes. Drives less than 100GB will have a leading zero (80GB is denoted as 080, etc)
b = buffer size and interface
- J = 2MB PATA with ball-bearing motor
- L = 2MB PATA with fluid dynamic bearing (FDB) motor
- P = 8MB PATA
- R = 16MB PATA
- M = 8MB SATA
- S = 16MB SATA
- F = 16MB SATA 3gbps
All Maxtor SKUs have a zero at the end. It may have a value, but I'm not aware of one.
Example: A Maxtor drive with a model number of 6Y200P0 is a 200GB 7200RPM PATA drive with an 8MB buffer from the DiamondMax Plus 9 family.
now my generic answer: for all HDD. A+ training....(instructor)
1: i make sure it has +5v and 12vdc power, if not all is hopeless.
2: IF PATA/SATA , i listen to the drive case with my ear.
whirrrrrrrrrrrrrr, no whirrrrrrr ,? its DOA.
if it spins its good. if not its 100% DEAD, (RIP)
3: do the gyro test, (if it fights you, as you change it's direction, then it is spinning) Drive in HAND. (whole deal)
4: does BIOS see it? (MOBO BIOS) hot key hit. RTM on MOBO.
yes, good.
no , DEAD. try another power cord to drive or data cable.
try different data ports. on MOBO.
5: try it on 1 PC, with step 4 and 5
6: if BIOS sees it ,so should WINDOWS. (may)
in the device manager.
and in disk manager. (off computer management CPL)
both. set the drive latter in the latter or it will be hidden.
keep in mind BIOS never tests a drive. it only asks it for
its NAME (PNP) PNP just identiifes the maker and type drive. and its spec. and 1 more tests. it shows the drive is NOT BUSY.
these facts ,help all techs, make good trouble shooting.
Sep 24, 2013 | Maxtor Hard Drive
I have a quantum fireball lct20 40gb hard drive that I am attempting to install as a slave drive in a Dell Dimension 2400 desktop, and while it works in other computers, I keep getting the BIOS detection...
Maxtor CrystalMax 1080
Maxtor Fireball 531DX Ultra ATA 100
Maxtor DiamondMax 16
Maxtor DiamondMax 1750 Ultra ATA 33
Maxtor DiamondMax 1750A Ultra ATA
Maxtor DiamondMax 17 VL Ultra ATA 66
Maxtor DiamondMax 20 VL Ultra ATA 66
Maxtor DiamondMax 2160 Ultra ATA
Maxtor DiamondMax 2880 Ultra ATA
Maxtor DiamondMax 30 VL Ultra ATA 100
Maxtor DiamondMax 30 VL Ultra ATA 66
Maxtor DiamondMax 3400 Ultra ATA
Maxtor DiamondMax 36 ATA 66
Maxtor DiamondMax 40 ATA 66
Maxtor DiamondMax 40 VL Ultra ATA 100
Maxtor DiamondMax 4320 Ultra ATA
Maxtor DiamondMax 536DX
Maxtor DiamondMax 60 ATA 100
Maxtor DiamondMax 60 ATA 66
Maxtor DiamondMax 6800 Ultra ATA
Maxtor DiamondMax 80 ATA 100
Maxtor DiamondMax D540X-4D
Maxtor DiamondMax D540X-4G
Maxtor DiamondMax Plus 2500 Ultra ATA
Maxtor DiamondMax Plus 40 Ultra ATA 100
Maxtor DiamondMax Plus 40 Ultra ATA 66
Maxtor DiamondMax Plus 45 Ultra ATA 100
Maxtor DiamondMax Plus 5120 Ultra ATA 33
Maxtor DiamondMax Plus 5120 Ultra ATA 66
Maxtor DiamondMax Plus 60 Ultra ATA 100
Maxtor DiamondMax Plus 6800 Ultra ATA 66
Maxtor DiamondMax Ultra ATA
Maxtor DiamondMax Plus 8
Maxtor DiamondMax D540X_4K
Maxtor DiamondMax D540X_4L
Maxtor DiamondMax D740X
Maxtor Fireball 541DX
Maxtor Fireball LCT20
Quantum Fireball CR
Quantum Fireball CX
Quantum Fireball EL
Quantum Fireball EX
Quantum Fireball LCT08
Quantum Fireball LCT10
Quantum Fireball LCT15
Quantum Fireball Plus KA
Quantum Fireball Plus KX
Quantum Fireball SE
Quantum Fireball ST
Quantum Fireball LM
Quantum Fireball AS
Maxtor DiamondMax Plus 9
Maxtor DiamondMax 10
Maxtor DiamondMax 11
Feb 22, 2010 | Quantum Fireball Lct20 40 GB ATA-100 Hard...
Maxtor DiamondMax Plus 45 7200 RPM 30.7 GB HDD suddenly makes clicking sound when started and will not be recognized by Win XP OS. The drive had been working flawlessly. Any suggestions?
Clicking sounds is an indication that the platters have a bad device internally. Once that happens the hard drive is no good, run the serial# on Maxtors website to see if its still under warranty, gd lk
E
Aug 01, 2009 | Maxtor DiamondMax Plus 45 (53073H4) 30.7...
DiamondMax 21 80-GB ATA/100 Hard Drive didn't get recognized as 1st drive or 2,3. do i need any software.
Use a partition manager to see if the drive is recognized. If it is not recognized, you may not have the jumper setting correct. If it is a master drive, set the jumper for master drive. same for slave or cable select
May 05, 2009 | Maxtor Fireball 541DX (2B020H1) 20 GB Hard...
Hard drive spins up but windows does not see it
Depending on your PC make model and BIOS it may not auto recognize the second drive, check those settings. and or it might not support the drive size, in which case look for a BIOS update for your system. You also might want to use "cable select" on the switches even though you set it to slave it may not like that.
Apr 24, 2009 | Maxtor DiamondMax Plus 8 40GB 7200rpm...
IDE AND SATA CONTROLLER PROBLEMS ON MAXTOR DRIVES.UNINSTALL CONTROLLERS AND REBOOT,DO NOT PLUG IDE DRIVE IN.THEN REBOOT AGAIN PLUG IDE DRIVE AND LOOK IN DEVICE MANAGER IF DRIVE IS RECOCNIZED CORRECTLY.(ASUS BOARD) OR INTEL CHIPSET PROBLEMS.
May 20, 2008 | Computers & Internet
Maxtor 120GB Hard Drive
Is that external???
Mar 24, 2008 | Maxtor Hard Drive
Mon PC ne reconnait plus mon disque dur
I have a maxtor 40gb DiamondMax Plus 8, and suddenly, my computer only recognizes over my hard drive. I work on XP, but the hard drive is in my computer for at mons three years. Not a problem before. It is partitioned. Can I chdisk from DOS, or else. Thanks for your help.
Dacha
That is what you wrote: Check in menagment console if you found there.If not check IDE CABLE if it is put in corectlly and check electricity!
Jan 05, 2008 | Maxtor Hard Drive
Maxtor Hard Drive Logo
467 people viewed this question
Top Maxtor Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Rick Arnold
Mark Taylor
Mark Taylor
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
