Question about Fujitsu Siemens LifeBook C1020 Notebook
I'm trying to replace the power in socket on a Fujitsu Siemens Lifebook C1020 but having problems taking apart. As I look at the screen, I cannot get the bottom off on the left hand side. There are no screws that I can see, it seems as if it's glued. Cannot find disassembly instructions anywhere. Can anybody help please.
  • Clive Gray Apr 28, 2010
    Thanks small6363, that might be the answer if the hard drive was at the back corner.
    There may be a screw somewhere but I'm blowed if I can find it.
3 Suggested Answers
  • 83 Answers
SOURCE: disassemble fujitsu siemens lifebook c1020 to replace motherboard
try downloading a maintenance manual.
they are quite helpful.
Posted on Jan 04, 2010
peeface
  • 180 Answers
SOURCE: replace the power in socket on lifebook c1020
i took apart a dell and was having the same problem. on mine it turned out to be double sided tape and it pulled right apart. but you should check, check and recheck for screws before you just yank it apart
Posted on Apr 28, 2010
Testimonial: "Hi peeface, thanks There are areas stuck with double sided tape you can hear tear but not in this corner I'm afraid. Hinge post seems stuck."
How do I restore the built in keyboard on my Fujitsu Lifebook C 1020
You need to take apart the laptop to do this.
Why not simply attach a portable USB keyboard which will work just as well?
Oct 04, 2014 | Fujitsu Siemens LifeBook C1020 Notebook
Replace the power in socket on lifebook c1020
Apr 28, 2010 | Fujitsu Lifebook C1020 Notebook
Fujitsu Siemens Lifebook C1020 laptop display and booting problem
change the ram memory ...this issues appear when the ram memory is not functional like it should..if you have a way to borrow some just to try ..you will make an ideea
If you have more than one boards in the laptop..remove one by one ..and try to boot with the other/s until you locate the one with problem..
Jan 30, 2010 | Fujitsu Siemens LifeBook C1020 Notebook
My laptop doesn't turn on and the red indicator of the battery
check the power settings and make sure that the battery and power cable settings are on when plugged in. Also sometimes a battery needs to be installed to do this. If the power adapter is working then all should be fine.
Aug 26, 2009 | Fujitsu Siemens LifeBook C1020 Notebook
My Fujitu Lifebook c1020 display is bad and needs swapping. I need a repair maual.
its pretty simple to change the screen on this computer, and you dont really need a service manual (i dont even think you will find one for that)
the way you do it is remove the rubber "dots" around the screen, there should be atleast 4.
when they are out, and you have removed the hidden screws, you can take of the frontbezel around the screen.
when the bezel is off you might need to loosen or remove 1 of the 2 screwes on each side at the bottom hinge.
the screen itself is fastened to the hinge with 2-4 screws on each side of the screen. remove them, take out the flat/wide cable on the backside, and disconnect it from the 5-6cm long printbord.
reverse the process when you put in the new screeen.
May 28, 2009 | Fujitsu Lifebook C1020 Notebook
Fujitsu LIFEBOOK C1020 power problem
or a bfoken powr jack.I replaced mine recently for £4.00 and took approx 2 hours.
Jun 16, 2008 | Fujitsu Lifebook C1020 Notebook
Fujitsu Siemens LifeBook C1020 Notebook Logo
135 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
