Question about Refrigerators
I have a mini fridge and it was leaking this bright green substance after I unplugged it for about 3 days, and then when I pluggedit back in, it started smelling really bad. I have know idea what's going on, please help.
  • 4,793 Answers
The bright green substance will have turned black fairly quickly as it is mould from the vent pipe,clean out with clorine bleach and dry before use to clear mould/smell.
Posted on Apr 28, 2010
Mini fridge doesn't get cold anymore
Is the unit running? If so then,
by shutting the unit down for a long period may have exposed a pinhole leak of refrigerant at an external brazing point. or you may have caused an issue in cleaning it This is something that would require a licensed technician to resolve.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 15, 2017 | Emerson Refrigerators
Refrigerator temp erratic
you will have to replace your thermostat of the fridge
you can find it near the light inside the unit
Sep 17, 2008 | Samsung RS2534 Side by Side Refrigerator
My Mini fridge Doesn't Get Cold, it's running, I've tried unplugging it for a day and then plugging it back in , still not getting cold..Looked at back and everything looks fine..Except..T
Replace the fridge compressor with another one, try a Google search and maybe you'll find result's for your specific fridge. If all else fails, then ring up your fridge manufacturer and talk to them about your fridge, and if you still have warranty and you complain hard enough, they might just send in a new compressor.
Dec 10, 2012 | Haier HSB03 Compact Refrigerator
Stench from back of fridge
Sounds like a regrigerant leak. Have it checked by an appliance tech.
May 26, 2012 | Siemens Bosch Neff Integrated Fridge...
I think my cooling unit is shot, but about the same time of my fridge going out I had what seemed like a water leak. It was in a closet no where near any water lines,but on the same side of the closet...
These RV fridges are filled with ammonia, sounds like your unit has a leak, You should remove your fridge and possibly get it repaired , refilled and tested, or find a used one, These units are a few $$$$.
Oct 12, 2010 | Dometic RM2652 Refrigerator
Something leaking from the vent inside the top of the refridgerator. It is a sticky substance with an orange color. Is it freon?
No, it sounds possibly like the glue that was used to seal the back of the fridge is leaking out. Maybe a defect, if your fridge is still under warranty, I'd call the seller to ask about what can be done from there. Freon is a gas.
Feb 08, 2010 | Refrigerators
Mini Danby Fridge Won't cool but compresser is running very HOT!(Model DCR412BLS) the fridge has just recently been moved into a warmer environment without air conditioning. As well, it had accumulated...
never turn a fridge up side down and when moving a fridge or freezer keep it upright as much as poss and dont plug back in for 24hrs.now leave it unplugged a buy new one...
Sep 14, 2009 | Danby DCR412 Compact Refrigerator
Leaking ink
Hello
Have a look at the link below, it should assist you in solving your problem.
Click HERE.
Kind regards
Michel
Oct 29, 2008 | Office Equipment & Supplies
The motor on my Sanyo Mini-Fridge goes out every 3 to 4 days. The previous surge protector it was plugged into shorted, and I think that may have something to do with it. What is wrong? It will work fine...
defective relay/overload combination if you replace them and it works, there's you problem, if you replace them and the problem continues, suspect a faulty compressor.
May 01, 2008 | Refrigerators
Fridge leaking oil on the bottom right side
OK, usually if you see an oily substance that you are sure is not from the fridge contents it's oil from the sealed system. When a leak in the sealed system happens the refrigerant gas leaks out and the lubricating oil also leaks out. I'm afraid you may be in this situation. As the refrigerant leaks out the cooling efficientcy drops off quickly and eventually there is no cooling at all. You would have to use a refrigerant leak detector "sniffer" to locate the leak and then have a certified company repair the unit. Sadly, the cost to do a compressor replacement and leak repair is 2/3's or more the cost of a new fridge...
Jan 15, 2007 | Frigidaire GLRS237ZA Side by Side...
Refrigerators Logo
131 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
