Question about Ricoh Office Equipment & Supplies
I have a RICHO Aficio CL1000N. I keep getting the code; "transfer rollers out of alignment". Where do I look for them and how do I go about aligning them ??? And also.....How can I get a service manual for this Copier ????
    President:
  • 1,194 Answers
Thanks for using Fixya
You can download the service manual from this link.
Posted on Apr 28, 2010
My Ricoh Aficio 3235c overlaps clolours when printng
With out seeing copy here is my thought either bad drum if it is streaks down copy or laser unit for yellow is out of alignment . In user tools there is a maintance tab go into it and do color alignment if it fails then could be transfer unit or laser unit for yellow will need to have a copier tech come out to fix it.
Oct 30, 2012 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
Need to reset maintenance count on a richo aficio AP410n laser printer ?
• After the technician replaces the fusing unit, the maintenance counter must be reset with engine SP mode 7-804. • 7-804-1: Transfer roller • 7-804-2: Paper feed roller • 7-804-3: Fusing unit).
Jul 27, 2010 | Ricoh Aficio AP410N Laser Printer
On a ricoh aficio CL1000N, what does the error code SC922 or SC992 mean?
There is no sc922 for the CL1000N, but sc992 is a general software error. It typically shouldn't interrupt operation, but it if it does and it happens more than once, try to figure out what you were doing when it happened. Were you printing a big job? Were you printing a job with a particular font? Does it always happen at a certain time of day? Narrowing down the conditions can help to figure what is causing the error code.
Jun 30, 2010 | Ricoh Aficio CL1000N Printer
Aficio CL1000N Printer: On my Ricoh aficio CL1000N it says add toner Cyan....
If I remember right, the CL1000 won't print if any of the 4 colors are out. You have to replace the cyan toner in order to print, even in black and white.
If you haven't tried already, you can try taking the cyan toner out and shaking it up (just a little bit) to try to get the printer to find the little bit of toner left in the bottle.
May 16, 2010 | Ricoh Aficio CL1000N Printer
What is meant by error code SC 403 of RICHO AFICIO 2035E
SC 403 is a Transfer belt position sensor error
The transfer belt position sensor does
not activate even if the transfer belt
contact clutch has been switched on
twice and rotated once. Pls check if
Main motor/drive, Transfer belt contact clutch if defective, Transfer belt position sensor
if defective. or your Photo sonductor drum/PCU carriage unit does not turn or stock up or not inserted properly.
Jan 20, 2010 | Ricoh Aficio 2035 Copier
Ricoh Aficio CL800 - Set Transfer Roller
possible transfer roller rotation sensor dirty or damaged transfer roller. check -- open rear door and see how the roller looks.
Apr 10, 2009 | Ricoh Aficio CL1000N Printer
Richo Aficio 2015 I have a richo 2015 machine which has a reading of 1,08,700(number of print out taken)but lately the paper gets folded inside just above the drum. The matter does get printed on the paper...
The pressure roller is inside the fuser section of the copier. If there is a flat spot on the roller, you will get those results. It's better to rebuild the whole fuser unit including the bearings and heat roller. That will stop that jamming from happening.
Jan 26, 2009 | Ricoh Aficio 2015 Copier
Paper coming out from the tray is folded for richo 2015
You do have a fuser problem. There are a set of stripper fingers that are supposed to keep the paper from wrapping around the heat roller. One of them may be damaged and is catching the paper. The Pressure roller can also cause problems if it is torn. You need to have the fuser looked at by a tecnician to determine the problem. Hope this helps.
SC 441 Error code
Transfer belt cleaning unit.
open top cover, cleaning unit cover(2 black tabs rear)
pull unit slowly. check if paper jam or gears not turning
Dec 24, 2008 | Ricoh CL1000N Laser Printer
24 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
