Question about Roper REX4634KQ Electric Dryer
The dryer does not circulate
The dryer does not go round and round
    President:
  • 1,430 Answers
The problem is likely the dryer belt . Go to www.appliancehelponline.com/servicemanual.html there is a video that will show you how to replace it. It may be a different model but the process will be the same. You can also enter in your model # for diagrams and illustrations. Not all models are available. All parts come with installation instructions.
Posted on Apr 28, 2010
Drum goes round, only cold air circulating and no heat to dry washing, machine is constantly bleeping and signalling end of drying cycle
If you pull the panels off you should find the tech sheet to help diagnose your machine. But in you case sounds like it need to be taken apart and cleaned and check the limit switches.
Jan 15, 2014 | AEG T58840 Dryer Electric
I bought my dryer in May and it has never completely dried my clothes. I especially have trouble with towels and heavy knits. What could the problem be?
Did you have the same Issue with your old dryer?? Check for a kink in your exhaust hose from dryer,if OK start dryer and go to exhaust vent outside and check air flow at vent ,you should have a good amount of warm air coming out.if not you have a restriction in the duct,that will have to be cleaned out.You need good air circulation to dry clothing not just heat the air circulation helps remove the moisture from the clothes hopefully this will help with your concern
Aug 12, 2010 | Maytag Dryers
Vornado Circulating Fan - motor will run but blades will not turn.
Does the motor spin, but the blade is not turning?
The motor has a D shaped shaft. If the hole in the blade that the shaft goes in is rounded, then the blade will spin. In that case you need a new blade. Vornado can supply that.
Jun 27, 2010 | Vornado Circulating Fan
Dryer making a thumping noise, heating okay, drum is going round. could drum be out of round and thumping on the rollers
the roller is out of round instead for the internal bearing has dried up and locked tight making the belt to burn the nylon roller flat in the spot the belt rides on. It will be neccessary to replace the belt and the roller as well
Feb 20, 2010 | LG DLE2532W Electric Dryer
Haier HLP140E Electric 110V dryer exhaust filter.
I have had this dryer for 4+ years and finally have used the "floor vent" filters that come 12" x 4" and cut two of them to fit. It's a pain because unlike the round design they can "fall out" when you snap the filter back in. Be that as it may, they work well because you cannot buy the black round wool filter anywhere.
Jan 03, 2010 | Haier HLP140E Electric Portable Dryer
Creda t522vw has topped spinning but still
Could be the belt has failed, you need to remove tho top cover, and check to see if the drive belt is intact, grasp the belt and see if it is o/k.
Another way to check is turn the drum from inside and it should go round., if not, then it is probably the belt.
Hope this helps.
Dec 06, 2009 | Dryers
No air circulation
check the blower fan....the center of the fan that rides on the motor shaft can wear out, (get rounded out) and stop turning.
hope this helps..........................jay
Mar 21, 2009 | Dryers
No circulating heat
Hello mojack448, check the vent, its plugged ether in the lint catch filter or the exchaust duck work. Merry Christmas.
Nov 13, 2008 | Magic Chef CYE4000AWW Electric Dryer
My WVF 2402 washer/dryer washes clothes ok but doesn't dry them.
Sorry I'm way late with this but I've only just noticed it. Unplug the machine from the mains! Remove the lid (with a torx screwdriver) and you'll notice a small circular device with 2 leads attached on the top of the machine, in the centre there's a small button, press it and it should click......you've fixed it This is a thermal cutout safety device designed to switch the drying heater off if it becomes too hot. The probable cause for this is that you've over filled the machine and the air didn't circulate freely. as a rule of thumb, dry 1/2 as many clothes as you wash.
Mar 23, 2008 | Bosch Classixx WVF 2402 Front Load...
Laundry taking too long to dry!
1. Make sure the filter is clean. A clean filter allows for proper air circulation in the dryer.
2. Make sure the rear dryer vent is clean. Move the dryer, unplug it and remove the rear vent hose and clean out any debris from the vent, in the hose and any debris in the outside vent.
Over time, these things get clogged and reduces the air circulation in the dryer, causing it to take longer for the clothes to dry.
Please let me know if I can be of further assistance to you.
- Jim
Feb 14, 2008 | Dryers
Roper REX4634KQ Electric Dryer Logo
73 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
