Question about Candy Washing Machines
Where can i find a filter in candy eclypsa alice ce 10,
Where can i find a filter in candy elypsa ce 10, turned around it and didnt find it
5 Suggested Answers
SOURCE: my candy eclypsa CE1400 the
I need a operation manual for Candy Eclyps CG544T, please send me .
Posted on Oct 11, 2008
  • 867 Answers
SOURCE: Candy Eclypsa CE124/1 drum does
It sounds like the motor brushes have failed. Quite a common fault and not too complicated to fix.
Posted on Oct 25, 2010
  • 6277 Answers
SOURCE: i whant candy eclypsa ce
I'm so sorry but this forum is not able, nor in a position, to supply any type of manual, parts list, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained probably over many years.
Manual
You will need to type into your search engine/web browser '(make model number) washer sevice manual' and you MAY be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct but they often supply only to registered agents ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Aug 18, 2011
  • 6277 Answers
SOURCE: i need to know how
Unfortunately FixYa cannot provide that direct - members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
John C.
Posted on Sep 06, 2011
My washing machine motor not rotating in washing cycle. Motor works well in Spinning cycles, but not working agitatewashing movement in any cycle. It's water filling, stopping and draining all works
Would help to have the model and type...but typically if the tub is not agitating the coupling between the motor and the tub is worn out or broken. However, if it is spinning properly, it probably indicates a problem with the transmission. Really need to know what type of washer it is to help pin down the problem. Any "burnt" smells coming from the washer? Give a little more information and maybe we can figure it out. Top load...side load, make and model preferred. You can locate that information on a plate usually attached inside the door on most models.
Apr 17, 2016 | Candy Washing Machines
Do u have ce 439 t candy washing mashin parts?
Ask Candy after sales or go to espare.
Jun 26, 2015 | Candy Washing Machines
Candy eclypsa ce104
it will need replacing the valve is at the top right on the rear
Jan 12, 2014 | Candy Washing Machines
I whant candy eclypsa ce 439t timer meeter diagram
Manual
John C.
Aug 18, 2011 | Candy CN126 Front Load Washer
Hi my candy eclypsa washing machin cj534. ihave heater element in rear side but icant dryer after washing please can you expline me how to oparate and make dryer thank you your customer
I think a manual would help you ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C.
Mar 20, 2011 | Washing Machines
Candy Eclypsa CE124/1 drum does not move on any cycle, even spin cycle.
Oct 25, 2010 | Washing Machines
Washer Dryer overfills and pours out through front door
The pressure switch tube is only about 5mm in diameter so is easy to find, to be certain it is not blocked you need to remove it and check to see it is clear, and that the lower end where it is fixed is also clear, also make sure it is not punctured as this will result in loss of air pressure and stop the switch from working..
I assume it stops filling when you turn m/c off.
If it does not then you have a sticking water inlet valve.
plz rate my solution. Thanks.
Dec 17, 2008 | Candy CNW156 Front Load Washer / Dryer
Buttons on CE124 candy eclypsa not working
the on/off switch sounds faulty they can get hot and jam, with the button stuck in you cant open the door, the switch will have to be replaced
Jan 18, 2007 | Candy CN126 Front Load Washer
Candy CN146
0I have a candy intergraded washine machine ,could you tell me where the filter is please as the wash finish but still has water in, I put the cycle on to the water discharge and it emptys,then i put it onto a spin which works fine. But i need to know the problem
Nov 01, 2006 | Candy CN146 Front Load Washer
Washing Machines Logo
231 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
