Question about Porter Cable 3 1/4 Hp Plunge Router
Replacing 1/2" chuck with 1/4" chuck. How do you lock the motor down to complete the process?
  • 623 Answers
There should be a button somewhere on the machine to lock the shaft.
Posted on Apr 30, 2010
Removing keyless chuck on Metabo power drill
Simple way to remove a chuck. First - REMOVE THE BATTERY FROM THE DRILL
Second of all if you can open the chuck all the way that is good. You have to remove the left hand thread screw that holds the chuck on. It will be a slotted head. Remember it is left hand so to remove it you have to turn it like you were tightening a regular screw.
After the screw is completely removed you should take a 1/2" or 10mm allen key and tighten it in the chuck. Lay the tool down on a surface where you can hold it securely or tighten the tool in a vice so it will not move. The spindle should lock so you can use a piece of pipe to unscrew it (regular thread) or if the spindle doesn't lock you can lay the drill down so that you can "whack" the allen key with the side of a heavy hammer. You might have to hit it several times to get it off.
I have done this many times and have never damaged a drill.
Feb 15, 2011 | Makita Drills
I have a dc 759 it has a plastic cover over the keyless chuck ....it is stripped out.....can i just replace the plastic cover? .... if so how and where can i get one
If the drill is not too old, I would take it to your nearest factory dewalt repair shop. they have a good warranty on their items. If it is older you probably need to replace the chuck itself. You need to remove the plastic to get the chuck open and then there is a screw down inside the chuck that needs removed. The chuck should come right off and just reverse the process to install the new one.
Nov 12, 2010 | Dewalt DC988kar XRP 3 - speed 1/2" 18v...
Replacing gears
you have to disassemble the tool completely. Remove chuck, remove battery, remove all screws holding body parts together, remove one side of body. Now you can see motor and gear box. Pull out both of them and twist gearbox a bit (just few degrees or millimeters) if it goes, then just pull gear away from the motor. Be carefull, some gear parts may drop of, so hold gearbox down and motor up. Juraj
Jun 04, 2010 | Makita 18V 1/2"CRDLS Drill Kit
Need to change chuck
When you buy a replacement chuck it will have detailed instructions- at least Jacob's brand chucks do. Basically there is a retaining screw inside the chuck that needs to come out first- it may be left-hand threads . Then you put the short end of a 1/4" or larger allen wrench in the chuck and close it tightly. Set the drill on a bench with the chuck off of the bench and strike the allen wrench with a mallet in a counterclockwise direction. Do this several times, then you'll be able to spin the chuck off by hand. Reverse the process to install the new chuck.
Apr 13, 2010 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
07,010,43:49314 system error
Here is the solution for your problem.
7,010.43: The printhead is stuck in the tilted position, or is not tilting properly over the CAM, due to problems with the process motor gearbox.
1. Reboot the system.
2. Did this correct the problem?
Go to Step 2. Complete.
2 1. Do the printhead lock arms rotate correctly? Go to Step 3. Repair or replace the lock arms.
3 1. Is there spilled ink around the printhead? Clean the print-head area.
Go to Step 4.
4 1.
Check the process gearbox for obstructions
or damaged.
4.2. Ensure the gears are correctly aligned and homed.
4.3. Verify the process shaft and drive module
shaft are at their home positions.
4.4. Did this correct the problem?
Complete. Go to Step 5.
5 1. Verify the headtilt gear will engage. You can
manually set the headtilt gear.
5.2. Is the gear engaged properly?
Go to Step 6. Set the head tilt gear.
6 1. Use service diagnostics to run the Tilt Axis
Drive
test.
6.2. Did the test fail?
Replace the process gearbox.
Go to Step 7.
7 1. Use service diagnostics to run the Process
Motor
test.
7.2. Did the test fail?Replace the process motor.
Go to Step 8.
8 1. Use service diagnostics to run the Head
Maintenance Wiper Clutch
test.
8.2. Did the test fail?Replace the wiper drive clutch.
Go to Step 9.
9 1. Ensure the wiper is properly aligned.
9.2. Use service diagnostics to run the Wiper
Drive
Test.
3. Did the test fail?
Go to Step 10. Replace the exit module assembly.
10 1. Use service diagnostics to run the Load
Maintenance Clutch
test.
10.2. Did the test fail?Inspect the maintenance drive system, replace any defective
parts.
Hope this helps and rate your response.
Thanks, SF
Feb 18, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
How to remove bit retainer or chuck from drill
Grasp the chuck and twist the sleeve counter clockwise and pull up.It will come off. To replace the chuck slide it back onto the drill shaft, grasp the chuck collar, twist it counter clockwise and push down on it, it will slid back onto the shaft and lock into place.
Nov 20, 2009 | Bosch 11222EVS 1 1/8" Sds Plus Rotary...
Chuck is locked in open position
What you can try is some WD 40 spray into the chuck and then find a GOOD pair of gloves or a rag and hold the collar of the chuck either by hand or use the rag and a pair of channel locks to protect it and then use the tool motor slowly and see if that doesn't release it
May 25, 2009 | Craftsman 14.4 volt Cordless Drill/Driver...
Xerox C2424 Error: 07.010.44:152562
Hi design811:
Here is your problem.
replace the lock
arms.
printhead area.
Go to Step 4.
4 1.
or damaged.
homed.
Go to Step 6. Set the headtilt
gear.
Drive
test.
Replace the
process
gearbox.
Go to Step 7.
Motor
test.
Replace the
process motor.
Go to Step 8.
test.
Replace the
wiper drive
clutch.
Go to Step 9.
Drive
Test.
exit module
assembly.
Maintenance Clutch
test.
parts.
Hope this helps
May 21, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Error code 07,010,43:13829 xerox c2424
Hi sales1stsupp:
replace the lock
arms.
printhead area.
Go to Step 4.
or damaged.
homed.
gear.
Drive
test.
Replace the
process
gearbox.
Go to Step 7.
Motor
test.
Replace the
process motor.
Go to Step 8.
test.
Replace the
wiper drive
clutch.
Go to Step 9.
Drive
Test.
exit module
assembly.
Maintenance Clutch
test.
parts
Hope this helps
Apr 22, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Removing the dewalt DC925 'rohm' chuck
I have a DC927 and a DC926 that I removed 1/2" Rohm Supra SK key-less chucks on. This process is pretty simple. Put the drill motor in 1st gear. Put the clutch ring in drill mode and not in driver or hammer. Reverse or open the chuck all the way. Hold the chuck firmly in a vise and give the drill a good POP counter clockwise. The last step can also be done with a pipe wrench by placing the drill on a work bench and turning the chuck counter clockwise. Continue to un-thread until the chuck is removed. The replacement chuck must have the same mounting process and mechanism. Put a few drops of locktite on the threads and thread the replacement chuck back on. Tighten the chuck using the vise or pipe wrench. Place the short end of an allen wrench in the chuck and tighten down on it. Placing the drill on a work bench, strike the allen wrench with a mallet to finish tightening and locking down the chuck. Congratulations, you have just changed out your chuck.
Feb 16, 2009 | Dewalt DC927KL Heavy Duty 18 Volt Cordless...
Porter Cable 3 1/4 Hp Plunge Router Logo
79 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim Parker
Jim Parker
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
