Question about Peg Perego 12 Volt Rechargeable Battery
Does the 12 Volt battery for Peg Perego John Deere need to be replaced each year?
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Nope, but you should maintain it with a charger when not in use for a long time
Posted on Jun 07, 2012
  • 60 Answers
SOURCE: do I need to replace all tires on peg perego john deere
Hi!
On these, only the 2 rear wheels are the gear wheels. You will just need to replace the tires on those with the rubber ones if you choose to go that way.  Good luck!
Posted on Mar 11, 2009
  • 670 Answers
SOURCE: We bought a Peg Perego john deere hpx. where can
You could try here. http://tigerimports.net/sunshop/
Posted on Dec 24, 2009
  • 670 Answers
SOURCE: We just replaced the battery and it worked fine
Use a meter to confirm whether the battery is still working. The meter should read around 12-13 VDC if the battery is good. The 12 Volt Peg Perego battery is made with 2 6 volt batteries connected in series. Maybe the connection broke when the battery fell out. Check the connection and also check with a meter if either battery is pumping out 6 volts.
Posted on Jan 03, 2010
  • 110 Answers
SOURCE: where can i get a rubber tires for a Peg Perego
the whole tire would be difficult to replace with a rubber one, but you can put bmx tires on the plastic wheels and that will give much greater traction, but shorten the life of the gearboxes. here is a link to how to do it.
http://www.youtube.com/watch?v=AAySJVt6bys
Posted on Jan 28, 2011
  • 110 Answers
SOURCE: can you replace a Peg Perego Four Wheeler 12 Volt
yes!!!! you should use SEALED lead acid batteries, not golf cart or boat batteries due to risk of build up of gases inside the little chambers and possible explosion or acid burns. batteries from computer back up units are great and you can find pretty good deals on ebay for those. keep the connectors off the old battery and use it on the new one. the one possible downside is the bigger battery might not fit in the regular spot, but you can modify the space usually with a few strategic cutouts. good luck!
How to change battery
you need the thing that connects to the battery and plugs into the wall. You can get one at walmart for around $40 Peg Perego 12 Volt Quick Charger for Peg Perego John Deere Polaris and...
Aug 01, 2014 | Peg Perego 12 Volt Rechargeable Battery
How to change the battery on a Peg Perego John Deere Gator HPX 12 volt ride on toy
the battery is behind the front grille, you have to remove the screw in the middle and then pull out on the green plastic clips on each side then fold down
Jul 23, 2012 | Peg Perego John Deere Gator HPX Ride on...
Battery connectors get hot on gator
are both wheels turning in all of the gears?
May 21, 2012 | Peg Perego John Deere Gator HPX Ride on...
I want to test motors on pergo gator can i hook up reg 12 volt lawn battery to test that they spin or can i test charger
no don't hook it up to regualr 12 volt battery, first check the voltage of the peg perego battery and make sure that its putting out 12 volts, then you can use jumper wires and connect to the motors with the peg perego battery and verify that they work
Jun 25, 2011 | Peg Perego John Deere Gator HPX Ride on...
Where is the battary? Peg Perego John Deere Gator HPX 12 Volt Ride on Toy
the battery is behind the front bumper. There are tabs on either side in wheel wells to release the front end panel and it pivots downward to access the battery compartment. good luck!
Dec 22, 2010 | Peg Perego John Deere Gator HPX Ride on...
HI, I HAVE A PEG PEREGO JOHN DEERE LOADER.I NEED A
You can get compatible replacement batteries for your ride-on toy from here.
John Deere Ground Loader Peg Perego Ride On Toy Battery 12 12 AH F2... You can just change the battery and use the plastic casing and wires attached to your current battery. This will save you a nice sum of money. It is not hard to do. Check this video to see how to do it.
Oct 03, 2010 | Peg Perego 12 Volt Rechargeable Battery
Jan 01, 2010 | Peg Perego 12 Volt Rechargeable Battery
I need a new batery charger for my peg perego gator hpx 12 volt. where can i get one?
I bought my Peg Perego Charger at
http://www.shopjandl.com/mecb0034.html
They fit the 12 volt blue batteries for Peg Perego.
Hope this helps
Jul 09, 2009 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego 12 Volt Rechargeable Battery Logo
69 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
