Question about Motorola Mobility V360 Cellular Phone
How do I change phone tone from vibrate to ring.
I'm not sure how my phone got chnaged to vibrate, but I don't know how to change it back to ring.
    New Friend:
  • 81 Answers
Open the phone, and push the volume buttons on teh left side. push the up arrow untill it starts beeping and the volume shows up on the screen.
You can also set it to ring only or vibrate only, in the ringer settings.
Posted on Apr 28, 2010
Samsung epic galaxy S running Android 2.2. Phone stopped vibrating. Why? Purchased on 4-1-2011.
problem is either with your ringer settings or from the ********.
Check your ring tone settings, see if vibration is enable/active.
If vibration is enabled and you still don't feel any vibration from the phone, then it means your phone's ******** has become defective. Below is an image of what the ******** looks like:
Also, factory reset the phone and see if that would solve the problem. If resetting doesn't solve the problem, then know for sure that the problem is with the ********. It might have loosed contact and shifted from it's normal position or it maybe defective.
Let me know if you would like to replace the ******** yourself or not.
Take care.
Jul 01, 2011 | Samsung Cell Phones
Tip
BlackBerry Tour: How to make it ring and vibrate for incoming calls
You can customize your BlackBerry Tour so that either it rings when you get a phone call, or it vibrates -- or both. To make your phone both ring and vibrate when you get a call, go to your BlackBerry's sounds and ring tone options, which you can get to by either of the following two ways:
#1 - Use the trackball to go to the sound icon in the upper left corner of the main screen and click on it, then toward the bottom of the list that appears, select Set Ring Tones/Alerts, then select Phone.
#2 - On the main screen, press the BlackBerry button (the one with the seven dots) to take you to your Home folder. Scroll down to the Options folder (it's usually toward the bottom, and it has a wrench icon) and click on it, then select Sounds and Ring Tones.
From this scren you can select the ring tone that you want and adjust the ring tone volume. Then scroll down to Vibration and set it for On.
There is also an option for Vibrate with Ring Tone. If you turn this option on, the phone will both ring and vibrate at the same time when you get a call. If you turn it off, the phone will vibrate first, then ring. Either way, you'll get the ring and the vibration -- it's just a matter of whether they happen together or not. To see the difference between the two options, use the "Try it" option at the bottom of the screen.
When you've made the selections that you want, exit out of the options screen, but be sure to choose Save rather than Discard to save your changes.
on Jul 10, 2010 | RIM BlackBerry? Tour 9630 Smartphone
CAN'T HEAR MY PHONE RING WHEN SOMEONE CALLS ME I HAVE TO PUT THE PROFILE ON VIBRATE
Each of your profiles can be set to different ring tones and different volumes, so whatever profile you have your phone set to, make sure you have it on a ring tone you can hear, and make sure the volume is turned up. Let me know if this doesn't work.
Jun 18, 2010 | RIM BlackBerry Bold 9000 Smartphone
I had purchase a new nokia 1650 wont ring or vibrate
just fomat your phone first then try to change your tone settings
Mar 11, 2010 | Nokia 1650 Cell Phone
My Motorola Razr won't ring or vibrate when receiving an incoming call except when plugged in to the charger
Turn off the ringer id function in settings, ring styles, load detail, ringer id's off.
Hope this helps
Jan 11, 2009 | Motorola Mobility RAZR V3
Won't Ring
check the settings in your phone book. this happened to my phone and all of the personal ring tones were set to vibrate. I don't know how this happened. I went into each contact and changed the ring tone to none and I am back in business
Sep 15, 2008 | Motorola Mobility W385 Cellular Phone
Ring vs vibrate
This phone allows you to independently set ring and vibrate modes. When you access "Call Vibrate" to set the mode, also visit the "Call Ringtone" menu to turn off the ringer.
You may want to leave the vibrate mode OFF and your ring tone ON and use the quick keys to switch between ring and vibrate. Two ways to do this, push and hold the # key to switch between normal mode (the settings you chose in "Call Ringtone" and "Call Vibrate") or use the side volume button to access the "Master Volume" and select "All Off", "Vibrate" or a ring tone volume.
If this helps you, please leave me a good rating.
Aug 17, 2008 | Samsung SCH-u340 Cellular Phone
Changing Ring Style
scroll down and it takes you straight to the ring styles and u can pick it straight from there x
May 20, 2008 | LG Shine KE970 Cellular Phone
No ring, only vibrate
if the ringtones ring from settings or the songs play then it will be surely the settings problem please select ring and vibrate instead of vibrate only and if it doesn't works then go to a near by repair shop and ask them to check and change the buzzer
May 02, 2008 | Nokia 6288 Cellular Phone
How to turn vibrate on?
You can change the settings of the selected active profile.
Select Menu > Settings > Tones > Incoming call alert, Ringing tone,
Ringing volume, Vibrating alert, Push to talk settings, Message alert
tone
, Instant msg. alert tone, Keypad tones, or Warning tones. You can
find the same settings in the Profiles menu.
Jan 16, 2008 | Nokia 6288 Cellular Phone
Motorola Mobility V360 Cellular Phone Logo
157 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
