Question about Ultra Linear UL-2200D Car Audio Amplifier
My amp stays on even when i turn the car off, and its killing my battery. what do i need to do so that when i turn my car off, the amp also turns off?
    President:
  • 2,309 Answers
Hook up the power lead to a switched circuit from the ignition or install a toggle switch
Posted on Apr 28, 2010
INTERIOR LIGHTS WONT GO OFF. KILLING BATTERY.
Probably bad headlamp switch. You do know most have a position which turns the interior lights on even with the doors closed, don't you? If you have this turned off, but lights stay on, replace the switch.
Nov 30, 2014 | 1997 Ford Taurus
Can alternator put out 14.2 volts but not enough amps to charge battery and turn off dattery light?
Yes and no.
It sounds like you have a wiring problem.
The alternator output could be 14 volts and only one or two amps, but that would be enough to kill the warning light. Its more likely the alternator is charging but the current is not reaching the battery.
Aug 26, 2014 | GMC Envoy Cars & Trucks
My left turn signal stays lit even when the car is turned off. I have to disconnect the battery so it does not kill it
Since the bulbs only get power when the turn signal switch is used, it sounds like your switch has a fault. and needs replacing.
Dec 13, 2012 | 2003 Volkswagen Passat
2006 acura tl #6 fuse, interior light, draws to much amps with car switched off , take fuse out , fine ,if dont take fuse out , kills battery in 4 or 5 days
You get a wiring diagram of that circuit
From there you will see what could stay on,
if that item failed,even though the car is turned
Before you say too many AMPS, always test to
confirm what your assumptions are.
Test,don't guess
Jul 01, 2011 | 2006 Acura TL
On my 94 jeep im having an electrical problem, something is killing my battery and i checked the alternator and my starter and i can not find the solution something is killing my battery rapidly please...
START THE VEHICLE, PUT A VOLTMETER ON THE BATTERY. THE VOLTAGE SHOULD READ 13.90 TO 14.80. IF THAT IS OK, THERE MAY BE A BATTERY DRAIN. TURN OFF EVERY SWITCH IN THE CAR.CLOSE ALL THE DOORS. MAKE SURE ALL THE COURTESY LIGHTS ARE GOING OUT. & THE GLOVE COMPARTMENT LIGHT. RAISE THE HOOD. DISABLE ANY UNDER HOOD LIGHTS. DISCONNECT THE NEG. CABLE FROM THE BATTERY. PUT A 12 VOLT TEST LIGHT, ONE END ON THE NEG BATTERY POST & THE OTHER END ON A GOOD GROUND { METAL }. IF THE LIGHT COMES ON THERE IS A BATTERY DRAIN. NO LIGHT , NO DRAIN. IF IT'S ON, ONE AT A TIME PULL THE FUSES OUT OF THE POWER DISTRIBUTION BOX. IF THE LIGHT STAYS LIT, PUT THE FUSE BACK. DO THIS WITH ALL THE FUSES BIG & SMALL. IF THE LIGHT STAYS LIT, DISCONNECT THE ALTERNATOR. THEY CAN CHARGE THE BATTERY WHILE RUNNING, & DRAIN WHEN STOPPED.
Jan 11, 2011 | 1994 Jeep Grand Cherokee
The led on my lxa 600 watt amp in my dodge magnum
If the light is all that is on then it will be fine. It would take days to weeks for it to kill todays car batteries. If the amp is drawing more power than just that though, I would move the remote wire to the ignition or the headunit, because the fusebox is getting constant power to tell the amp to stay on.
Oct 10, 2009 | Car Audio & Video
I have a 2004 chyrsler sebring v6 and recently my fan started not shutting off when i turned the car off and now its killing my battery does anyone have any idea what would make the fan stay running even...
Check under the hood and see if you have a decal that says fan may turn on after car is turned off. The fan can run for 10-15min after shut-off.
If it's on for only that length of time and it's killing your battery, you may need a new battery.
If it's not turning off at all, open fuse compartment under the hood, take a small rubber mallet and start to tap the relays. There should be one there for the cooling fan. Once you find it, (the fan will turn off when it's tapped) you can exchange the relay for another (of the same part number - like the wiper relay or A/C relay or something) restart car, let it run til hot, and turn off. If fan shuts off within 10-15 minutes, you need a new relay.
Aug 03, 2009 | 2002 Chrysler Sebring
The abs brake sensor stays running even when I
The ABS modual has gone bad. You can pull the ABS maxi fues under the hood to keep it from killing your battery.
Jul 01, 2009 | 2002 Chevrolet Avalanche
Brake light and stop brake light stay on after car is turned off. This is killing the battery. Tried changing the 15 amp breaker under sterrting column
Your brake light switch is eith stuck or gone bad.  It is located on the brake pedal and you can try to jiggle it to see if it will free itself and turn the lights off or you will need to replace it.  It's a pretty easy job and relatively inexpensive.  Let me know if you have any other questions.  Thanks for rating my response and for using FixYa!
May 28, 2009 | 1997 Nissan Maxima
Amp LED light turns on then off
You need to use a multimeter to confirm that you have both B+ and remote voltage at the amp.
Oct 28, 2007 | Sony XM-2200GTX Car Audio Amplifier
Ultra Linear UL-2200D Car Audio Amplifier Logo
94 people viewed this question
Top Ultra Linear Car Audio & Video Experts
Professor_V
Professor_V
brian williams
richie46
Are you an Ultra Linear Car Audio and Video Expert? Answer questions, earn points and help others
