Question about Philips MX3700D Digital Surround Sound Receiver System System
Philips MX 3700 D home theatre system
System shuts down after only 10 minutes. (FM tuner and DVD player)
It seems to be overheating for some reason, but the repair person who is looking at the unit does not know why??
  • 26 Answers
SOURCE: Philips HTS3410D home theatre system.
Power off the system
Unplug the power cord
Wait 5 minutes
Plug back the power cord
Power up the system
Press the open/close button
Load a DVD and play
If the tray still will not open, the cover will have to be removed and manually operated. You may have to have a technician look at the unit.
Please rate this solution - Thanks
Posted on Feb 28, 2009
ginko
  • 19396 Answers
SOURCE: hts 3450 home theatre system- dvd in player- but won't come out
When a disk is stuck inside the player , try following the procedure below:
Unplug power cord.
Plug back power.
Turn on the unit and press repeatedly the eject button at the same time. If you successeed in ejecting the disk before the player starts reading TOC(disk initial track), then the disk will eject.
If that does not work, then there is an internal fault, in that case the unit must be taken apart to remove the disk.
Posted on May 04, 2009
SOURCE: my philips 3100 home theatre system will play
Change the motor disc spindle
Posted on Sep 09, 2009
SOURCE: philips lx3600d dvd surround home theatre system dvd player fault
when the dvd is inserted it shows up no disc so it is not loading
Posted on Feb 05, 2010
  • 308 Answers
SOURCE: Corrupted Firmware on Philips HTS3555 Home Theatre System
Only posibility is finding a service shop that services Philips....
Posted on Mar 23, 2010
Phillips mx3660d dvd player with surround sound system overheats about 45 minutes into a movie and then shuts down. Once it cools down you can turn it back on and finish the movie. Does anyone know what is...
my phillips mx 3660D digital surround dvd system won't read the movies any more it says no disc.It will play music cd's beautifully ok whats the problem? help it was playing fine
Oct 18, 2009 | Philips Magnavox DVD/VCR Dual Player
My dvd home theatre system ht tx75 keeps shutting down
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
May 28, 2009 | Samsung HT-TX72 Theater System
Black and white
Unplug the home theater for about 2 minutes, and see if the default color has been reset once you replug it.
Mar 23, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
Ghosting of picture from a Panasonic home cinema system
There must be a fault in the screening of the internal wiring to the scart outlet in the home theatre system. I simply changed the way the player was connected to the TV and the interference disappeared:-
1.) I used the RCA video outlet instead of the scart lead. Picture quality was not compromised. FYI the Panasonic Plasma TV I have has only RGB video input sockets at the back, so I used a scart to RCA adaptor to overcome this problem of connecting old technology to new.
2.) The surround sound when playing DVDs is generated directly from the home theatre system so there was no need to connect the audio from the home theatre system to the TV
3.) I used a pair of RCA leads to connect the "audio out" from the TV to the "audio in"on the home theatre system to provide the option of TV sound through the home theatre system.
Mar 18, 2009 | Panasonic Televison & Video
I didn't solve the problem,however i called sam sung and I will be sending it in for repairs under warranty.
thank you
Jan 27, 2009 | Samsung 1200W 5.1-Ch. XM-Ready Home...
DVD HOME THEATRE SYSTEM
You must change the color system PAL to NTCS or viceversa.
Aug 16, 2008 | Philips PSS110/17 MP3 Player
Philips Home theatre system HTS3000
try to clean the lens of your player with the cd lens cleaner available in the computer store or appliance store.
Jul 20, 2008 | Audio Players & Recorders
My home theatre system (sAmsung DVD home theatre system HT-Tx75)shuts down automatically after 10 minutes of listening to the radio...it says 'protection', then shuts off. i checked to see if it was on...
Protection mode on a Samsung player most likely means that the unit is overheating due to a non or low functioning fan. Before taking it somewhere to be serviced turn the unit on and see if the fan in the back is functioning (it should be on whenever the unit is on). If it is not you can try gently blowing it out with a can of compressed air.
I am sure that you can have it serviced but it might be cheaper to purchase a new player.
Good luck and take Care,
-WN
May 06, 2008 | Televison & Video
Home Theater Philips HTS3410D Audio problem
your sytem is going into protection power regulayor ic needs to be renewed
Sep 04, 2006 | Philips HTS3400/37B System
Philips MX3700D Digital Surround Sound Receiver System System Logo
162 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
