Question about Sharp AR-168D Black and White Copier
Document feeder It has a document feeder for faxes and 2 sided copies. Feeder quit working. Technition says it may be one of 2 "boards", but can't get parts for this machine. What may be the problem, and is "can't get parts" true??? Thanks.
  • 1,110 Answers
Parts are absolutely still available for this machine. It was introduced in February of 2004. Most manuafacturers supply parts for at least 8 to 10 years minumum. If you have a maintenance contract then you need to make them fix your machine. All manufacturers provide letters to their Authorized Dealers when discontinuing parts support for any particular model. Therefor if they tell you they can not get parts then ask them for the letter from Sharp saying there are no parts available. Most of the time this is just a ploy to try and get you to buy a new machine.
If you do not have an agreement then look for another repair company/person as they are not looking out for your best interests.
If you want a site that sells parts then check out precisionroller.com
Just put AR168D in the search box at the upper right, they have something like 50+ parts listed and they are not even a Sharp Dealer.
Good Luck and Thank You for using Fixya.
Posted on Apr 28, 2010
WONT MAKE A COPY IN TOPFEEDER
Check the connection of the doc feeder to the copier. if you open a cover on the doc feeder does reflect on the copier? Ensure the doc feeder is aligned there is a small magnet right front side of the doc feeder that sits on top of a switch (Can not be seen underneath front plastic the copier when down. Adjustment bolts for the doc feeder is the rear right hinge only.
Mar 21, 2014 | Konica Minolta Bizhub C253 With Document...
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Want to use HP 1040Fax machine to make copies
1. Turn the page face down and insert it into the document feeder.
2. Press Copy twice.
2. Press Copy.
Number of Copies then 01 [01-50] will display.
3. If you want more than one copy, use the phone pad to enter the number of copies.
4. Press Copy to start copying or press Start/Enter to go to the next option.
Zoom Rate then 97% will display.
Dec 05, 2011 | HP 1040 Plain Paper Inkjet Fax
We have a black line down the center of all copies...
If the problem only happens on copies or sent faxes then no it is not your drum. There is something on your scan glass. My guess is you are getting the line on your copies when you run the original through the document feeder. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on
May 20, 2010 | Office Equipment & Supplies
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
Mar 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
Brother Intellifax 1" black line on right in send & copy modes
lift up your document feeder and check for something on the **** glass
Nov 16, 2009 | Brother IntelliFAX 4100 Laser Fax
When faxing does paper face uup or down
You load the originals print side uo on the document feeder tray or print side down on the glass.
To send a single page fax you can either load the original on document feeder tray or on the glass; to send a multi-page fax you must use the document feeder tray.
The position of the paper is the same either you copy, fax or scan.
All this is clearly explained in the user's manual, that you should read and you can download from HP support pages for you printer:
Aug 09, 2009 | HP Officejet 6310 All-In-One InkJet...
Ricoh C21SF Automatic Document Feeder (ADF)
Take a little soap and a little water and clean the gray feed tire that is located in the document feeder. Check for any paper obstructions. If the machine has had a lot of prints I would replace the feed tire.
http://www.websitetoolbox.com/mb/copierquestions
Sep 25, 2008 | Ricoh Aficio SP-C210SF Printer
Black lines on copies when run thru fax feeder
There is a thin strip of glass that you will see when you lift the top feeder. There is most likely white-out on it.
When you use the top feeder, it doesn't use the large glass, it only 'rolls' the original document over this small strip of glass.
Jan 18, 2008 | HP LaserJet 2840 Printer
Document feeder
Its most likely to be the pickup roller and separation pad which will need replacing. as a short term fix try cleaning them with some isopropyl alcohol
Sep 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Sharp AR-168D Black and White Copier Logo
67 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
