Question about Sigma 10-20mm f/4-5.6 EX DC HSM Lens for Canon Digital SLR Cameras
Lens will only operate between 10-14mm - Sigma 10-20mm f/4-5.6 EX DC HSM Lens for Canon Digital SLR Cameras
    Problem Solver:
  • 18 Answers
Sounds like it was dropped
Posted on Apr 29, 2010
One wins of the new Nikon 3200 locks in however cannot use camera camera says lens not locked
The contact in the lens is the ground contact. If it does not touch the camera mount the camera will, give an error code and not operate. Remove lens mount and check pin spring operation. If stuck slightly enlarge hole
Feb 14, 2015 | Nikon Coolpix 3200 Digital Camera
Operating lens
If you're asking about the 70-300mm D lens and the viewfinder is displaying "fEE" then turn the aperture ring on the lens to its smallest setting (largest f/number). Control the aperture from the body, the same way as on a lens without an aperture ring.
May 24, 2013 | Nikon D5100 Digital Camera with 1855mm...
When the time to operate my 18 to 55mm is not working how can i fix this can you help me what to do
Hi Tom, if it your first time operating the Canon EF-S 18-55mm f/3.5-5.6 USN Lens then this wont be that difficult. To operate the lens, simply attach it to the DSLR body, turning the lens untill it clicks into place. To zoom the lens, turn the grip section of the lens both ways.
Dec 27, 2012 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Lens error. lens is currently retracted. will not open. nikon s8100 bought xmas 2010.
Had issue with lens stuck and not retracting on nikon s8100. first removed battery. then manually (gently) rotated lens counterclockwise until lens seated in fully retracted position. inserted battery, turned camera on and camera operational again. I suspect that root cause of lens jamming was turning off camera while simultaneously moving zoom lever
Mar 11, 2011 | Nikon S8100 Digital Camera
A700 flashing "lens" message
Is the lens switched to manual as well as the mode dial. If the compatable lens is a minolta requiring an M42 adapter make sure that the protruding arm/rod is operating the shutter when depressed and that the adapter when fitted operates the lens when turned from auto to manual. Good luck.
Jun 27, 2009 | Sony Alpha DSLR-A700
EOS 66 works ok without film
Is your lens attached....some models won't operate in certain modes without the lens attached.
Apr 07, 2009 | Canon Photography
Cd drive not working
i have personally faced this issue before, sometimes it does happen that CD/DVD ROM's go bonkers in reading discs, mostly bcoz either the CD/DVD is damaged (scratched etc.) or the lens has gotten dirty.if it is a lens issue use a lens cleaner (lots r avail. in the mrkt) and try again if not im afraid ur CD/DVD is concked
Mar 23, 2009 | Compaq Presario sr1403wm AMD Sempron 3000+...
Not operate
E 210 is lens operation problem. Open up the machine top glass, dont close the top or feeder unit if installed. Try to switch on the machine and see inside the optical unit, is the lens makes any move ? If not, commonly it is caused by broken gear motor lens drive. If it is moving but stop at the end of movement then you have the Home Position sensor faulty. Try to check that area.
Apr 10, 2008 | Canon NP 6050 Copier
Error 18
The "E18" error code indicates an error that involves the lens unit or lens cover. This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera. Solution Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area: - Hold the camera so that your fingers do not touch the lens unit when you are shooting. - Make sure the camera is off before you put it back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
Aug 31, 2005 | Canon PowerShot SD500 / IXUS 700 Digital...
Cameras Logo
47 people viewed this question
Top Sigma Cameras Experts
Doberman
Devabhakthuni...
Devabhakthuni...
Are you a Sigma Camera Expert? Answer questions, earn points and help others
