Question about Ducane Standard 1504 (LP) Grill
How do you change from a natural gas orifice to a LP gas orifice on a Ducane model 1504?
  • 8,197 Answers
To convert your grill you will need the part # 37800 You can get it on the link below. Half way down
http://www.clagrills.com/allgrillparts/ducane/ducane-model-1504.htm
Good Luck
Posted on Apr 29, 2010
Convert gas grill natural
ducane will not make these available anymore because the ducane family no longer owns the company and the models since 2007 are all made in china with poor quality controls. conversions are simple but the parts will not come through ducane or weber. replace the orifice in the tip of every control valve and replace the regulator. that is the only difference in fuel types.
Oct 15, 2013 | Ducane 30400042 (LP)
Model# BWH30NLTB
Unit goes under sure heat name also.
My unit emitted unburnt gas smell the minute pilot started,
and was annoying during burner operation.
I discovered they built unit with primary pilot that had 2 ports.
They used LP and sealed off natural gas,instead turning lp/nat
knob on back activates second pilot for natural gas use.
This means natural gas goes thru LP pilot orifice and burns
slightly off during normal natural gas use(by design).
The unused natural gas orifice has 1 air mix hole and the LP orifice
has 2 air mix holes.
I carefully plugged 1 of the holes in the LP orifice and suddenly
pilot gas flame seated correctly on orifice port.Gone was the
unburnt odor of natural gas.
The typical flame in a flame appearance now was exhibited by
the small pilot,secondary pilot remained consistent with manual
picture.
Of course, to use with LP I would have to open blocked air mix
hole in addition to the other changes per manual.
Hope this helps someone with similar condition.
Dec 31, 2012 | Reddy Heating & Cooling
My left burner is much hotter then the right burner on my 1504 Natural Gas Grill. Please adivise
It mat simply be a case of the right burner needs to be removed and thoroughly cleaned as well as the attached venturi valve. Spiders like to build nest in the venturi valve, clogging them so the so the air to gas mixture is off.
Jul 18, 2011 | Ducane Standard 1504 (LP) Grill
I cannot find a supplier who can provide an LP to nat gas conversion kit for my 4 burner grill made under the name: Ducane, model # 30400040. Can you assist? Marlin
Perhaps, the reason you can't find the fuel conversion parts is that they are not convertible from one fuel type to another. Ducane/Weber makes both an LP model and a Natural Gas model of your grill, but no conversion kits. Because, as the Owners Manual states "Liquid propane gas is not natural gas. The conversion or attempted use of natural gas in a liquid propane unit or liquid propane
gas in a natural gas unit is dangerous and will void your warranty."
http://help.weber.com/manuals/ducane/2009%20Manuals%20pdf/Affinity_3400_4400_NG_OwnersManual_27010342_061008.pdf
Certainly, you could attempt it, Marlin . But it's not the wise thing to do.
I know this wasn't the answer you may have wanted, but I hope it helps you.
May 06, 2011 | Ducane 30400040 Stainless Steel Grill
Does conversion from LP gs to Natural gas on Ducane 30400040 (essentially makes it a model 30400041) require changing the inlet orofice on the IR burner ? I purchased conversion kit that included all new...
Did the conversion kit give you an LP orifice for every new gas valve? LP gas orifices have smaller holes than Nat gas orifices. Can you smell gas when you turn on the IR burner by itself? Some burners styles have an air adjustment on the end that fits over the orifice. Make sure it's getting enough air. Also make sure your ignitor sparker is positioned where the spark can ark against the top of the burner. Ducane grills have rotary ignitors, so turn it (with gas off) and see if you can actually see where it's sparking. If it's not sparking in the right place, it will be difficult to light.
May 14, 2010 | Ducane 30400040 Stainless Steel Grill
How to change burners for a ducane meridian 32 inch 5 burner gas grill
Go to Ducane web site http://www.ducane.com/manuals/ and download the manual for your model.
Has Mederian 3 & 5 burners and LP & NG
Also has Stainless 3 & 5 and LP & NG
Need Adobe Acrobate reader that can also be downloaded.
Manual shows step by step in Annual Cleaning section
azrsanford@comcast.net
Apr 04, 2010 | Ducane Meridian 32 Inch 5 Burner Gas Grill...
Change from natural gas to propane
1.You will need to change the pilot orifice and the burner orifices
2. You may need to change the gas control valve. Some gas control valves are made for natural gas and some are made for LP. They have regulators built-in, that deliver the correct pressure respectively. Natural gas is 3.5 inches of water column, LP is 10 inches of water column.
Some manufacturers sell kits to change the spring in the regulator from Nat to LP
You would need a parts breakdown on the specific model number of your fryer to find the parts you need. Hope this helps.
Apr 07, 2009 | Imperial IFS40 Deep Fryer
Converting a GE Profile Gas Range from LP to natural gas
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
Jan 06, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ducane Standard 1504 (LP) Grill Logo
283 people viewed this question
Top Ducane Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
