Question about Refrigerators
Fridge has hot spot
Our 3 yr old Gorenje fridge-freezer (not sure model - freezer below fridge) recently started to over-freeze in the fridge, recently, building up ice at the top. Some items froze to the top and bottom if they touched it, while some dairy items went sour too soon. On examination, the centre-back of the cabinet is HOT to the touch - as hot as holding a mug of coffee! This comprises about one quarter of the interior.
We have defrosted and thoroughly cleaned both fridge and freezer, turned the thing back on, and hey presto - two cold bands sandwiching a hot-spot area.
What to do? Thank you.
Hit it with a big stick!
Posted on Mar 25, 2008
Hi, I have a 3 yr old Haier Fridge serial #HBP18GAAWW, the feezer is on the bottom. The food and drinks keep freezing in the fridge and there is alot of frost in the freezer. Is there a problem with his...
Have you tried to lower the temp.settings?? If settings are about 1/3 of the range, then it could be a thermostat problem.
Keep me posted!! Rate this post!!
Aug 12, 2010 | Haier Refrigerators
MY 9 YR OLD FRIDGE IS FREEZING MILK, JUICE AND ALL LIQUIDS IN THE MAIN COMPARTMENT BUT NOT NECESSARILY ON THE DOORS
you gotta send model number,there are different things that can cause this,if the freezer is on top,the cold air from the freezer gets blown into the fridge in the center of the top shelf so if any food is near this it will freeze if the air isn't monitored, check the settings first,it could be set to high, there's a cold control or thermostat that monitors how much air comes into the fridge and when it reaches a certain temp it shuts off but it sounds like your having a problem with it,also on some fridges they have a damper that can mess up,there's a door on it that doesn't close and the cold air just keeps coming into the fridge and things start freezing up
Dec 24, 2009 | Refrigerators
My 9 yr old Kenmore Elite fridge is warming up!! The freezer is fine!!!! Model 3 106*74902401 Seriel # ES423704 Manufacture date is 10/2005, I purchased it in Dec of '05 and it's been WONDERFUL!!
This problem sounds like a damper control broken or frozen.
Lowering the freezer temperature may help to fix the problem as the damper sometimes freezes and not able to open to cool down the fridge side.
If lowering the freezer temperature doesn't help, you may need to call for a technician to fix or replace the damper control.
Also, be sure the door closes properly and no air comes in or out from the fridge.
Dec 18, 2009 | Computers & Internet
I have a 3 yr old side-by-side. The freezer is freezing ice cream solid even though it's turned all the way down. Food in the bottom two drawers on the refigerator side are freezing. Water has dripped...
Hi, this problem is going to be with the running thermostat. (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ed22pwxxn00 setting on 3 top shelf items freeze. Is our 18 yr old fridge going out?
Adjust the freezer damper to a higher number to reduce cold air flow to the fridge section. This will eliminate freezing in the fresh food section.
Aug 29, 2009 | Whirlpool Refrigerators
Kenmore Elite 106-74202402 Freezes food ice solid in the fridge
Hi
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 03, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Gorenje KE267MLA Fridge too warm
higher the number, colder the fridge ie 7 is the coldest setting
switch with red dot is for summer/winter operation. only necessary to switch it on if the appliance is in a cold location
Sep 30, 2008 | Gorenje Refrigerators
Refrigerators Logo
234 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
