Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Self clean lock
My frigidaire self cleaning oven latch is stuck in the locked position. have unplugged and cut power off ... nothing will reset the self clean lock.
  • Frigidaire Master
  • 3,051 Answers
Hello there:
Normally every body gets this almost right by cutting the power but there is a trick to this it can be done in 2 different ways depending on the unit
First unplug the unit and wait 15 -30 seconds then plug it back in and wait for 15 to 30 seconds then unplug it again and repeat this step 1 more time then upon the final plug in wait for 5 min and then unlock as you normally would.
now on the newer units the trick is to let it stand unplugged for 1 hour to allow the internal reset device to reset the appliance then plug it back in and then wait 5 min and you should hear it automatically unlock the appliance or you cn simply unlock it as you normally would
BUT REMEMBER DO NOT TOUCH IT FOR THE 5 MINUTES AFTER THE PLUG IN STAGE OR YOU WILL HAVE TO DO IT ALL OVER AGAIN OK
Hope this is very helpful for you please keep me posted on how this is going there is still more that i can show you but i wanted to start with the basics ok?
Best regards Michael
Posted on Apr 29, 2010
My GE wall oven is stuck on lock mode. I cancelled a self clean (I know, big mistake) and after cooling down it still won't unlock. I've cut the power and still nothing. It's been 3 days! Trying to avoid...
Try putting it back in self clean. Listen to see if it locks. then cancel the self clean. It could be the self clean lock motor has gone bad. The lock hook can be moved to unlock the door by inserting a stiff wire like a coat hanger between the door and the oven and moving the latch over to unlock the door.
Nov 07, 2014 | Ovens
Self cleaning
There is a SAFETY INTERLOCK, if you opened it then locked... Is that what you said? It can not clean if the door is not locked.
If you unplug the stove and this will give it a reset. but you may have done some mechanical damage that you will have to inspect to see what it is doing. Is the Locking handle working properly? Is anything jammed ? Ect... Look at the Mechanical components first...
Mar 01, 2014 | Frigidaire Ovens
Frigidaire door lock won't reset
Hello Steven Krenz - Was the unit in self-clean mode? Try pressing and holding the "Clear/Off" button to stop any operation of the EOC. Do this at the same time while pushing and hold the light switch to the left of the door lock. Usually this will trick the oven into unlocking the door. If it is ineffective, try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and redo the steps. If door continues to maintain locked while open, the unit may possibly have a faulty door latch or a communication problem with the EOC. Contact a professional to move forward accurately.
Apr 02, 2013 | Frigidaire GLEB27S7A Electric Single Oven
I was cleaning my oven and one of my kids opened the doore before it was finished and then pushed the cleaning button again but did not shut the over door so the lock is up on the door and it won't shut. ...
unplug unit. remove rear cover, see if latch motor has made it to rest position. microswitch may be holding power off to latch. a slight turn may be all you need to reset latch.
hope this helps
Sep 28, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Opened oven door seconds after pushing clean. Lock stayed out but by pushing clear and door switch, unlocked but oven will not work, says it is "off" Have turned off power for 5 mins but didn't solve...
the door latch may have over run its normal reach causing it to stick . ck the lever / also try putting it into a clean cycle while holding the latch in the closed position ... i thnk the latch is stuck . you may have to remove it and reinstall . to correct .. power off should have corrected it . so it may be stuck .. mm
Jul 15, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Started to self-clean, locked the door, etc. Had
Hi.
The appliance door is probably locked in consequence of the self cleaning cycle.
Unplug power cord, and allow the oven cooling down for few hours.
If the is still locked, then the high temperature generated in self cleaning cycle may have damaged the door latch, or the electronic control.
Parts must be tested to discover the fault.
Call Frigidaire at the number listed on the owners manual.
Regards.
Mar 03, 2010 | GE Ovens
Opened oven door before it could lock while I was
try unplugging the unit,
depending on your exact model it may just be lost in the programming becuse it sensed the door open while locking so it shuts down the lock for safety
just unplugging if for a few minutes might clear the error enough for the lock to rotate back to closed
position
Nov 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door is locked shut. How do we get it to
Try cutting the power to it. ALSO push in to relieve the tension on the latch while attempting to open it.
Oct 21, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door is in the locked mode and wont close
You can use a screwdriver and a wire coat hanger to get to the latch between te slots on the door. you have to open the door to get to the scews in most cases.
Mar 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Locked latch on the self cleaning oven
try wiggling the door latch to get it open if not try the cleaning process, if that works, and see if the door comes unlatched and the light goes off. if not the lock light switch is stuck and it will need to be taken apart and cleaned
Oct 13, 2008 | GE JKP15 Electric Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
299 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
