Question about Kenmore 85920 PowerSpin Upright Wet/Dry Vacuum
Won't extract will not extract the cleaning solution from the carpet when cleaning
  • 2 more comments
  • mpriddy Jun 13, 2008
    Will not **** up water and no manuel
  • brenda_hance Jul 04, 2008
    will not **** up water
  • Anonymous Jan 24, 2009
    I am experiencing the same problem, no extraction of solution. please advise
  • Anonymous Feb 21, 2009
    The Kenmore PowerSpin carpet cleaner has stopped sucking up the solution. It worked fine when I cleaned a carpet a couple of months ago. Now I want to do my other carpets and nothing happens. Only a little solution will come out at a time, and whatever there is doesn't get sucked up.
I am having this same problem. Do you have a manual because, I don't and I also would like to know what I can do to fix the problem.
Posted on May 25, 2008
    New Friend:
Won'T **** UP THE WATER
Posted on Oct 19, 2010
2 Suggested Answers
SOURCE:
ekcnoel
  • 998 Answers
SOURCE: Platinum Hoover Max extract won't
Try to check the fuse if blown due to long time usage, you can check it with a multi meter or if the unit still have warranty try to bring it back to the shop where you bought it for the security of your vacuum. feel free to send feed back good day and best regards.
Posted on Aug 02, 2011
My Hoover Max extract dual v cleaner worked fine cleaning the carpet but when it came to using the hose attachment for my sofa, there was no suction and the brush did not spin.
Hello, Kathy -
If you have not yet checked your owner's manual; the Troubleshooting section, I suggest you do.
If you do not have the manual, you can download a PDF (Adobe Reader) version here:
https://www.manualslib.com/products/Hoover-Max-Extract-Dual-V-6126442.html
This is the link to the Troubleshooting section in the manual:
https://www.manualslib.com/manual/389163/Hoover-F7411900-Steamvac-Dual-V-Wide-Path-Deep-Carpet-Cleaner.html?page=19#manual
I hope you made sure the dirty water tank was empty and that the filter screen is clean.
Jan 02, 2018 | Hoover Vacuums
How can you clean spots off carpet
Office pros cleaning service is expert in carpet cleaning.They categorize our cleaning program depending upon carpet condition. Offer three types of carpet cleaning programs.
Steam clean/ Hot water extraction
Bonnet clean
Very low moisture encapsulation clean.
Office pros cleaning staff expert in spot and stain remove from carpets,use the green certified product for cleaning.So finnally I suggest for Office pros cleaning for remove the spot and stain from carpet.
Commercial Office Carpet Cleaning
Dec 30, 2013 | Vacuums
How can Berber carpets be maintained fresh and new-like for a longer period of time?
You can clean them with household units but even professionals have trouble with berber carpet because of its tight weave and usual inlaid patterns. Dry carpet cleaning between professional cleanings will help keep carpet looking new without staining. My suggestion is to use a dry carpet cleaning machine and then have a professional come in with hot water extract as often as every year depending on traffic. I sell the SEBO DUO machine you can see by clicking the link provided.
http://vacuummedic.com/product.php?id=511
Jun 28, 2013 | Hoover SteamVac Carpet/Upholstery Deep...
My hover extract deep cleaner won't spray water or cleaning solution
If you have the receipt from when you bought it, take it to the closest Hoover warranty center and they will fix it under the warranty at no cost to you.
Jun 11, 2017 | Hoover F7431-900 SteamVac Vacuum
How to clean your carpet?
Clean the carpet with regular vacuum, baking soda or vinegar is the best cleaning option to remove the stain or dirt over the carpet and also helpful to make long life of carpet with cleaning.
_________________________
crawl space vapor barrier seal
Jun 28, 2012 | Vacuums
Hoover SteamVac isn't extracting solution from carpet. Motor runs and the brushes weren't turning at first but do now
That vacuum is fine on liquid extraction but often gets clogged by debris when it hits a solid. It would be better to do the clean with the steamvac then follow it with a wet/dry shop vac to be sure you got all the water. I say this because the vac built into that hoover is way too easy to clog.
Mar 13, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Bissell pro heat will not extract water from the carpet
Try checking the top section of the machine (where the dial is located to switch it from floor to tool) and there is a little red plastic piece about 1 inch square on the inside of it. This is a lint filter that has a little door on it. Open the door or remove the entire thing to clean it out. It is probably completely blocked with hair, etc.. which is why you have no suction. Replace it after you clean it out and hopefully your problem will be solved!
Sep 06, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My hoover carpet scrubber the brushes won
(1) Remove the brush block and assure the presence of the square drive pin on top of one brush. It should be about 1/4 inch square, two inches long to connect o the drive mechanism.
(2) Remove and clean the filter screen from the base, behind the brushes. Squeeze the two red tabs together, and pull down from the base. Clean the hiar/debris from the screen.
(3) Assure the Brush Speed knob on the hood is NOT set to the OFF position.
Aug 30, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Kenmore 85920 PowerSpin Upright Wet/Dry Vacuum Logo
610 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
