Question about Western Digital My Book Essential 1TB External USB 2.0 Hard Drive
When i connect my wd 1tb hard drive i get usb device not recognised plz help
    Sergeant:
    Novelist:
  • 172 Answers
Hi sexybarneygu, Assuming you have tried other USB ports getting the same problem, I recommend you return it (if it's under warranty) if not, remove the Hard Drvie from the casing and connect it to another computer internally (I dont want you to get another external case for you Hard drive because you hard drive MIGHT be the one with the problem and you cant fix it (you can't fix hard drives, just work around it in order to get your data back and then trow it away). If the other computer sees your hard drive ok, then go buy an external case and install your hard drive there. make sure it's the same interface - most likely SATA interface. I'm 80% sure it's just the casing not the hard drive. Don't forget to rate if my answer helped you. Thank you :D
Posted on Apr 28, 2010
My WD elements 1.3 TB external hardisk. It gives a buzz when connected and is not recognised by windows
It sounds like the HDD inside is dead. The USB interface may have an issue but usually clicking or buzzing is HDD failure. If you have a desktop you can try removing the hard drive from the external case and connecting it directly to the computer using a SATA cable.
Jun 19, 2016 | Western Digital Wd Elements Se 1tb...
Hi, my ps3 won't recognise my 1tb wd external hard
The problem with the new 1Tb WD Passport that I just purchased is that it is a USB 3.0 format and apparently PS3 doesn't recognize that speed.
Haven't found a workaround for it yet, but all these people advising you to reormat anew Passport drive are wasting your time.
Jul 02, 2012 | Computers & Internet
I have a 1TB WD my passport external harddrive and its not recognised on my sony blu ray
You are trying to conect this disk to the standalone Sony bluray device with USB cable?
You are sure sony have implemented this functions (external disk support) on this player?
Now knowing enough about the sony device, you should first of all see through the users manual. There could be a FAT(32) / NTFS issue. Some devices like this does not support NTFS, and the drive must be formated with FAT32.
Jan 28, 2011 | Western Digital 1TB My Passport Essential...
I have a brand new WD 1TB My Book delivered today not recognised
Pleaes open the Device Manager and right click on the Yellow exclamation mark.
Now, click on update Driver and select Install from Advanced Location.
Type the Location as C:\Windows\inf and click on Ok.
The Driver should be installed now.
Jul 13, 2010 | Western Digital My Book Essential 1TB...
WD 1Tb Drive not recognised on my HP Media Centre a1550a
Probably the size nay be above the parameters the existing software is able to recognize
Did you receive a disc and if you did not. Simply go to the page of the manufacturer and down load the driver, then the Plug and play should recognize it..
Nov 01, 2009 | Western Digital Elements powered by WD 320...
Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Jun 01, 2009 | Western Digital My Book Essential 1TB...
Hd only switches on briefly the shuts it's self down
If it has another connector type ie firewire or usb ( the opposite of what you are using ) then try that.
If its usb then you can go into device manager and un install the usb hub under usb devices etc and re install your motherboard drivers and re connect the hard drive also if you have a laptop or a friends computer you can connect it to temporarily to install it on just to see if it works on there computer - if it does then that means the hard drive is fine if not then it points at the hard drive.
May 09, 2009 | Western Digital Elements powered by WD 320...
WD 1TB working properly for some time
Make sure the power supply (power brick) for the mybook is working. (unplug both ends or the power cable and plug back end)
do the same for the USB cable. Still no luck? Plug the USB connector into a different port on the PC and see if that changes your luck.
Feb 27, 2009 | Western Digital My Book Essential 1TB...
Western Digital My Book Essential 1TB External USB 2.0 Hard Drive Logo
254 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
