Question about Kitchen Ranges
Lpgas oven Sometimes after 15 minutes it will start to sound like it blowing air and cooling off.
  • 53 Answers
this could be servel different problems, most of which are fairly simple. however, with LP you may be better off contacting your LP gas supplier to see if they can check it for you.
Posted on Mar 24, 2008
Air conditioning unit blowing warmer air even when unit is set on 70 and then will blow for 10-15 minutes and then cut off for 5-10 minutes before coming back on again blowing warm air.
If its a window unit, pull out of window get to the front fins might have to remove a few screws on the sides of front and spray out with a hose be careful not to get control box wet.spray fins and wheel inside, dump water out the back or side, put back in window it should start blowing cold air if not then its time for a new one.but sounds like its getting over heated
Aug 28, 2017 | Heating & Cooling
My microwave shuts off, black no power when ever I cook tv dinners, potatoes etc. after 2.5 or 3 minutes. After 10 minutes or so, power comes back on and it displays PF. lots of steam inside after.
Hi Kerry,
"PF" is power falure if you didn't aready know this. It sounds to me like the coolig fan might be running slow or there is blocked or restricted air flow through the unit. This cooling fan is only for the HV transformer and magnetron. Sometimes you may get air flow around the door but this is incidental. The PF tells me that the power is being interrupted either at the power source (wall outlet or circuit breaker) or the magnetron TCO is cutting out. It also could be a bad magnetron running too hot. As far as the steam goes, I usually just leave the door open on my microwave for 10 or 15 minutes to let the condensation evaporate.
Jun 25, 2015 | Hotpoint RVM1435 Microwave Oven
My EverStart portable air conditioning unit
sounds like you need to wash your condenser coil. Sounds like your compressor is kicking out on high head pressure. Once it cools off it starts cooling again take it out and give it a bath don't get the electric wet.
Sep 12, 2014 | Heating & Cooling
05 Avalance heater working intermitantly.
bleed the cooling system you have an air bubble in there.
Oct 05, 2013 | Chevrolet Avalanche Cars & Trucks
Miller Trailblazer, welds great for about 30 minutes. Then I loose my arc. It will spark but not maintain the arc. I let it cool off for 15 to 30 minutes it will weld for another 15 to 30 minutes.
Sounds pretty normal. These units are not rated to weld continuously. They might only be rated at 5-10% for cheap welders and longer for better ones. They are never designed to run continuously. You need to get into the higher end ($$$) before you get that ability.
You can try to blow cool air into the unit to help it cool. Sometimes this can extend the work time.Basically you can try that or work to your temp cut off limit as you have been or upgrade to a better unit. That is about all you can do.
Apr 04, 2011 | Miller Trailblazer 302 Welder Generator...
Engine rough after 15 to 45 min, cool off and uhookbat and repeat
check the egr valve, it may need to be replaced.
Feb 26, 2010 | 1996 Ford Bronco
A/c problem.
jasonjacob1 is right. If the air from the A/C is not cool, the only cause is low or empty refrigerant. This means that the gas that your vehicle uses to produce cool air is gone from the system. The solution is not to recharge the system but to locate and fix the leak, then recharge the system.
May 05, 2009 | 2004 Toyota Sienna
97 Deville cooling
Hmmm... its gotta be the compressor.
Jul 05, 2008 | 1997 Cadillac DeVille
Blowing hot air
Water in the pan is normal, this is the humidity removed from your space. Pan must be emptied regularly. If the unit shuts down after 15 minutes, you may have a blocked hot air duct. Make sure it is flowing freely. This includes makeup air from outside the room to replace that blown outside by the AC.
Jun 24, 2007 | Sunpentown (EHW10268) Air Conditioner
Kitchen Ranges Logo
53 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
