Question about HP Pavilion a350n PC Desktop
Power problem .... tried 3 different power supply cords...the green light on the rear blinking meaning???? pushed switch on front ...held in.....no response only moved from 1 office to another....always was ok before
    Problem Solver:
  • 13 Answers
Was it dropped..?? the indicator light should b solid not flashing.. If you held the power switch in for several min an nothing Try plugging the cord directly into the wall. Do not use power strips as they may have failed.Toggle the voltage regulator switch from 115V to 230V then back again. If you are in North America, this switch must be on 115V. you may have a loose connection in the machine Lastly, you may need to go inside the case and confirm the thin wires running from the front power and reset switches are connected to the motherboard., to check be sure u are grounded an check all connections inside the computer... If the LED is still flashing, the power supply is probably bad.
Posted on Apr 29, 2010
Testimonial: "ALL POSSIBILITIES COVERED.....THANK YOU!!!"
Black Screen no sound, Green light blinks for some time then goes red then recycles back to green
Tv have power LED lights indication are blinking and recycle blinking.Mean the tv power supply board is the problems and the causes.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Mar 02, 2011 | Sony KDS-R50XBR1 50" HDTV
Computer will not turn on. green light blinking
Try replacing the power supply, a blinking green light usually means the power supply is missing an output voltage. If you do that and you still get a blinking green light then the motherboard will need to be replaced.
May 01, 2010 | HP Media Center m1080n (PC099A#ABA) PC...
My power switch won't turn on and a green light on the back of the computer is blinking when the red switch is on the 115 and stops when on the 225. What do you think is wrong?
First off, the red switch is for 155 or 220 volts and should not be adjusted or moved from its position.
Now, disconnect the unit from its power source and allow to set for 3 minutes.
Re-install your power connection and do not push the power switch.
Look in the rear of the unit at the power supply and see if you have a green light.
If so, push power and have fun.
If not, you will need to most likely replace the power supply.
Good luck..
Nov 24, 2009 | HP Compaq Presario SR1303wm PC Desktop
HP a820n No Power-up after City Power Failure
You have a bad power supply. It is not an expensive fix. Remember HP's take HP power supplies. When ordering either look on ebay for your model or order from part supplier.
Aug 22, 2009 | HP Pavilion A820n (PP165AA) PC Desktop
Blinking green light front and back. Clicking sound from inside.
Do you mean the little green LED light near where you plug the power cable into the back of the computer? If that's the blinking light then unfortunately, this means that power is getting to the power supply but it is not going from the Power Supply to the Motherboard/Devices. The power supply is broken and is not converting the power from the wall to the proper voltage for the Motherboard/Devices. You will have to replace the power supply.
Call HP, and I hope you are in warranty and get it replaced for free or you can order the exact same one from HP that originally comes with that model. 1-800-HP-INVENT for their tech support line.
May 05, 2009 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
Will not pwer up. Greenlight blinking on back
The green blinking light can mean there is a problem with the power supply.
Try unplugging the computer from the wall, and turning on the pc on switch.
After a few minutes, try plugging it back in.
If that does not start things up, you may have a bad power supply.
If the power supply is bad, these models take standard power supplies. You should get an ATX 350Watt or higher power supply.
They are easy to replace, unplug the power from the wall, disconnect all the cables inside the computer. Unscrew the four phillips screws outside the back of the computer where the power supply is attached to the case.
Remove and replace.
If you don't feel comfortable with this, a good local computer shop can help you out.
Apr 13, 2009 | HP Compaq Presario SR1330NX (PP161AA) PC...
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Sony VAIO VGC-RB50 No Power
Most likely you have a problem with your power supply. First off make sure your Input voltage selector switch is properly set. This switch should be located next to the power cord. In most cases it is red in color, and will have "115V" and "230V" printed on the switch. I have seen red switches and black switches, but mostly red. I you live in the US, you should see "115V", Europe is "230V". Before flipping the switch, unplug power cord.
Since the light is blinking, you are getting power to the power supply. The power supply might be bad, and you need a new one.
Nov 07, 2007 | Sony VAIO VGC-RB50 PC Desktop
Mitsubishi WD-52525 Status Light --- blinking red constantly.
possible that over night your set took a power surge ,possible power supply fault.
Sep 12, 2007 | Mitsubishi WD-52525 52" Rear Projection...
HP Pavilion a350n PC Desktop Logo
299 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
