Question about Magic Chef CER3725AA Electric Kitchen Range
Adjust temp level of the oven .. model 34ja-5tkxw
How do I reset the temp level in this oven ..
the temperature is not at the level as set electronically
.. oven thermometer reads 30 % below what it is set for and does not reach the temp in a graduated increases..
How do I reset the temp level in this oven electonics ..
  • Magic Chef Master
  • 3,361 Answers
Press the bake key.
Adjust temperature to 550 degress.
Press the bake key again and hold it for 3 seconds.
The temperature +/- should appear.
You can then adjust temp +/- 35 degrees.
Posted on Mar 08, 2009
I have a Jenn Air JJW9830DDP double oven electric, and the temperature in the oven is about 100' less than what it reads on the display. I tested the temp sensor and it ready 1073 ohms. Any s
Well, your temp sensors can still be bad. If not, there's always a new control board you buy!
However, I wouldn't drink water from that oasis without making ABSOLUTELY sure I'm not seeing a mirage.
The only common denominators between your upper and lower oven temp readings is the firmware and the oven thermometer you are using to visually check the temps.
What type of thermometer are you using to check your oven temperatures with?
If it's not a digital thermometer used specifically for testing ovens, you might just be leading leading yourself astray.
You need a calibrated thermometer. If I don't have a calibrated digital thermometer on me, I use two or three oven thermometers (the dial type) and average the readings.
It's the only way to be as close as possible with a digital probe.
If you have thoroughly verified that your oven is in fact not reading the correct temperature, then you can adjust it +/- 35 degrees F via your oven's control panel.
To adjust the oven temperature:
1 - Press Setup pad.
2 - Select the down arrow to scroll to the next screen.
3 - Select Temp Adjust using the Quickset pads.
4 - Select upper or lower oven (select models).
-"Set temperature offset using the Upper Set Knob" is displayed.
5 - Enter the desired temperature change using the Set knob.
The temperature can be increased or decreased up to 35 degrees.
The temp. change is displayed at the top of the window.
6 - Press the Set knob to accept the change.
Now, if you are still worried about the temp. reading being off, replace both the upper and lower temp sensors. That's all you can do besides replace the main board.
Oct 24, 2014 | Jenn-Air JJW9830D Electric Double Oven
Why does my oven thermometer read less than the temperature the oven is set at?
An oven doesn't go to the temp selected. That is the average temp. If you set it to 350, it may drop to 300, then to 400, but will maintain an average of 350. Without knowing your model #, it is hard to say. Some have anticipator (that anticipates the temp and controls the heater and the thermocouple that is trying to keep the temp steady. Some models have an adjustment at the oven switch (rear) that can be adjusted for temp up or down.
Oct 20, 2014 | Ovens
Is there any way to turn off the beeps- starting oven, when it reachs set temp, changing temp
Hello g harrison - Unfortunately the range does not have an adjustable volume level or cannot be turned off. It is designed to advise you of when the oven is starting or reach desire temperature.
Nov 29, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I own a spectra range Model # JBP30B0B4WH The problem is that the oven temp, is off about 15 degrees how can I adjust it? Roy
This is from page 13 of your manual:
To Adjust the Thermostat
Put the Oven Temperature knob in
the OFF position.
Press and hold the HOUR +/– pads for
5 seconds until the display changes.
Before display changes back, press
the HOUR +/– pads to increase or
decrease the temperature in 5
degree increments.
The oven temperature can be adjusted as
much as 35°F. or down as much as 35°F.
If the oven adjustment is set cooler
than the factory setting a minus sign (–)
and the adjusted temperature will appear
in the display.
Wait several seconds for the control
to automatically set and return to its
previous setting.
Feb 10, 2010 | GE Spectra JBP78 Electric Kitchen Range
The temperature gauge does not regester the corrsct temperature of the oven. THe temperature is only around 340 when it should be 375.
Remove oven temp knob, look for small set screw to adjust temp, use oven temp guage to check, usually cw + temp, ccw - temp on set screw.
Apr 29, 2009 | Kitchen Ranges
Incorrect temperature
under the oven knob is the screw that adjusts the temp. remove the knob and with a small blade screwdriver adjust the temp according to your wife's oven thermometer CW+hotter CCW=cooler
then on the back of the knob is a screw to adjust the position of the knob with respect to the marker
Apr 20, 2009 | Viking 30" Professional Select Built-in...
OVEN WILL NOT COME UP TO TEMPERATURE
You can calibrate the oven on this model. Press the bake button, adjust the bake temperature up to 550 degrees and then press and hold the bake button until a 0 displays. Now you can adjust the oven temperature up or down to match the display.
Here is a repair manual link that you can use to download frigidaire repair manuals. The one for 30 inch freestanding ranges will have the section on calibrating the oven's electronic control.
Thanks
Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Preheat beep indicator is inaccurate
It's working ok. These often beep after a preset time. It may be set to beep at 10 minutes. Not always at the temp set. It is usually close enough though.
Nov 19, 2007 | Magic Chef CER3725AA Electric Kitchen...
Magic Chef CER3725AA Electric Kitchen Range Logo
388 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
