Question about Hoover V1 SteamVac SpinScrub Vacuum
Hoover SpinScrub brushes not turning - Hoover V1 SteamVac SpinScrub Vacuum
  • 438 Answers
Hi There,
Here's a very helpful Tip that I've written that explains step by step how to diagnosis the Hoover SteamVac when the brushes stop spinning. This will also walk you through how to replace the brush gear turbine assembly if you find that this is the part that is broken.
If this was able to answer you question, and help you fix this, please be so kind and rate the repair helpful, or leave feedback. This is really what keeps Fixya experts continue to answer free repair solutions rather then just the premium ones that customers pay to have answered. Thanks for showing your appreciation.
Feel free to add a comment if you have any questions or need further help.
Here's the link:
http://www.fixya.com/support/r4530769-diagnosis_fix_hoover_steamvacs_when
Thanks so much,
Chris Jones
GoVacuum.com
Posted on Apr 28, 2010
Brushes stopped turning
check the drive peg that turn the brushes it may have broke and needs replaceing this link is for the manual it will show you how to get the brushes off.
http://hoover.com/file/670/
Aug 11, 2012 | Hoover Steam Vac Dual V w/ SpinScrub...
Were can i find the belt on a hoover steamvac spinscrub the wheels quit spinning on it
There is no belt on the Hoover SpinScrub. The brushes are turned by an air driven turbine. To test the turbine, insert a flat screwdriver into the square hole that the pin on the brush assembly normally fits into, and see if the fitting turns. If it doesn't turn, the turbine has seized up and will need to be replaced.
Jun 20, 2011 | Hoover SteamVac F5914-900 SpinScrub...
SteamVac F5914-900 SpinScrub Upright Vacuum: Is it ok to use the hoover steamvac on tile floors...
Yes, your Steam VAc will work on tile floors. You'll want to remove the rotating brushes and install the Bare Floor Tool attachment - Hoover part number 48417003
May 16, 2010 | Hoover SteamVac F5914-900 SpinScrub...
I have a Hoover SteamVac SpinScrub. The brushes
If the speed control switch on the hood is in the On position, it would appear the drive mechanism for the brushes is not spinning internally. The drive mechanism could easily be replaced by a technician.
Oct 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Agitator brushes wont turn even after cleaning
the brushes will not turn even wen the switch is turned on
Aug 10, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Brushes won't spin on FloorMate
you need to replace the belt or make sure the brushes are locked into place.
Jun 18, 2009 | Hoover H3030 FloorMate SpinScrub 500...
How to clean my Hoover steamvac brushes? or
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Press all four latches (B) and pull brush
block out. The brushes can be cleaned
under running water
Godbless
Jun 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover spinscrub
First do they turn easily by hand? Usually there is a plastic shaft that drives these brushes. If they are "seated" properly, the unit will not turn. The shaft is usually a "male" and fits into a "female" opening. If it is installing correctly, then I would see if any belts are off.
Jan 17, 2008 | Hoover V1 SteamVac SpinScrub Vacuum
Hoover Sping Vac
Finally after at least 10 more attempts with the brushes and the lint screen and several words to make a sailor blush, The brushes started to spin again. Not sure what did it.
Nov 17, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SpinScrub Carpet Cleaner
I was having the same problem, the black seal under the tank that captures the water was broken, and it wasn't getting any suction.
Nov 05, 2007 | Hoover V1 SteamVac SpinScrub Vacuum
Hoover V1 SteamVac SpinScrub Vacuum Logo
1,933 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
