Question about DeLonghi DC312T 14-Cup Coffee Maker
The coffee pot steams so much it is melting the paint off my cabinets, and it is about 7 months old. I have cleaned it out with vinegar and it still steams....Theres a window in my kitchen it steams up when I make coffee...Any suggestions?
As explained in a couple of other blogs, the thermostat fuse usually opens up when it exceeds a certain temperature, however in your case it seems to have shorted out, beleive if you replace this item, which is located on the heating element thru bottom access(base of Coffeemaker)that might solve your problems, cheers. . .
Posted on May 05, 2010
Clean iron?
Hello tcant....
  • 1 Fill the iron's steam receptacle with white vinegar or CLR, a product used to clean coffee pots. CLR is available in department stores.
  • 2 Plug in and set the iron to its steam setting.
  • 3 Operate as usual. When the vinegar or CLR begins to steam, operate the iron as you would normally. Press it over an old, clean towel as the vinegar or CLR loosens sediment and dirt from the appliance.
  • 4 Continue ironing until all of the cleaning solution has steamed out. Repeat the cleaning process if necessary until the iron no longer oozes discolored liquid and the ironing surface is clean.
  • 5 Fill the iron steamer receptacle with distilled water and set the appliance to steam.
  • 6 Continue steaming until the smell of vinegar or CLR is gone.
  • 7 Prevent future mineral buildup by using distilled water for steam in your iron, rather than tap water. Joe. Thanks for choosing Fixya!
  • Jan 12, 2011 | Black & Decker ICR250 Iron with Auto...
    I have a Mr. Coffee model JHX33 coffee maker, and have lost the owners manual I need cleaning instructions. Can you possibly help me?\r\n Thanks Eddie Thatcher
    mcdevito75 here, I too have a Mr. Coffee, coffee maker 4 cup. The instuctions shold be just about the same for both our Mr. Coffee mavhines, ------ With a new or clean filter in the machine fill the pot 3/4 way full of White Vinegaar the pour that into the resovior, place thepot back in place on the machine and start the machine up, let the vinegar cycle thru, when done the vinegar is now in the pot, empty the pot back into the resovoir, and cycle again, this time 1/2 way thru the cycle or pot half full stop the cycle for 30 mins. this will keep the vinegar in the machine and claen all the little ports. After 30 mins, complete the cycle. repaet this 2 more times. Then repaet once the machine is cool but this time use plain water, repaeat plain water cycle 3--4 times to clean out all the vinegar, Mr. Coofee needs claening when you notice coffee brewing has slowed down or maCHINE STEAMS TOO MUCH DURING BREWING CYCLE.
    Jun 19, 2010 | Juicers
    I put in 12 cups of water and only 4 cups come out with coffee what is wrong with this. It is only one month old
    This occurs occasionally if the unit needs cleaning or you are brewing a new pot of coffee immediately after emptying a hot pot of coffee.
    Run a cup of vinegar through the coffee maker twice, run at least 2 pots of clean water through to rinse the vinegar out.
    This should clear the problem until it needs cleaning. The suggested frequency of cleaning is every 30 pots, but this varies depending upon the type of water you use.
    Nov 16, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
    DCC-1200 coffeemaker cleaning button flashes constantly after it starts,slowly makes coffee and is strong and lots of steam. I have cleaned twice with vinegar solution. What should I do. The coffee maker...
    Make sure that when you do the vinegar solution, you do at least 4 cups of white vinegar, and fill it up the rest of the way (max fill line) with water. The manual says to "fill to capacity with a mixture of 1/3 vinegar and 2/3 water," which lots of people misunderstand, and think it means "1/3 CUP vinegar and 2/3 CUP water," which is not the case. It means 1/3 of your 12 cups (and 1/3 times 12 is 4 cups) of vinegar, and 2/3 of your 12 cups (aka, fill it up the rest of the way) of water.
    You might have to let it soak for an hour before you try to brew it--this lets the vinegar work at the calcium buildup a LOT better (kind of like soaking your pots and pans before you try to clean them), but it should definitely work for you. If not, call Cuisinart's tech support (1 800 726 0190) and they might be able to get you a replacement :)
    Aug 21, 2009 | Cuisinart DCC-1200 Coffee Maker
    Brewing time is too long 20 min for 6cups
    You have an obstruction in the feed line to the heating element. I found coffee grounds before the check valve. I had to take the bottom off it which I am sure the manufacture wouldn't approve of but I was at my wits end and ready to toss it. I just brewed a full pot 10 minutes!!!
    Aug 18, 2009 | Cuisinart DCC-1200 Coffee Maker
    Cuisinart automatic grind and brew
    Clean it out with vinegar and water - 2 ozs distilled white vinegar, 2ozs water
    Dec 08, 2008 | Cuisinart DCC-1200 Coffee Maker
    Water steams away and nothing drips into the caraffe
    I had this problem too and finally found a fix for it.
    I don't know if the cause of this issue is the same for everyone experiencing the problem, but the issue for me was hard water. The fix is to run vinegar mixed with water through the machine quite a few times, until it starts to run normally.
    If you do have hard water issues, it's recommended that you run vinegar or citric acid through the machine about once a month, to keep deposits from building up.
    Feb 15, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
    Cleaning light came on and lost manuel on how to clean it
    1 part descaler 1 part water put that in our water container stsrt it up rince very good especialy if you use descaler . descaler is better than vinegar descaler melts the calcium vinegar remove calcium in little piece thanks for using fixya pierre
    Feb 13, 2008 | West Bend 56860 10-Cup Coffee Maker
    Cuisinart Coffe Maker has no power
    vinegar is not the best thing descaler vinegar remove calciumin little piece that might block thr rest of machine descaler produit melt calcium 1 part solution 1 part water fill the water tank start machine leave it running for few second turn off for 15 minute and repeat untill empty dont forget to rince the machine very good that stuff is very corosif but does the jobs thanks for using fixya pierre
    Feb 09, 2008 | Cuisinart DCC-1200 Coffee Maker
    TAKE 45 MIN TO MAKE A POT OF COFFEE
    you said you clean it you use vinegar or decalcifier vinegar remove calcium in piece it might block the orifise if you use decalcifier it melt the calcium 1part solution to 1 part water dont forget to rinse very good that stuff is nasty cheers
    Jan 23, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
    DeLonghi DC312T 14-Cup Coffee Maker Logo
    144 people viewed this question
    Top DeLonghi Coffee Makers & Espresso Machines Experts
    Henry  Thomas
    Henry Thomas
    Shehu Pro
    Shehu Pro
    Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
