Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Futura ce 200
When I hook up the embroidery unit nothing starts woking. I have un hooked it and re hooked it and still nothing happens.
  • Cindylem May 15, 2008
    My carriage will not move on the embroidery machine.
Warning - undertake this fix at your own risk as it will probably invalidate the warranty.
The problem is a bad connection inside the embroidery unit - there is a small plug that joins four sets of wires that comes loose.
1) disconnect the embroidery unit
2) Turn the unit over and remove the posidrive (crosshead) recessed screws on the bottom. ONLY remove the recessed screws NOT the ones holding the catch to hold embroidery unit to machine. ALSO DO NOT remove the one screw that is different (it has different head that allows a flat screwdriver as well as a posidrive)
3) Carefull turn unit back over
4) With the enbroidery unit facing you there is a screw facing you in the white cover of the hoop holder. Remove this screw and carefully remove the plastic cover.
5) On the underside of the hoop holder nearest you there are two black screws that are undone with an allen key. Remove these (they allow the main cover to come off
6) Pop out the long plastc cover under the hoop holder (where the ting moves back and forward)
7) Pop out the section of cover behind this that is now loose.
8) Carefully tease off the main cover. IT will come with patience and by moving the embroidery arm back and fortht to give space. DONT FORCE IT.
9) You will see the rails running left to right that the hoop holder moves on. Under these you should see four wires, that are joined to four other wires by a connector.
10) Wobble the connector to get them to connect again
11) Connect the embroidery unit to the machine and switch on.
12) If the carriage goes to the start position you have restored the connection. Secure with insulation tape
13) If not switch off, wobble, switch on unitl it works
14) Disconnect and replace covers.
Good luck. This sorted out our machine that just moved the carriage the wrong way and flashed red 88
Posted on Aug 27, 2009
I had the same problem and found that the feed dogs must be in the lowered position otherwise nothing will happen,remove the embroidery unit and check the selector and try again,
Posted on Jun 28, 2008
My futura ce 200 quantum embroidery machine is all set up to embroider and the green light is on when I push to start nothing happens. When I push the back stich it goes back to the orginal position and...
Change the fuse in the plug failing that it could be the inline fuse inside the machine normally near where you plug the lead in, if youcan get to that it is a matter of changing it, and the Hoop must be detachedwhen powering on! Otherwise it will not start. Hope this will help you. Good Luck.
Jul 20, 2011 | Singer CE-200 Quantum Futura Computerized...
Which format should I use for my Singer futura CE-200 when I download embroidery deisgns
The Futura should run any format program but its dedicated program type is XXX so if you have that option I would use that one.
Jan 18, 2011 | Singer CE-200 Quantum Futura Computerized...
Singer futura ce-100 wont start
Do you still have the embroidery arm attached? If you do, the sewing function of the machine won't work.
Mar 24, 2010 | Singer CE-100 Futura Computerized Sewing...
Machine won't recognize embroidery unit
Isnt their something in the way of the chips that connect the embroidary arm to the machine
Mar 04, 2009 | Singer CE-200 Quantum Futura Computerized...
Singer ce100 start button
Hi Vanessa,
Please give me more info in order to help you. Are you trying to use the embroidery unit? If yes, did you send a design to the machine via your computer?
Oct 27, 2008 | Singer CE-100 Futura Computerized Sewing...
Learning to operate my new singer futura ce - 150 sewing machine & embroidery unit and can't get to work
Aug 11, 2008 | Singer CE-100 Futura Computerized Sewing...
I recently bought a Singer Futura CE-200. I was using the embroidery function, but had to stop due to threading problems. When I went back to the computer a few days later my computer was shut down. I...
Wow, I finally get to have a solution.
1. Turn the machine off.
2. Remove the hoop.
3. CAREFULLY slide the bar on the embroidery unit to the left.
4. CAREFULLY slide the piece where the hoop attaches toward you.
5. Turn on the sewing machine. The machine should take the unit to "standby" with a click.
6. Attach the hoop with the power on.
7. Exit the Futura software.
8. Restart the software.
This "should" fix the problem, however, you may have to repeat this process more than once to get it to "stick".
Jul 25, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer futura CE-200 Can not wind the bobbin thread
In embroidery mode, you have to send a design to the machine before the bobbin winder will work.
Jan 30, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer Quantum Futura CE-200 Problem
My machine did the same thing. I had several frustrated nights ans then it just started to work. Some suggestions that I had was that there may be dust where the units connect. Not sure what I did, but it worked.
Dec 27, 2007 | Singer CE-200 Quantum Futura Computerized...
I have had the same problem with my machine as well. have you tryed, keeping it hooked to your computer while sewing, even if you are not using your embroidery unit it still needs to be hooked up, that seems to have helped some with the beeping.
Feb 10, 2007 | Singer CE-100 Futura Computerized Sewing...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
219 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
