Question about Craftsman 25cc Gas Line Trimmer
Trimmer runs with choke on, but quits as soon as you turn choke off??
    Brigadier General:
  • 3,917 Answers
Its cause old fuel will crystallize when it is left in tank for a long time which ends up in plugging up ports and fuel lines and builts small screen in carburetor.Fuel lines will dissolve clogging carb and also the gas will evoporate leaving the oil behind clogging up carb.So you have to remove the carb and clean out,replaceing gaskets or fuel line.For that you may use carb cleaner and make sure to note where the fuel line goes.The fuel filter broke off of fuel line and letting debris get in carb plugging it up also the muffler is known to clog up a lot on these machines where they runs. However the compression should be 60 to 120 lbs any thing below 60 is junk. When adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow untail machine runs also you need to check for spark by removing plug and grounding aginst engine to chech spark.Fittin a new spark plug is suggested and if you are going to make these repairs use new fuel line and filter .
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Posted on Apr 28, 2010
Will not stay running
How dose it run with choke on Half? I would try adjusting adjusting air fuel mixture, but make sure you have clean air filter in it before any thing else.
Mar 29, 2014 | Ryobi 22 in. 26 cc Gas Hedge Trimmer...
My lawn trimmer stalls out after running for several minutes
id Check the spark plug. If the electrode on the plug is worn , id replace the plug. Make sure you check the gap on the plug before, you install it. Id also check to see if the air cleaner is dirty, or not. If the air cleaner is dirty the engine can't breath. Is the gas old that's in the trimmer? If it is dump it out, an replace it with new gas/oil. Are you sure that you mixed the gas/oil correctly? Is there a choke button on the trimmer? Make sure that after you start the trimmer,an it warm's up a little you shut the choke back off.
Jun 01, 2012 | Garden
Ryobi CS30 Trimmer starts and runs in full choke and half choke but stumbles and stalls on run. Not up to full rpms when in full choke and half choke....
You probably need a slight carburetor adjustment. Try to turn the L mixture screw (the one near the bottom of the carburetor on the air filter side, closest to the engine) 1/8 to 1/4 of a turn counterclockwise. These mixture adjustment screws ( L and H) have odd heads on them and conventional tools won't turn them. I use an automotive type plastic wire connector (around 22 gauge) with a ring terminal end which I can hold. Tap the plastic end of the wire terminal connector onto the head of the screw with a small hammer and this will enable you to adjust the L screw. This adjustment will increase you high speed side and possibly allow it to run off choke in a regular manner.
May 21, 2011 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Manual for a craftsman weedwacker model 31679108
Trimmer Starts but stall out as soon as throttle is used and choke turns off. if I hold the throttle and pull the choke it runs but will stall as soon as choke is let go.
Jan 31, 2011 | Craftsman 27cc 2 Cycle Crank Straight...
My Ryobi trimmer quits running after I turn choke off and pull trigger to speed it up
run it with chock on half way it will start running better after a wile
Sep 20, 2009 | Garden
Trimmer won't stay running
Most likely needs the carb rebuilt.
First check the prime bulb and fuel lines for cracks. Check the spark arrestor for carbon buildup.
Another problem could be a stuck piston ring, but try rebuilding the carb first as it is usually the source of the problem.
Aug 02, 2009 | Homelite Mighty Lite Lawn Trimmer
Stalling out
Generally with two cycle engine as soon as the engine starts the choke needs to be moved to the off or open position. Some chokes have a middle position that lets the motor run until it is warm enough to move the choke into the open position. In other words weather it is a two or four cycle engine the choke is used only to start the engine. If you unit is newer and still does not run well with the choke in the open position, you may need to adjust the hi-speed circuit to a richer one.
Jul 13, 2009 | Troy Bilt Tb70ss Gas Trimmer
Gas Trimmer will not stay started
Many times with a gas mix, after sitting for a while, the mix separates and gums up the carb. Taking the carb off and soaking it overnight in a parts or carb cleaner and running carb cleaner through the tank and gas lines will cure this.
Jul 02, 2008 | Ryobi 15" Electric Factory Reconditioned...
My straight shaft trimmer will idle but dies when the I pull the trigger.
Apr 03, 2008 | Ryobi 15" Electric Factory Reconditioned...
Craftsman 25cc Gas Line Trimmer Logo
41 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
