Question about Edirol UA-4FX External Sound System
Audio card won`t work under XP
I put up P II 333Mhz of some parts given to me by a friend. I think Mboard
is with BX chipset, and I bought some 256 SDRAM and an audio card with Opti 82c931 chip ( all of this parts were secondhand ) ,and made myself dual-
boot with W98 on C and XP on D partition. Also found drivers for audio card for
W98 on internet ( and it`s working fine ) but all the drivers I`ve tried for XP wo-
n`t produce anything but some hushed noise, and XP refuses to "see" the ca-
rd as mounted hardware. Card is in ISA slot, could that be the reason? Is the-
re any solution or workaround to this or should I simply throw in few more bu- cks and buy me some PCI audio card?
  • 93 Answers
Xp can cattier for some isa and eisa slots
but quite a long shot for the driver to be honest
price and time wise it would be best to get a new or even second hand pci card
sorry i cant help you any further on this but its the best option
Posted on Mar 24, 2008
SOURCE:
I bought a second hand HIS ATI RADEON 4670 1gig agp, we test it first and works fine also in my pc, then after 1 week used the video card shows no response to my monitor totally blank screen so i had to...
The card could be failing. Try checking that the fans are turning on the HIS when computer is on. Also make sure the heatsink under the fan is fully touching. The card may think it is overheating so check all the connections under the cover on the HIS card
Thanks for using FixYa
May 21, 2011 | ATI Computers & Internet
Just installed xp for a friend on an old ibm netvista 6794 NZU pc. Went to ibm website but can not find the motherboard or chipset drivers to allow this pc to acess the internet. Can anyone help please. ...
It's a big pain when you dont have the right driver. but try this:
1. download and install the Windows Service Pack 3 (XP SP 3) in the computer and check if it works.
and how are you trying to connect to the internet? you might just want to put in an extra PCI network card, if you want to use the broadband or if you need the usb ports to work, try a PCI USB card instead.
either ways, make sure you have installed SP3 in that computer.
cheers!
Nov 17, 2010 | Computers & Internet
My audio says "no audio driver" where can I find one, and how to I install??? Thank you so much.
If you run Win OS try ro update driver via PC manage.
right click:1- ->my Compuer
                  2- ->Click on Device manager
                      3-->Click ->Sounds Video & game controller.
                               (here look for a yellow symbol if present  you  have a problem with the driver )
                            4- Look at the mboard to see if you can find an obvious brand andmodel number printed on the mboard, usually in larger characters, oftenbetween the slots - if you see that, tell us what you found.
2.look at the cards in the slots to see if you can find anything thatlooks like it might be the brand, a model number - if you see that,tell us what you found. You may have to remove the cards to examinethem properly
3. look at the labelling on the largest chips on the mboard.
If you see VIA - go here - choose Chipset or Platform Drivers:
http://www.computing.net/hardware/w...
If you see Intel,
go here and download the utility to identify your chipset:
http://www.intel.com/support/chipse...
Once you have identified the chipset, go back to that same web page, and click on the link to drivers for your chipset.
Usuallyyou need to get at least the latest INF Update utility, and the latestApplication Accelerator. If your Intel chipset has integrated (onboard)video, video drivers will be listed - in that case also get the latestvideo drivers.
If you see NVidea, go here, choose Platform/nForce Drivers:
http://www.nvidia.com/content/drive...
Oct 03, 2010 | Northgate (STAX2517C2) PC Desktop
Powercolor Radeon 9550 R96 256mb Card - Lights on, noone at home!
Depends on the video card ,it might require more power ,200w is fine for onboard but add other components and the system needs more power.
Disconnect the harddrive or CD ROM drive and see if the system will start.
If it starts then you will need more power 300-400w at least but shuttle power supplies can be expensive to get.
May 18, 2009 | Power Color RADEON 9550 R96-LC3 (128 MB)...
I wiped clean the windows me that originally came on it.i did a fresh install of xp with service pack 3.i also added 256 mgb stick of ram to the 128 that it allready had.i bought a 400 gig external to make...
install all the latest drivers for your computer from the manufacturers website for the motherboard ( chipset drivers ) the graphics card ( which will help with the display ) and your network card and anything else you need to install driver wise.
This will allow your operating system ( windows xp sp 3 ) to know how to use or communicate with the hardware devices ie graphics card, motherboard etc.
Apr 11, 2009 | Sony Computers & Internet
OptiPlex GX270 mini tower
Remove the 256mb memory and insert the 512mb memory in slot1 and see whether it works. Please note that the memory needs to be in pairs.
I think the GX260 is mini tower has two different moles
1) PC3200 compatible with memory - 184 Pin DDR3200 400MHz
2) PC2700 compatible with memory -184 Pin DDR2700 333MHz
Please enter the service tag on dell.com and find the manual and the right memory for your PC
All the best!
Dec 17, 2008 | Dell OptiPlex GX270 Small Mini-Tower...
When I am trying to load OS XP it is not working, but the system is running well with Win98
i think the hard disk might have got crashed or the cd from which your installing may consists some error (or it is unreadable ) ...
just try with other cd ....
or you might have installed some upgraded version of windows than the XP just for example :vista or media center etc .....
or you might be trying to install the XP in the drive which consist of the upgraded version of windows than the XP ....
just check these things and reply me ...
and tell me the what exactly error message you are getting while you go to install the XP ...
any doubts you can reply me
i am always here to assist you..
thank you
bye ..
rate my solution
Jul 08, 2008 | Intel Motherboard
I had lOADS of problems with my new PC (Vista) so my friend who was apparently a "computer expert" told me the best thing to do was KILL Vista and put on XP. As he builds his own PCs etc... I...
link
download and run everesthome. Click on the motherboard on left column, click on chipset, click on sothbridge chip set in right column. Google the chipset or audio controller for drivers or email me, [email protected]
Apr 10, 2008 | Computers & Internet
Will hellgate london work on my pc
These are the system requirements:
OS - Windows XP/Vista
Processor – XP: 1.8 GHz or faster / Vista: 2.4 GHz or faster
Memory – XP: 1 GB RAM / Vista: 2 GB RAM
Hard Drive – 7 GB (14 GB required for Digital Delivery)
DVD Drive – 8 SPEED (not required for Digital Delivery)
Video Card – 128 MB with Pixel Shader 2.0 support*
Sound Card - DirectX 9.0c compatible
DirectX - Version 9.0c (included)
Online Multiplayer – 512 Kbps or faster
Input - Keyboard, Mouse
This download is not supported on FAT16 and FAT 32 file systems.
*Supported chipsets: NVIDIA GeForce 6200 or greater (GeForce 8800 recommended for DirectX 10); ATI Radeon 9000 or greater. Laptop versions of these chipsets may work but are not supported. Updates to your video and sound card drivers may be required.
I think you'll need a better Video card.
Nov 17, 2007 | Dell GX270 P4 256/40/48X/XPP/NONE...
Unable to install Windows xp
If you can afford it i'd look at trying another stick of 256 or a new 512 stick, XP doesn't really like anything under 512 and it pretty much won't run at all with 128, so if you can get it cheaply try that first if that doesn't fix it let me know
Oct 30, 2007 | AOpen MK77M-II Motherboard
Edirol UA-4FX External Sound System Logo
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
Ben Armstrong
Steve Allison
Steve Allison
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
