Question about Kenmore 23913 Progressive PowerMate Bagged Canister Vacuum
The motor in my Powermate (Kenmore Canister 116.27614700) is whining, high pitched, but still works. A local shop told me the motor is dying (the one in the Powermate that drives the beater bar) and would cost $150 for them to repair. The machine is only 1.5 years old and I paid $300...yikes. I think I can fix it but don't understand why the foam gasket that apparently wraps around the motor costs as much as the motor. This is assuming that part 32 (ks747156) is the foam I see glued to my current motor. Is there a cheaper gasket solution? Also, Sears doesn't appear to sell the wire connectors anymore. Can I buy them elsewhere? they look like they crimp (not twist on like household electrical). Thanks!
  • 1 more comment
  • kerry_crocke Apr 28, 2010
    Thanks!
    I've tried to see if I can peel off the gasket from the current motor. It seems pretty well glued on and I suspect the foam will just tear.
    Is there an alternate gasket solution? Some foam meant for another purpose? What does the foam do? What would happen if I didn't have the foam?
    Also, any gotchas I need to look out for while doing this, because it looks pretty straightforward (and I'm pretty handy)?
    Good stuff so far!
    Thanks! I may try to get that foam off some how and reuse it!
  • 755 Answers
I think you are right! Buy the motor.....use the gasket from the old motor if you can cut it off clean and just glue it on the new one.
The connectors are just brass blade connectors which you should be able to get at a Home Depot or Lowes in the electrical section. Or...just cut off the old connector AND use wire nuts to connect them to the new motor *(which assume comes without any kind of connector right?).
That should do the job for the cost of a motor...a little glue and two wire nuts. Good call!
Good luck and be careful!
Posted on Apr 28, 2010
  • john andrew manchook Apr 28, 2010
    The foam serves a couple purposes. One, it keeps the vacuum path sealed so that the vacuum is sucking up from the rug and not out the motor mount. Two, it also minimizes vibrations that occur as the beater bar load changes. That vibration is damaging to the motor over time.
    If the foam seems a bit flimsy maybe you should just get new foam. That may have contributed to its early demise! Otherwise you can cut on the glue itself to get as much foam away from the old motor as possible. I can't think of a cheap analog to the insulation foam offhand. I think whatever you use has to handle vibration and some heat stress.
    Any gotchas eh? Good question. I think you have it all covered my friend. The motor is designed to turn in only one direction using AC power so the wiring shouldn't be in question. If it turns out to be a DC motor than it will be polarized and you should be careful to match up the wiring colors correctly.
Where can I get part # KC38KCEN1000 HEPA FILTER FOR MY KENMORE CANISTER
I would think you should be able to get it at your local sears store or go online to www.partsdirect.com
Feb 27, 2012 | Kenmore 23913 Progressive PowerMate Bagged...
I have a kenmore vacuum, Series 116-23613300. four years old. It is emitting a high pitch squeel. I have checked and the hose is not clogged, I have put in a new bag and I have washed the foam filter. ...
If the squeal is coming from the canister portion of the machine, then you most likely have a fairly serious motor/fan problem. There are no moving parts on that machine other than the fan/motor assembly in the canister.
A local service center could confirm that. You can try to get a free quote if they offer such a service. Many may charge a fee even for diagnostic work.
If the noise is coming from the power-head, then there are multiple possibilities ranging from bad brushroller bearings to failing power-head motor.
Apr 04, 2011 | Kenmore 25512/ 25513 Progressive Canister...
How do I gain access to the motor of an Electrolux 2000 canister vacuum. The air intake on the motor must be partially blocked as there is a loss of suction and the motor makes that high pitched whine like...
Dismantling the vacuum probably won't help much, and reassembling can be a bear.
To check the intake, remove bag and look into bottom of bag well. It there's a filter there, remove it and check intake at bottom of bag well. Clear if there is.
The afterfilter on a canister is located beneath the air diffuser grid on the top of the machine where the tools can be attached. Remove this cover and there should be a white filter. Yours is probably black, or at least real dirty, if it's never been changed. This also blocks the airflow, reducing suction, and potentially damaging the motor. Extremely dirty filters are an indicator of how much dust is getting into and through the motor. This is usually caused by using generic bags rather than the genuine Electrolux, now Aerus, bags.
It is also an indicator of another internal problem on some other Aerus and pre-Aerus Electrolux vacuums.
Sep 10, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Motor slows down and makes burning smell
If the noise is coming from the canister motor, you probably have bad motor bushings. I had the same problem, replaced the motor and all was fine - only for one year. The problem is back and is due to the fact the motor is very high speed (to get good suction) and should be made with bearings, not bushings. I will not be repairing a second time as a $70 motor annually is a bit pricey, and yes it will get VERY hot. I will buy a new vacuum - not another Kenmore.
May 25, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Power head for Kenmore Canister Vac
Another potential problem for the increase in difficulty in turning the beater bar (drum) could stem from extremely dirty bearings, located at each end of the beater bar. I've seen hair knotted up to the point it chokes the bar and significantly reduces its ability tpo turn.
Mar 11, 2009 | Kenmore Whispertone 29512 Vacuum
Brush does not turn on my vaccum
If there is no suction when you disconnect the beater bar assembly near the hand hold where you grab the vacuum, then there may be either a restriction in the vacuum line between there and the vacuum section (that rolls around behind you), or the vacuum line from the handle point to the rollaround section is not properly connected. This all assumes the vacuum motor in the rollaround is running.
The beater bar section does nothing but cause dirt particles to be sucked into the vacuum system. The vacuum or suction is created in the rollaround unit.
Jan 22, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Motor on the powermate keeps cutting in and out.
If your talking the motor on the beater bar, then chances are either when the beater bar was attached to the hose near where you hold it, it did not lock, and the connection is intermittent, or the cord has an internal break.
Jan 22, 2009 | Kenmore 22313 Bagged Canister Vacuum
Kenmore 23913 Progressive PowerMate Bagged Canister Vacuum Logo
87 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
