Question about Acer AL1716 F Monitor
It display acer logo, and then goes to totally black, switch light flashing green, won't be turn on or off? is it fixable? or I need a new monitor?
  • 11,361 Answers
Look for bad caps (bulging tops) inside, please see my pictures:
http://s807.photobucket.com/albums/yy352/budm/ACER%20AL1716/
Please post back what you find.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Apr 28, 2010
Monitor comes displays Acer logo and goes black after 3 seconds, with indicator light still green.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 18, 2010 | Acer AL1916W 19" LCD Monitor
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
My acer AL2416w monitor turns on to a black screen
I have 2 Acer AL2416W monitors that i have been using for 2 years. There has been a handful of times i would turn my computer on in the morning and the screen would be black and Acer would lightly flash on the monitor 1 time. Typically a restart would take care of the problem. Last week the monitor blacked out and i can't get it to work. Any suggestions?? I switched ports on the computer to verify it wasn't the video card and tried new DVI cables to verify it wasn't those? Is this fixable??
Sep 06, 2009 | AcerView 77E 17" CRT Monitor
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
At power up tv displays Acer logo then goes to black
will not turn off power with out unplugin it
Mar 01, 2009 | Televison & Video
Acer AL1914 black screen, green light
it sounds like a deleted driver? try getting the driver for the monitor, did you loose the Operating system at some point, if so try a system restore to a date when the computer was working properlly prior to the malfunction. It sounds like it restored you to a time before the driver for that monitor was installed.
Feb 16, 2009 | Acer AL1914B Black 19 in LCD Monitor
Monitor repeatedly flashes Acer logo and computer display in cycles
We had the same problem with the 17" we bought in Aug. Sent it back for repair. Acer sent it back without fixing the problem. Started doing it again in Nov. This time I called a supervisor and they sent me a new monitor. Well yesterday it started doing the same thing. You can fix it temp buy unplugging it and holding down the on-off switch for 30 seconds. Please let me know if you have a better fix.
Dec 13, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Acer AL1716 F Monitor Logo
195 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
