Question about Pentair Fns Plus 48 sqft De Pool Filter (In Ground Pool)
My Pentair FNS 48 is having problems. I have a kreepy Krauly that will have strong suction when pool pump first turns on but then it weakens after about 4-5 mins and then completely stops. I've tried to open the air relief to see if there was air stuck inside and the valve opens but does not spurt water no matter how long it's been open. I tried to open it just as I turn on the pump and it does spit out air and then steady stream of water (no where as powerful a stream when I did this a few months ago). The gauge does not register at all. I ordered a new gauge, followed instructions on installation and it still does not register any psi. Can you tell me what I should be looking for? I recently took the filter apart to spray clean the grids and added 4.8lbs of D.E. Do you think maybe I damaged something inside? If so, any idea what it could be? Incidentally, we've just had a couple of windy months and the pools been heavily leafed filled.
  • tweety868 Apr 28, 2010
    I've clean around the impeller and just snaked the hole that goes from the intake and was able to remove some large leaves. I started the pump again and the gauge is not register anything. Doesn't move at all. The pump has now been on for 10 minutes and it is slowing down again. I open the air flow and no water is coming out. As I am writing this, the kreepy krauly has stopped moving.
  • 990 Answers
You can try to clean the impeller ether by removing the pump basket and reaching inside the hole behind it to feel for a clog. Do this with a screwdriver or needlenose plier. If it feels spongy work the clog counterclockwise and then try to pull out with the pliers. Hlso if you have had a alge problem since you cleaned the filter you may need to clean it again. Also you need to kill any alge before you run the pool.
Posted on Apr 28, 2010
  • Kieran Ruppert Apr 28, 2010
    Your air pressure is not the problem that is probally just a clog in the air bleed "T". If you pulled junk from the impeller and it is doing this still you may need to break the pump down and clean the impeller out by hand with a piece of wire. For this you should have a tank body "O" ring on hand as the old one will be hard to seal again and you will probally need the new one. Also pick up a new pump basket to keep this from happening again. Also you may need to check for a clog in your suction pipe.
2 Suggested Answers
SOURCE: KREEPY-KRAULY Ties itself into a knot while cleaning.
Solution:
We removed 2 portions of hose located at the Krauly end, and attached those at the filter end, then we took the 2 portions located at the filter end, and placed those at the beginning of the Krauly end.
Apparently the problem was that the 2 portions of hosing at the Krauly end had become "twisted" and continually enabled the Krauly to move in the knot tying direction. By replacing these 2 portions at the Krauly end with "un-twisted" portions from the filter end, this ended the twisting cycle.
The Krauly has been running for 48hours straight now without a single knotting episode.
If we see the knot tying direction beginning again, we will repeat these steps, continually replacing with un-twisted portions.
At 1st we thought we needed to purchase some new tubing, but we didn't have to, only needed to move around some hosing.
Posted on Jan 05, 2010
Kreepy Krauly has very little suction thru head but plenty thru hose
most all pool cleaners generate there motion with a thing called a venturi ! thats inside it usually moves a small propeller from the action of water being sucked hard thru the hose , on most the path to this "propeller" is different than that of pool debris , i suspect this alt path is part ways blocked , a simple way to clear is to connect garden hose to suction port of cleaner and force water Back in other direction other than that sometimes dissasembly is need to lube and clean hidden ports inside
Jan 04, 2014 | Pentair Kreepy Krauly Inground Automatic...
Kreepy krauly regulator valve won't close, it's always open so the cleaner doesn't move. There's plenty of suction,
It has debris stuck in it. Normally it is not too hard to clear it out. If you can't clear it, try to run the Kreepy without the regulator.
Aug 04, 2013 | Pentair Kreepy Krauly Inground Automatic...
Kreepy kraully not cleaning complete pool
If the pool hose has been connected to the Kreepy Krauly in the one position for a long time, the pool hose gets set is a position so the kreepy Krauly travels ith same path all the time. Try rotating the pool hose 90 degrees and or change the angle of the hose connector in the skimmer box.
Mar 07, 2012 | Pentair Kreepy Krauly Inground Automatic...
Low filter pressure
First, check for debris in the filter and pump strainer baskets. This can commonly cause these pool cleaners to get poor suction. Also, check to ensure that the main drain and all suction lines are closed, except for the suction line to which Kreepy Krauly is attached.
May 02, 2011 | Universal Kreepy Krauly In-Ground Pool...
I have great water pressure in my pool, but the minute I attach my Kreepy Krawly, the pressure drops and there is a large vacuum in the pump reservoir. the Kreepy hardly moves at all thereafter.
It sounds like your you might not have all of your suction lines closed. Check to ensure that the main drain and all suction lines are closed, except for the suction line to which Kreepy Krauly is attached. If this is not the problem, it could be that the pool pump and filter system that you have may be too small It should be capable of providing at least 25 gallons per minute. These are common issues with these pool cleaners.
Feb 02, 2011 | Universal Kreepy Krauly In-Ground Pool...
My Kreepy Krauly won't move. I've checked the hose for holes and also replaced the vinyl suction cup on the bottom but it won't budge. Doesn't appear that there is much suction. Could it be something...
Yes, it could. Check the filter and pump for debris. This could severely restrict movement in these pool cleaners. Also, check the flaps of the Kreepy Krauly for debris. Also, check to make sure that the main drain and ALL suction lines, except the one the cleaner is attached to, are closed. This might also be why you have a lack of suction. My final suggestions would be to check the return line water flow and make sure that it is strong enough.
Dec 30, 2010 | Universal Kreepy Krauly In-Ground Pool...
Kreepy crawly keeps stopping but nothing is blocked
With Kreepy Krauly pool cleaners, it is usually something blocked so you have taken the perfect first step in finding your problem. You will also want ensure that the main drain and all suction lines are closed, except for the line to which the Kreepy Krauly is attached. Also, if this is a new purchase, it could be that your pump and filter system are too small to properly propel the cleaner.
Aug 13, 2010 | Universal Kreepy Krauly In-Ground Pool...
My kreepy krauly seems to have good suction, but moves very slow. I usually hear a tic,tic,tic,tic, But, lately it has been tic....tic......tic Very Slow
Try these suggestions to get your automatic pool cleaner working properly:
• Check to ensure that the main drain and all suction lines are closed, except for the suction line to which Kreepy Krauly is attached.
• Check for debris in the filter or pump basket.
• Check for debris in Kreepy Krauly’s flapper. Debris may prevent flapper movement or restrict flow.
• Check the hose to ensure there are no leaks.
• Check the vacuum connection. It should be submerged so no air enters the system.
• Check the pump basket lid for looseness, cracks, and worn or missing O-rings.
Jul 28, 2010 | Pentair Kreepy Krauly Inground Automatic...
Our kreepy krauly will not stay suctioned to the bottom of the pool. What can we do?
Check for air leaks in your hoses, your pump or in the plumbing system. Also check for clogs in your pump impeller if you have any problems with your basket. Good luck.
Apr 24, 2010 | Universal Kreepy Krauly In-Ground Pool...
Need operational manual
the manual is available at this web add, thanks be sure to leave a good rating.....
http://www.novem.com.mx/mkreepy.pdf
May 12, 2009 | Pentair Kreepy Krauly Suction Side...
Pentair Fns Plus 48 sqft De Pool Filter (In Ground Pool) Logo
341 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
