Question about Fuji FinePix A345 Digital Camera
My camera accidentally fell and hurt me zoom, now when I go to take a picture and no picture just says zoom error
  • 255 Answers
The lens is moved in and out by a set of gears much like a rack and pinion in a car steering box. What happened is that the lens was pushed in and the gear set has probably skipped a tooth. If the zoom motor cannot move the lens, the microprocessor will flag this problem and give you this error. You may want to look carefully at the lens and see if it is c0cked to one side. If it is, then you may want to attempt to straighten it by grabbing it and gently coaxing it back into alignment. However, there is a good chance that a gear tooth was broken, or there is another problem that won't be able to be fixed by coaxing the lens straight with your fingers. In this case, you will have to send your camera in for service. Good luck.
Posted on Apr 28, 2010
Dsc-s2100
You might want to send your camera to your Sony Authourized Dealer for some technical repair. Since it accidentally fell, there might be a part from your camera that is affected by the sudden hit causing your lense to jammed.
Thank you.
Aug 01, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Zoom error! Gah! What?
Did you leave your lens cap on when you turned the camera on? I did that and got the zoom error. Turned it off and then turned it back on after removing. That helped me.
Jan 11, 2009 | Fuji FinePix S1000FD Digital Camera
Lense on Cannon sureshot
Not really, zoom lenses are pretty fragile and will permanently be damaged when they get a shock. Most probably the guide rails/pins are damaged inside, and it will need luck and patience to glue them in place (and most of the times glue isn't strong enough to keep them together).
Better sell it for parts on ebay and get yourself a new one (most of the times broken fetch half price of used ones). People need different parts (i.e., the mount, motors, aperture assembly), and it is environmentally great to recycle goods for reuse by other repairers...
K.
Sep 15, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Fuji Zoom Error Message
drop it on the floor from a few feet I did this and now mine works
Aug 02, 2008 | Fuji FinePix A820 Digital Camera
Canon powershot SD600
Looks like the lens is "out of alignment". Canon charges heftily for this repair. However if the lens is not broken then many people have got it working through systematic bashing. Click here to view the thread
Jul 16, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lens error, restart camara issue in SD900
Hey GeorgiaPlum,
What is most likely happening is there is damage to the lens or the lens mechanism and you should have the camera looked at by an authorized service technician. I will say that digital camera repairs often exceed the value of the camera, but it can't hurt to get an estimate done. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 05, 2008 | Kodak EasyShare C613 Digital Camera
Pink polaroid i631 camera
Here is the solution for your problem. If you look at your camera at an angle, you will see the zoom lens2_bing.gif is little bent to the side. I want you to put pressure on the cam to snap-it into it's place. After you heard a click, then turn-on your camera. This will fix your cam.
Vicent
Jun 14, 2008 | Polaroid i631 Digital Camera
Dropped my camera canon sd450
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 17, 2008 | Canon IXUS V2 Digital Camera
Zoom error
I just got one from Newegg.com. It was a refurbished item so I knew I was taking a chance. Straight out of the box it gives me a "zoom error" and will not take pics or even display an image. From what I've read about this it is most likely something in the zoom mechanism and needs to be fixed by the factory.
The only thing you can do is send it back to be fixed. I know this isn't much of a solution.
Dec 15, 2007 | Fuji FinePix S5700 Digital Camera
Fuji FinePix A345 Digital Camera Logo
66 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
