Question about Toshiba Qosmio G35-AV600 Notebook
I turn on the computer and run but i dont see an image
    Problem Solver:
  • 12 Answers
Assuming it's your graphics card as i wrote for another post...Put it in the oven dude, I got given one for free and this had the same problem, in the oven and it's fixed just look it up on utube. On top of that believe it or not I've done it several times since as the down side is it needs to keep cool or it goes again, got a cooling pad it has to live on now.
To check that it's definately your graphics card try plugging in a hdmi cable to a tele or hook an lcd, also I had mine running on the onboard VGA card so I could check the resolution rate, should be up around 1900 I think? If not then I would gues it's your card, if you really can't get it to work then you've got nothing to loose, get a manual online for dismantling and in the oven for 10mins on about 180 degrees c.
Posted on May 27, 2011
    Sergeant:
    Champion:
  • 301 Answers
Change the display cable into the machine , or lcd dsiplay , buy en ebay or amazon
Posted on Aug 01, 2010
My webcam is not working....... hp model is HP g60-235DX. somebody help me to sort out this problem.
wow posting with no OS stated, windows what? or linux?
amazing impossible post.
it needs 2 drivers.
usb2, and the cam, no camera runs lacking both in most HP computers.
we are not HP , HP is HP
and your page is here.
https://support.hp.com/us-en/product/HP-G60-200-Notebook-PC-series/3837658/model/3860166
see that?
came with vista or w7 , 32bit or 64bit.
so tell HP what you have and bingo the drivers.
are you internet connected?? for PnP to work you must
if that fails.
see this.
Cyberlink YouCam Software
the ICH9 chip must work first. correctly, under chip set (USB)
id load them all but BIOS. leave bios alone.
or run HP assistant
note they ask you what OS it is.... a KEY FACTOR always.
.http://h18021.www1.hp.com/helpandsupport/hp-self-support.html
Jan 01, 2018 | HP G60-235DX Notebook
It dont load
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Sep 13, 2007 | SanDisk Sansa e260 MP3 Player
My HP Photosmart B110 Series wont scan to my PC. The window kept showing that its necessary to update LCD screen? I dont know what it meant and I dont know how? Please help!
1) Leave the computer on with Digital Imaging Monitor
2) Turn off the printer
3) Disconnect the USB cable
4) Wait for 3 minutes
5) Turn on the printer
6) Wait 3 minutes for computer to update the printer
Regards,
Shrey
May 30, 2011 | Office Equipment & Supplies
How to trasfer pictures from camera D60 Nikon to my lap top
Using the Camera
* 1 Attach the USB cable to the camera. Open the small, rubber door on the side of the camera body and plug the corresponding end of the USB cable into the slot on the camera.
* 2 Plug the USB end of the cable into the computer. Make sure the cable is securely attached to both the camera and the computer.
* 3 Turn the camera on. This will open software to download your images. You will be able to move the images from the camera to the computer and choose whether to remove the images from the card.
* 4 Select the option to download or transfer images. This will depend on what type of operating system you are running and may vary if you are running third-party image processing software, such as software that came with your camera.
Using a Card Reader
* 1 Turn the camera off and remove the memory card carefully.
* 2 Insert the card securely into the card reader slot.
* 3 If necessary, turn on the card reader. This will open the software to remove images from the card and place them onto your computer.
* 4 Select the option to download or transfer your images.
Apr 30, 2011 | Nikon D60 Digital Camera
Hello my problem is when i use my labtop dell vostro 1015 for 2 hours or less or longer than that it being freezing and stucked so in this case i shutdown my labtop directly from the on\off bottom and...
If it freezes very often then try to run a diagnostics on the system.. U can do it by turning on the computer, tap F12 - under advanced boot options select diagnostics and run a complete test.. If you get any error codes then contact dell to fix the issue.. If you dont get any error codes then try to clean the computer by doing disk clean up... If it still hangs then do a complete reinstall of OS.. If you dont have a disk then Dell has a default partition on the computer and you can install with the same..
If you have windows vista on the computer then tap F8 when the computer turns on and then you will be able to see the advanced boot options.. Select repair my computer.. In the repair my computer screen select the dell factory image restore...
Your computer will go through the installation and it will be up and running...
If you have windows Xp then you have to turn on the computer and when the dell logo appears you have to simultaneously press control and the F11key.. You will be able to reinstall the OS in this way
Sep 16, 2010 | Dell Vostro 1015 Laptop
Hello i want to reinstall vista but i have forgotten how to prepare the hard drive first , could you please tell me in the few easy steps how this is done. thanks Paul
If you dont have the dell factory image restore then you have to reinstall the OS using disk..Or call dell @ 18006249896
Sep 02, 2010 | Dell Inspiron 1525 Notebook
Compac presario S5000NX dont start anymore... the pcu is running but see no images
You need to check if the light on the monitor is green on amber.
If its green then you need to turn off the computer, take out the ram, cmos battery, HDD/CD/DVD cables, power cables, and then put them back, this will ensure there is no static.
If still dont work then you need to take the ram out and start the computer, if it beeps then its a video chipset issue. If it will not beep then its you motherboard that has gone bad.
If the light is amber then remove the monitor cable from the computer and see if you get a message on the monitor stating no input signal, if dont then monitor has gone bad, if you get the message, then follow the steps mentioned above.
Regards,
Shrey
Jan 10, 2010 | Computers & Internet
My computer doesn't show the image
1 st check all power connection cable if it not work then.................................emideatly contact u r dealer... dont try to solve it by u r self. u may damage u r computer.. best regards
Oct 09, 2007 | Cornerstone FIC AD11 Socket A ATX...
Transfer images from mobile to computer
i have Nokia 6630..i want to tranfer images from my mobile to pc through USB but i dont know how to connect it & i dont know how to use it..can you help me with this problems?
May 29, 2007 | Nokia Handsfree For 6020, 6101, 6102...
Toshiba Qosmio G35-AV600 Notebook Logo
64 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
