Question about Kenmore Dryers
I have a kenmore 70 series gas dryer that stopped heating
    President:
  • 1,218 Answers
Good day,
There are a lot of items that can cause a no heat condition on a gas dryer. Best to follow a step by step testing procedure to isolate the issue.
Here are items to check. You will need an ohm meter to perform some of these tests.
1. Make sure the gas is turned on to the appliance.
2. Remove the back cover of the dryer. In the center bottom is a small skinny white ceramic device, held on with one screw.
Remove one of the wires, and check it with an ohm meter. It should show zero ohms of resistance. If not, it is defective, and needs replaced. This device on your brand causes 80 to 90% of all no heat problems.
3. As well, there are 3 or 4 other thermostats in the area, either round or rectangular, with 2 wires going to them. Check all of them if needed. They should all check zero ohms.
4. To check the igniter, you will have to remove the front panel. A tutorial follows, on how to do that.
Locate the gas valve, on the left side. Follow it forward, you will see the 2 wires on a plug, and at the tip of the burner tube, the igniter itself. Unplug, and check the igniter leads. It should read about 20 to 30 ohms. if not, it has burned out and needs replaced.
5. On the gas valve itself, are 2 black coils, held on with a 2 screw bracket. They can fail, but cannot be tested with a meter. If they are bad, the heating system will light the igniter, and shut down without firing the gas. All components must be in place to perform this test.
That covers 99.5% of all issues. There are others, such as the timer, heat selector switch, centrifugal switch in the main motor, but are extremely rare.
The tutorial below is not about heat trouble shooting, but is supplied to show how to gain access to the front of the machine.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
This is what the thermal fuse looks like. Common failure item, along with the ignitor.
Posted on Apr 28, 2010
Kenmore 70 series gas dryer - does not start when pushing the start button
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Kenmore 77632 Gas Dryer
I have a kenmore 70 series gas dryer. It won't
Check the thermal fuse and thermostats first, then the ignitor and the valve coils are the next possibilities.
Eric
Jan 24, 2010 | Kenmore 63942 Dryer
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
My gas dryer stopped heating it is a Kenmore 70 series. I am getting good gas flow but dryer will not heat.
Try this link I hope it helps, I know it helped me a ton!! ps don't forget to rank my help. Thank you and have a nice day!
http://fixitnow.com/wp/2004/11/13/mailbag-how-to-troubleshoot-a-gas-dryer-with-no-heat/
May 07, 2009 | Whirlpool LGR3624JQ Gas Dryer
Kenmore 70 Series
The most likely cause is a bad ignitor part number 279311. It has to glow to open the valve and ignite the gas. You should hear a loud click when you first start the dryer. That tells us there is voltage to the gas valve.
Apr 07, 2009 | Dryers
Kenmore dryer 70 series flame ignites, but goes out after 5 mins
If it's gas, the coil valves get weak and are unable to hold themselves open when hot. First, check the exhaust vent. If it's clogged, it can't remove heat and it will shut off prematurely. Most likely the coil valves though.
Mar 03, 2009 | Kenmore 63942 Dryer
Dryer stops working after 10 minutes
Motor may be over heating.may need new motor.
Mar 01, 2009 | Kenmore 73952 Gas Dryer
Kenmore, heavy duty dryer, 70 series extra capacity, not heating
The following link explains how to diagnose a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you require addtional assistance, please let me know. I hope this helps you diagnose your problem.
Aug 12, 2008 | Kenmore 63942 Dryer
Kenmore 70 Series
You probably have an open thermal fuse, the dryer will run in some cases and not heat, Just moving air across you clothes will dry them however it takes forever.
If you are electrical or mechanical replace the thermal fuse yourself if not call someone you trust, you can purchase thermal fuses on line from Sears.com just do a parts search for you specific dryer.
Jun 04, 2008 | Dryers
Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
171 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
