Question about Lexmark JetPrinter Z11 InkJet Color Printer
Could not click link
When i clicked link it says error
    Genius:
  • 3,587 Answers
Get new printer drivers here and get back in connection
Posted on Mar 24, 2008
SOURCE:
How do i fix this
Known as "Not Found" errors, 404 errors occur when a link attempts to resolve to a webpage that does not exist.
When links are "broken" in this manner, search engine rankings can become affected and visitors grow reticent to return.
Luckily, the broken links that cause 404 errors are easy to find and fix using Google's online webmaster resources, allowing you to ensure that all pages display correctly and without error.
Log into Google Webmaster Tools by entering your Google ID and password.
Add your website to your Google Webmaster Dashboard.
Type your domain name (everything in your URL before the first forward slash)
into the Dashboard text box.
Click the "Add Site" button.
Select a verification process.
Click the "Verify your site" link.
Select your desired verification route from the drop-down box labeled "Choose verification method."
Select "Add a meta tag" and paste the provided code in between the <HEAD></HEAD> tags of your homepage, or choose the "Upload an HTML file" option to upload a blank html file with the name specified by Google.
Verify ownership of your web domain.
Upload your amended home page or Google-named blank HTML file to your server, depending on the verification method you chose in Step 2.
Use an FTP program to transfer the file in question to your website.
Click the "Verify" button to complete the process.
Identify 404 errors.
Click the "Dashboard" link to view website errors.
Examine the "Detail" column and locate any web addresses that show "404 (Not Found)" results.
Click on the "Linked From" column for each identified 404 error to see the location of the page that contains the broken link.
Visit the page that contains the broken link.
Right-click on the broken link and select "Copy Shortcut" or "Copy Link Location."
Right-click in your browser's address bar and select "Paste" from the ensuing menu.
Examine the link in your address bar.
Look for stray quotation marks, spaces, periods or commas.
Remove everything before the first slash from the link and see if the domain still displays.
Fix broken links. Open a text editor and load the HTML file for the page in question.
Correct link typos and delete links that no longer lead to live websites.
Save your amended HTML files and re-upload them to your server using your FTP program.
Return to the Google Webmaster Tools Dashboard.
Click the "Sitemaps" link on the left navigation bar.
Click the "Resubmit" button to resubmit your website's sitemap.
Wait an average of four to six weeks for Google to re-index your amended website pages.
Hope this helps
Nov 01, 2012 | Acer Computers & Internet
Need fix for 404 error
Hope this helps
Oct 31, 2012 | Acer Computers & Internet
Error 734 problem
To resolve this issue:
Click Start, point to Settings, and then click Network and Dial-up Connections.
NOTE: For Windows Server 2003, click Start, point to Control Panel, and then point to Network Connections.
Right-click the appropriate dial-up networking connection, and then click Properties.
Click the Networking tab, and then click Settings.
Click to clear the Negotiate multi-link for single link connections check box (if it is selected).
Click OK, and then click OK.
Double-click the connection, and then click Dial.
If this procedure resolves the issue and you can establish a dial-up connection, you do not have to follow the remaining steps in this article.
If this does not resolve the issue and you cannot establish a dial-up connection, go to step 7 to continue to troubleshoot this issue.
Right-click the connection, and then click Properties.
Click the Security tab.
Under Security options, click Allow unsecured password in the Validate my identity as follows box, and then click OK.
Double-click the connection, and then click Dial to verify that you can establish a dial-up connection.
Use a system utility software like RegInOut to fix all such type of errors, it will not only fix these errors but will also optimize your PC by repairing corrupt registry & windows files.
Dec 15, 2011 | Computers & Internet
My Emachine with Windows Vista keeps shutting itself down? What could be the problem?
The first step would be to turn off automatic restart on BSOD errors.
  1. Click on Start and then Control Panel.
  2. Click on the System and Maintenance link.
    Note: If you're viewing the Classic View of Control Panel you won't see this link. Simply double-click on the System icon and proceed to Step 4.
  3. Click on the System link.
  4. In the task pane on the left, click the Advanced system settings link.
  5. Locate the Startup and Recovery area and click on the Settings button.
  6. In the Startup and Recovery window, locate and uncheck the check box next to Automatically restart.
  7. Click OK in the Startup and Recovery window.
  8. Click OK in the System Properties window.
  9. You can now close the System window.
  10. From now on, when a problem causes a BSOD or another major error that halts the system, the PC will not automatically reboot. Rebooting manually will be necessary.
Now when it errors it wont restart, instead it will give you an error message that we can use to troubleshoot your problem.
I hope this helps! If this did help you, please give a thumbs up!
Jun 28, 2011 | E-Machines eMachines Desktop PC
When i connect to laptop i get connection terminated with error code 734
If you try to establish a Point-to-Point Protocol (PPP) dial-up connection, you may receive the following error message: Error 734: The PPP link control protocol was terminated. As a result, you cannot establish a dial-up connection.
This issue may occur if either of the following conditions are true:
  • Multi-link negotiation is turned on for the single-link connection.
    -or-
  • The dial-up connection security configuration is incorrectly configured to use the Require secured password setting.
  1. Click Start, point to Settings, and then click Network and Dial-up Connections.
  2. Right-click the appropriate dial-up networking connection, and then click Properties.
  3. Click the Networking tab, and then click Settings.
  4. Click to clear the Negotiate multi-link for single link connections check box (if it is selected).
  5. Click OK, and then click OK.
  6. Double-click the connection, and then click Dial.
    • If this procedure resolves the issue and you can establish a dial-up connection, you do not have to follow the remaining steps in this article.
    • If this does not resolve the issue and you cannot establish a dial-up connection, go to step 7 to continue to troubleshoot this issue.
  7. Right-click the connection, and then click Properties.
  8. Click the Security tab.
  9. Under Security options, click Allow unsecured password in the Validate my identity as follows box, and then click OK.
  10. Double-click the connection, and then click Dial to verify that you can establish a dial-up connection.
May 11, 2011 | Computers & Internet
I want to connnect internet to my pc through data cable with samsung s5620 mobile but it shows error 734, what should i do?
for more info see this link
http://support.microsoft.com/default.aspx?scid=kb;en-us;318718
i hope this helpful
than you for using fixya
Feb 19, 2011 | Samsung S5620 Cell Phone
I am trying to print on my Canon MP830 and I have had two error messages. 5C10 and 5100. I don't know what these errors are can you please help?
There seem to be a number of involved suggested fixes for the 5C10 error code.
Please go to this web page, and click the "Service and Support" link.
This will display a "Please enter your question" field. Type "5C10" into the field and click the Search button.
The first entry displayed will be a link to "ERROR LCD: Error Code 5C10" -- click the link
Three new links will eventually display:
  • Press ON/OFF switch to reset the multifunction device
  • Removing paper jams MP800R / MP830 / MP530
  • The MP830 may require repair
Click each link to see if the solution provided is appropriate to your situation.
Jan 05, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Error 404
  • 1
  • 2
    Add your website to your Google Webmaster Dashboard. Type your domain name (everything in your URL before the first forward slash) into the Dashboard text box. Click the "Add Site" button.
  • 3
    Select a verification process. Click the "Verify your site" link. Select your desired verification route from the drop-down box labeled "Choose verification method." Select "Add a meta tag" and paste the provided code in between the <HEAD></HEAD> tags of your homepage, or choose the "Upload an HTML file" option to upload a blank html file with the name specified by Google.
  • 4
    Verify ownership of your web domain. Upload your amended home page or Google-named blank HTML file to your server, depending on the verification method you chose in Step 2. Use an FTP program to transfer the file in question to your website. Click the "Verify" button to complete the process.
  • 5
    Identify 404 errors. Click the "Dashboard" link to view website errors. Examine the "Detail" column and locate any web addresses that show "404 (Not Found)" results.
  • 6
  • 7
    Visit the page that contains the broken link. Right-click on the broken link and select "Copy Shortcut" or "Copy Link Location." Right-click in your browser's address bar and select "Paste" from the ensuing menu.
  • 8
    Examine the link in your address bar. Look for stray quotation marks, spaces, periods or commas. Remove everything before the first slash from the link and see if the domain still displays.
  • 9
    Fix broken links. Open a text editor and load the HTML file for the page in question. Correct link typos and delete links that no longer lead to live websites. Save your amended HTML files and re-upload them to your server using your FTP program.
  • 10
    Return to the Google Webmaster Tools Dashboard. Click the "Sitemaps" link on the left navigation bar. Click the "Resubmit" button to resubmit your website's sitemap.
  • 11
  • Please post your feedback and Vote if the problem resolved as per your satisfaction.
    Sep 30, 2010 | Computers & Internet
    What may be the problem of my pc because it always restart?
    You need to get the exact error message to determine the cause of your system restarting. Then post again with the error message that will appear.
    If you're using Windows XP:
    1. Navigate to the Control Panel in Windows XP by left-clicking on Start, followed by Settings and then choosing Control Panel.
    2. In the Control Panel window, open System.
      Note: In Microsoft Windows XP, depending on how your operating system is setup, you may not see the System icon. To correct this, click on the link on the left-hand side of the Control Panel window that says Switch to Classic View.
    3. In the System Properties window, click on the Advanced tab.
    4. Locate the Startup and Recovery area and click on the Settings button.
    5. In the Startup and Recovery window, locate and uncheck the check box next to Automatically restart.
    6. Click OK in the Startup and Recovery window.
    7. Click OK in the System Properties window.
    8. From now on, when a problem causes a BSOD or another major error that halts the system, the PC will not automatically reboot. Rebooting manually will be necessary.
    If you're using Vista/7:
      Tip: In a hurry? Type system in the search box after clicking Start. Choose System from the list of results and then skip to Step 4.
      Note: If you're viewing the Classic View of Control Panel, you won't see this link. Simply double-click on the System icon and proceed to Step 4.
    Jun 12, 2010 | Computers & Internet
    Error 5100
    Use the link below to fix the error
    http://www.fixyourownprinter.com/forums/laser/25975
    2nd solution :
    o to the canon website (listed below) - under Tech Support - click on Technical FAQ's (this will pop up another small window)
    then click on Search by Key Word
    next - type in error 5100 and click on the circle next to - Include all words and hit Search
    next - click on the link with your answer "how to.... "
    this should show the answer
    http://www.usa.canon.com/consumer/controller?act=SupportDetailAct&fcategoryid=238&modelid=11865
    Oct 20, 2008 | Canon PIXMA iP1600 Printer
    Open Questions:
    I have a Lexmark Z11 that sat unopened in the box for several years until it was given to me as an emergency printer. The black ink cartridge had been pilfered by the original owner ( he got several of the se printers on clearance for $15 each). I bought a remanufactures high capacity cartridge. It workef fine for the three days of printing I did last week (about 25-30 pages of resumes and reference letters). When I went to use it a week later, it goes through the motions of printing but no ink is put on the page. I ran the clean cartridge several times but still no ink. I tried the new still-in-the-box color cartridge and did get color on the page in the alignment trial, but it was faded and full of white lines. I figured the cartridge was just old. It could be the ink leaked out of the remanufactured cartridge, but when I gently blew on the air hole I got a small splat of ink. (I used to be a sales rep for Canon printers a dozen years ago and we were told to do that to see if the cartridge still had ink.) I deleted and reinstalled the printer, unplugged and replugged cable and power cord twice. The printer receives the command and goes through the motion of printing, but as I said, no ink is put on the page. I have come to the conclusion the perhaps the remanufactured cartridge is at fault and I should take it back for an exchange, Can I get your take on it - is it the cartridge or the printer? Thanks! -Kathleen Brockway
    Mar 01, 2017 | Lexmark JetPrinter Z11 InkJet Color...
    Lexmark JetPrinter Z11 InkJet Color Printer Logo
    19 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Clive
    Clive
    Ekse
    Thomas F. Schneider
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
