Question about Agri-Fab Agri - Fab Snow Blower - 42"
Does anyone have the manual for a Jacobson snow burst snow blower ''homelite model ut35012''
I have a Jacobson sno-burst snow blower? I need a megneto assembly part#126668 for a j-501st engine
can do an online search for part--notify a small motor --lawn and garden repair shop --
Dec 15, 2016 | Garden
I have a Jacobson son burst blower n need the magneto assembly 126668
look up a small engine repair shop or online search for part
I do not know the oil-to-gas ratio to mix/buy. My husband passed away, and I cannot find the manual. Help, please. THANK YOU
Can you find the model number on the Homelite Mighty Lite BlowerVac?
For the UT08520 and UT08921 26cc blowers and the UT08550 and UT08951 blower vacs, you can mix the Homelite Premium Exact Lubricant with gasoline following the label directions. For other synthetic oil additives, use 2.6 oz of additive per 1 gallon of gasoline. (It's 20ml to 1 l if you use the metric system.) That's a 50:1 ratio (gasoline to additive).
Many Homelite Blower manuals are available here: http://manuals.homelite.com/documents?page=5 . You should try to find your exact model and then check the manual to confirm that your model blower vac uses this same ratio of oil to gasoline. You will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Sep 06, 2013 | Homelite Mighty Lite Blowervac
What Fuel-Oil mix RATIO would be appropriate for my Homelite/Jacobsen Snoburst snowblower model UT35012??
when in doubt, mix rich. 40:1 would be a safe ratio 32:1 might be to rich but that wouldn't hurt anything but maybe foul plugs
Feb 02, 2013 | Garden
I just need a manual for the Homelite Mighty Lite Gas Powered Blower Vac.
Do you have your model number?
You should be able to find your manual on this site:
http://www.homelite.com/service_support/product_owners_manuals
The manuals are listed by their model number rather than their marketing name. Look for the serial number plate which should also have the model number.
Thank you for using FixYa!
Aug 26, 2011 | Homelite Mighty Lite Blowervac
Snow blower won't stay running
ok heres what you do to get your snow blower to keep running.
while you have it choked, and you get it to the running point, turn the cup bowl ajustment in/out a fraction at a time while you move the chock off slowly till you get the right setting to keep it running then ajust the setting once more to clear it up to purrr like a kitten again the vibration moves the screw out to set everything out of wack......
Feb 09, 2010 | Craftsman 16" High Garden Tractor Snow and...
Homelite / Jacobsen Imperial 830 Manual
I did a search for Homelite 52642. There are several sites out there with a type of manual running from 25-30 USD. Try looking at a search like I did. Did not see anything on Homelite's site. Maybe the unit is older than 10 years.
Dec 28, 2009 | Garden
Agri-Fab Agri - Fab Snow Blower - 42" Logo
170 people viewed this question
Top Agri-Fab Garden Experts
Roland W VanLue
Roland W VanLue
Paul Sikkema
Paul Sikkema
Joseph Mueller
Joseph Mueller
Are you an Agri-Fab Garden Expert? Answer questions, earn points and help others
