Question about Haier HTF24R21 24" TV
Can not get all area channels - Haier HTF24R21 24" TV
How do I retune my Samsung smart TV 40"with 3D
Country (Area)
Broadcasting > Channel Settings > Country (Area)
Select your country so that the TV can correctly auto-tune the broadcasting channels. This depends
on the country or region.
When the PIN input screen appears,enter your 4 digit PIN number.
Digital Channel
Change the country for digital channels.
Analogue Channel
Change the country for analogue channels.
Manual Tuning
Broadcasting > Channel Settings > Manual Tuning
Scans for a channel manually and stores in the TV.
If a channel is locked using the Channel Lock function, the PIN input window appears.
This function depends on the country and region
Page 147 of this User Manual located on this page will give you more information. (Sorry it wouldn't let me link the PDF manual directly)
UE40H6240AK UE40H6240AKXXU Support SAMSUNG UK
Sep 09, 2014 | Samsung 40" 1080p 3D Slim LED Smart TV...
Missed channels
Those particular channels are not being detected because of antenna orientation or weak signal level. We have similar problems receiving digital channels 3, 6, 23, and 52 here in the Philadelphia area.
Jun 08, 2017 | RCA Dta800b1 Digital-to-analog Converter...
FRS 2Way Radio 14 Channel Conair Expedition MODEL FRS200SLV MANUAL
Here is some information that might help.
Range can vary due to topographical and atmospheric conditions. Voice transmissions on some channels are not permitted by law.
Use in DUPLEX mode, Repeater stations can re-transmit your signal over a wider area giving you extended range depending on the location, height and availability of the local repeater station.
For information on the locations of repeater sites in your area visit the manufactures website or look-up UHF channels and frequencies for your area.
Note: some channels / Frequency's are to be Avoided.
UHF Repeater operation is used when long distance communication is required, unless specifically needed use of the repeater channels is to be avoided. Some channels and emergency channels, some are calling channels for establishing communication and some are customary road vehicle channels.
You will need to look these channels up for your Area.
Other stuff on this subject on safety and safe operation.
Electromagnetic Interference/Compatibility
Nearly every electronic device is susceptible to electromagnetic interference (EMI). To avoid the possibility of electromagnetic interference and/or compatibility conflicts, turn off your radio in any location where posted notices instruct you to do so such as healthcaer facilities.
Feb 06, 2014 | Radio Communications
Cant get my digital antenna to pick up any channels
In your area, it may be necessary to use an antenna with an amplifier.
Jun 29, 2017 | Televison & Video
How do I get local channels when my Roku is connected to my TV
The roku is a one way streaming device and cannot see channels that your cable tv can see. It streams online content to your tv.
However if you live in a major metropolitan area 1 or more of your local channels may be available online, you can set those up in your private channels area then searching for local channels in your area to add as private channels.
Jan 27, 2013 | Computers & Internet
Have lost channels although I subscribe to a basis virgin package, anyone know the codes to bring the missing channels back please, or of a box we can get that will let us receive free channels
Nope.
They are switching to nagravision 3 area by area. Once your area has switched, you can no longer get all the channels.
At this time no box can get around this , but from what i read, boxes with ethernet connections may be able to work, but no fixes are available yet.
Afterdawn and techkings has info on this
Sep 03, 2010 | StarTech.com StarView SV411K 4-port KVM...
Have uniden 396T. Control channel now on one system does not work
Have you put in more than one control channel for your area.
I always put as many of the red or blue Control channels in my area. I counted 23 Control Channels for the whole system. I would put everyone in if it were me.
I set the system up as "Control Channel Only".
In a metroploitan area you should be able to pick up another control channel on the system.
I use the Arc396Pro Software ato program my scanner. (available at ScannerMaster) I know in the Pro version you can download the information directly into your scanner. You can try this to be sure your settings are going in correctly.
J
Nov 16, 2009 | Uniden BCD396T Handheld Scanner
Trying to find Channel 5
Maybe your area doesn't recieve that channel. every area has diffrent channels. But usally Channel 5 works in all areas maybe the signal prob.
Sep 08, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Wx channels
You are probably out of range of the other 5 channels for your area or your area may only have 2 Weather channels. I can sometimes get 4 here in the Los Angeles area but most of the time only 2. It depends on what the broad cast conditions are.
May 04, 2009 | Radio Shack Pro-95 Handheld Scanner
TV stuck on Channel Fixed;6
Go in to the user menu and find where the Auto Channel Setup is located. You can consult the instruction booklet for your TV set. Try this and see if it works. If it does not then there are a number of areas in the set where there can be some defective components.
The tuner is controled by the uPC system. There are a number of interface circuits involved for the channel control. Problems in these areas can cause the channels to not be able to be changed.
Jerry G.
Oct 19, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Haier HTF24R21 24" TV Logo
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
