Question about HP LaserJet 3330 All-In-One Printer
Marks down left side of copy
Line about 1/4'' down left side of paper
    Sergeant:
  • 166 Answers
There are several things that could be causing this I will TRY to address or suggest on all of them.
1.) If only appears when copying, double check the glass and make sure those areas are cleaned.
2.) If happens at all times, it could be the toner cartridge in the unit (especially if started when just changed). I would try another cartridge (later if you can stand the copies w/ the lines or if you have a spare).
3.) I have seen a lot of these machines do this putting vertical lines down the side of the paper because the fuser assembly has worn out and needs replaced.
I have seen #3 occur sometimes when paper gets jammed in a machine and someone pulls it out too rough, this can cause the slick cover over the fuser to crack, break, or bunch up, needing replaced.
Hope this helps you.
Posted on Apr 28, 2010
Black marks like a grid on left side of paper
I am a technician for brother printers. Yes it is your drum unit that is printing the grid on the unit. go our web site www dot tonerconcepts dot com and place an order for a drum from us. The drum your machine uses is the DR520/620 Our online price is $120.00 with free shipping
Aug 23, 2012 | Brother MFC-8480DN All-In-One Laser...
A Solid black line down the left side of the page
It could be 2 things...
1. Your scanner glass is dirty...open the doc feeder and clean the glass. probably Wite-Out.
2. A segment of your scanner assembly lamp is burned out. Not good, uneconomical to repair.
Jan 21, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Lines of copies utilizing automatic feeder
look to the side of your big glass and you'll see a piece of glass about 1.5" wide. thats the galss that is used for scanning from the feeder. theres got to be something on that glass. possibly white-out or even a small speck of toner can cause that. look closely.
hth,
razors
Mar 16, 2009 | Brother MFC-9440CN Laser Printer
TONER MARKS ALONG LEFT SIDE OF COPY
let me know the make & model. there may be a toner dposit in the paper path.
Jan 26, 2009 | Office Equipment & Supplies
LEAVES A BLANK LINE DOWN THE COPY
Dear sir; Try to pullout the drum unit, see have anything block the scan path( such as paper chip) or check the heat roller is there have torn paper wind up.
Dec 19, 2008 | Sharp AL 1631 Copier
3-INCH WIDE VERTICAL LINES RUND DOWN LEFT SIDE OF FAX MACHINE
Do your incoming faxes have the same marks?
If not you might find that the scanning part of your machine has a dirty mark on the glass or that the unit has become faulty.
Try and take a copy from the machine and print from a report or any print from memory.
If you have the black lines on both then i'd suggest getting a new drum unit, if u have it only on the copy I would have a look at your scanner glass and see if there is a dirty mark on it. if not maybe call out an engineer as the scanner unit maybe faulty.
Need anymore help msg me.
Dec 11, 2008 | Office Equipment & Supplies
Panasonic Panafax UF-885 - Heavy lined marks down side of paper
First print a report to see if the lines appear without using the scanner. If this is the case clean the charge wire. If you pin it down to the scanner, it is probably a poor solder joint on the cis unit. Take it out and run a hot soldering iron over all the joints on the reverse side of the cis.
Apr 15, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Grey Band/lines across page
your problem could be one of many things first try stoping the copy half way in the machine. to do this open the front door and cheat the door switch with some folded up paper or use a flat screw driver to bypass the switch. make a copy and watch the paper when in goes into the drum and starts to come out like 3 inches pull the screw driver or paper out of the switch. carefully pull the paper out from the machine and see if the image is ok. if the marks are there the problem is with the drum. if the image is clear and there is no marks then open the left door on the copier and inspect the rollers in the heat unit. to do this open the left door the front door has to be open to do this. there is a little green lever on the right side pull this down and look at the 2 roller if you see marks on the top roller or dirt on the lower roller this is your problem. also check the miliage reading on the drum if there is a sticker and check the meter on the machine the drum is rated for 55,000 copies.
Jan 03, 2008 | Canon imageRUNNER 400S Copier
HP LaserJet 3330 All-In-One Printer Logo
158 people viewed this question
Seeker5211
Seeker5211
