Question about Sony Playstation 3 (PS3) Console
My system heats up real quik like no sooner than i turn it on then it just messed up altogether when it goes to come on it goes green then yellow and red and blinks and shuts down. what is the problem and how can i fix it myself?
  • 40 Answers
You have yellow light of death. google gilsky method for fixing ylod
Posted on Apr 29, 2010
Hey, I purchased your Honeywell RTH2510 Thermostat, but I didn't even think to label the wires when I took the old thermostat off. Upon installation of the new Thermostat (2510) the Air Conditioning...
The connections that you really need to reference would be at the air handler itself. That would tell you which wires go outside to the heat pump and which wires go to the air handler. I can however give you some basics that may help.
Heat Pump Wiring
Terminals/Colors/Function
R- Red- 24v power supply. (Usually a jumper between RC/RH)
G- Green- Fan
W- White- Heat (Sometimes W1-W2, first or second stage heat)
Y- Yellow- Cooling (Same applies as above i.e. Y1-Y2)
C- Common (Most people use blue unless it is used for B terminal and sometimes cooling on older 4 wire systems.
B/O- Reversing Valve for heat pump. Either powered heating or powered cooling, depending on system installed.
Aux- Also used for heat.
Note: Considering that the installer had their own way to run all wires, use different wires, connections, etc. This is just a reference to common wiring in the field.
How the most common system is hooked up:
Thermostat:
Red wire goes to R terminal
Yellow wire goes to Y1 or Y2 terminal
Green wire goes to G terminal
White wire usually goes to W1 or W2 terminal
Orange or Black wire goes to B/O terminal
Brown wire usually goes to Aux terminal
Blue wire goes to C terminal, unless its being used as stated above.
This is without using a fossil fuel kit or zone control board.
Where do they go from the thermostat?
Red
goes to the air handler transformer or board and goes outside to heat pump to power low voltage controls.
Yellow wire goes straight outside to Y terminals on heat pump unless going to a board inside first.
Green goes to the air handler fan relay.
Common goes to the air handler and outside to heat pump.
Black or Orange will go outside to heat pump terminals for reversing valve.
White usually goes outside to heat pump,and inside to air handler. Will explain reason further down.
Brown will go to the air handler to the heat relay for the emergency heat.
On a call for heat, with a powered cooling system (more common).
The R, Y, and G terminals energize, sending a signal to start the blower and pull in the contactor outside. Note that the Y terminal is usually cooling, but since this is a powered cooling system, the reversing valve is not energized, causing the system to run in heat mode. If you have powered heating, the reversing valve terminal will energize also. Depending on thermostat, if you set the temp substantially higher than room temp, it may kick on the emergency/aux heat to quickly raise the room temp. On a call for emergency/aux heat, the R, G, and E/Aux terminals are energized, turning on the electric/gas heat instead of the heat pump. This comes in handy since the heat pump can only pull so much heat from outside before its not enough to properly warm the house, usually around 30 degrees outside temp. If you are running the heat pump and the system goes into "defrost", the outside unit will send a signal back to the air handler, through the white wire I mentioned earlier, to tell the emergency/aux heat to come on while it is in defrost mode, providing heat whenever needed.
Again, this is just a reference guide to some basic wiring, but hopefully it will tell you where the problem is or at the least, give you a good start. There are variables in which things can change the wiring like a zoning system or fossil fuel kit. Even then, you should be able to get pretty close. Hope this helps and Happy Holidays!
Dec 07, 2013 | Honeywell Programmable Thermostat Heater
I have a Canon Pixma iP4000 with a baffling problem. When I turn it on, the lights flash in this pattern: 4 green, 5 yellow, 1 green, 5 yellow, the yellow light stays on for a moment, then the printer goes...
Follow these steps to reset the printer:
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
4.
Jan 27, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
Hi, when we turn on the PS3 the light goes green for no more than 2 seconds, flashes Yellow/orange and goes to red. Nothing comes on the screen. Where to from here? Lance
its call YLOD...just happen to me b4...u need to heat the 2 cpu n gpu with heat gun about 5mins with 400-500 degree..this procedure is to resolder the gpu/cpu.tQ
Oct 22, 2010 | Sony PlayStation 3 40GB System
Playstation 3 (PS3) Console: has power go to turn it on goes to green then afte...
you got the yellow light of death, you would need to reflux solder on the processors and reheat the solder, here is a link for the repair, http://www.youtube.com/watch?v=XIm0Qk0CVTE&feature=related I suggest you take it to a pro if you feel you can not do it, you can mess up your ps3 if you don't do it right and taking it apart is a delicate job.
May 17, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 (PS3) Console: When it turns on light goes green then yellow and ...
yellow ring of death. there is no repairing it. you have to get a new system.
May 07, 2010 | Sony Playstation 3 (PS3) Console
The lights on the guitar flash real quik when first turned on.
it will be a error on the hard drive try and get a new harddrive
Dec 13, 2009 | Nintendo Wii Rock Band Guitar for Wii
I have a mobile home with just heat but the air cond come with it
You will now need a 4-wire thermostat as well as 4-wire thermostat cable since you now have cooling in addition to heating. The 4-wire cable should have a red, green, white, and yellow wire. Some cables have a blue wire in place of the yellow wire. The red wire, which is 24 volts hot, goes on 'R' terminal. The green wire, used for the indoor fan, goes under 'G' terminal. The white wire, used for heating, goes under 'W' terminal. And the yellow or blue wire, used for cooling, goes under 'Y' terminal.
Aug 05, 2009 | Heating & Cooling
Disc stuck and then Ps3 system when turned on goes from green to yellow then blinking red
PS3 has overheated and the thermal compound between the cpu/gpu and heat sync need to be replaced. the gpu and cpu may need to be reflowed as well. Had the same problem and fixed mine. The thermal compound was pretty much gone when i opened up the system. Also dont keep your ps3 on its side leave it flat this will help keep the compound from moving as much.
May 06, 2009 | Video Game Consoles & Games
Sony Playstation 3 (PS3) Console Logo
67 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
