Question about Gateway Profile 4 All In One (MPN PROFILE4SE) PC Desktop
Blank screen or vertical colored lines on monitor
Boots up sometimes, runs for awhile and then either a black screen or vertical different colored lines. It will stay this way until shut down. Sometimes it tries to restart itself but I get the same problem. Sometimes it does the black screen or vertical lines immediately on start up. I have had it three different places for repair...Help!
  • Taostinese Mar 25, 2008
    Any idea where the graphics card is located on the all in one gateway profile 4 and how to remove it? Gateway can't seem to walk me through the process or provide schematics.
    I appreciate any help. I had it in to several places. They all say it is not the graphics card. Best they could offer was they thought there might be a loose connection between the monitor and the motherboard?? I have no clue about any of this! Thank you for all the help shugster. Below are two sites. The second site is the computer I have. I hope you can help me.
    http://support.gateway.com/s/Profile/Pro...
    http://www.support.gateway.com/s/Manuals...
  • 93 Answers
Sounds like a graphics card failing
is it on board graphics ?
if so try a graphics card in there see if that helps it
also if you could borrow a monitor and see if that helps
its either one or the other and is a process of elimination
Posted on Mar 24, 2008
  • Anonymous Mar 25, 2008
    can you give me the exact model or even a link to a pic of the machine ?
    just so i can get a clearer understanding of it ?
    ok first we will try a driver up date
    click here for the driver
    i wont reply for a while as im of to work but will get back to you on this matter
    i will try my level best to help you
SOURCE:
MONITOR HD2200. I TURN IT ON AND THE SCREEN GOES WHITE THEN A FEW VERTICAL COLOR LINES APPEARS AND AFTER A FEW SECONDS IT GOES BLACK.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help out in solving the problem....
May 21, 2011 | Gateway HD2200 LCD Monitor
FP-768 (Silver, Black) (Black, Silver) 17 in. Flat Panel LCD Monitor: My screen goes haywire with all kinds of color cha...
The vertical lines/bar are sign of bad T-CON (LCD controller driver) board is bad, it is part of the LCD panel assembly, new screen will be needed, not worth it. You may try reseating the ribbon cable at the panel.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
May 16, 2010 | Fuji FP-768 17" Flat Panel LCD Monitor
Black screen with vertical lines through it
Could be faulty graphics chip or faulty screen. If you can hook up external monitor and picture is fine then probably faulty screen. If external monitor shows same problem the faulty graphics chip. Take to repair shop and let them have a look.
Jun 10, 2009 | Compaq Presario M2000 Notebook
Inspiron 8500 laptop monitor; vertical lines & color bursts
It sounds to me like you are having a problem with the video card on the motherboard, I am not familiar with this model but some you can remove the video card and upgrade, some you can not.if you can upgrade you can try this
if you cannot remove the video card then a new motherboard will be required to fix this computer.
you can look on ebay for a replacement at a reasonable price or talk to your local computer service center.
hope this helps.
Jan 09, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
Inspiron 8500 - Display issue
with the external monitor attached press <FN><F8> to toggle between internal and external display. if still nothing then it sounds like the video card.
MANUAL
Check all the connections (especially the ground screws) that was a problem with one I worked on last year.
May 29, 2008 | Dell Inspiron 8500 Notebook
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
Gateway Profile 4 All In One (MPN PROFILE4SE) PC Desktop Logo
1,333 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
