Question about Fedders A6Q10F2B Q Chassis Room Air Conditioner
How do I check the freon (coolant) and replace if necessary?
  • 674 Answers
You'll need some refrigerant guages that'll cost anywhere from $85 upwards. First though you would need to check and see if it even has the service ports to connect the guages to. Depending on the type of refrigerant you will not be able to buy it unless you have a CFC certification and then a 30 lb jug is $200 or more. You should probably get someone to check it for you. With the price of components and service calls it's usually cheaper to get a new unit but you could call and get some prices for service calls first. Sorry to give you this bad news.
Posted on Apr 29, 2010
How to replace heater core 2005 hyundai tucson
rip out the dash
rip out the sub-dash
drain coolant and freon
replace heat exchanger
recharge freon and coolant
replace subdash and dash
or
drop car off at shop
pay money
drive away
come back
pick car up
Dec 06, 2014 | Hyundai Cars & Trucks
Codes p0128
A code P0128 may mean that one or more of the following has happened: Low engine coolant level Leaking or stuck open thermostat Faulty cooling fan (running too much) Faulty coolant temperature (ECT) sensor Faulty intake air temperature (IAT) sensor Possible Solutions Past experience indicates that the most likely solution is to replace the thermostat. However here are some suggestions on troubleshooting and repairing a P0128 OBD-II code: Verify coolant strength & level Verify proper cooling fan operation (check if it's running more than it should). Replace if necessary. Verify proper engine coolant temperature (ECT) sensor operation, replace if necessary. Verify proper intake air temperature (IAT) sensor operation, replace if necessary. If the above items check out good, replace the thermostat
Aug 09, 2014 | 2007 Pontiac G6 GT Convertible
Po1228
Nov 13, 2013 | Cars & Trucks
Vibration in idle
could be a/c compressor is trying to lock up and dragging the idle speed down. before adding freon check the a/c freon level by using a/c manifold gauges to check the line pressures. may even want to pay someone to check them for you.
Jun 06, 2012 | 2000 Toyota ECHO
Zenith air conditioner coolant replace
usually does not replace the freon unless host pipe to measure the freon, then if you actually fill in as needed
Apr 20, 2012 | LG Heating & Cooling
Vw jetta code p0128
this obd2 trouble code table can help you understand the meaning of code.
and for p0128, you can try:
Aug 13, 2011 | Volkswagen Jetta Cars & Trucks
CEL on with PO128 code. Recently replaced radiator and thermostat. No engine cooling issues, had a leaking rad. Checked coolant flow; hot and cold, normal. Was going to replace ECT sensor, but want to...
  • Low engine coolant level
  • Leaking or stuck open thermostat
  • Faulty cooling fan (running too much)
  • Faulty ECT Sensor
  • Faulty intake air temperature (IAT) sensor
  • Verify coolant strength & level
  • Verify proper cooling fan operation (check if it's running more than it should). Replace if necessary.
  • Verify proper engine coolant temperature (ECT) sensor operation, replace if necessary.
  • Verify proper intake air temperature (IAT) sensor operation, replace if necessary.
  • If the above items check out good, replace the thermostat
Jun 11, 2011 | Dodge Caravan Cars & Trucks
I am getting P0128 obd code for my nissan sentra. how to solve this
Take note of the blurb regarding NISSAN products below
  • If Nissan vehicle, check for Technical Service Bulletins (TSBs), as the ECM may need to be reprogrammed to correct the P0128 code
Nov 17, 2010 | 2002 Nissan Sentra
What does code: PO128 mean? I plugged it into the diagnostic machine, and that's the code that popped up.
  • Faulty coolant temperature (ECT) sensor
The most common cause is a faulty thermostat. However here are some suggestions on troubleshooting and repairing:
Nov 20, 2009 | 2007 Chevrolet Silverado 2500HD
Fedders A6Q10F2B Q Chassis Room Air Conditioner Logo
156 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
